Question about Sony PlayStation 2 (PS2) Console
Ps2 will not boot up. press reset and only turns green x 2 seconds then returns to red status...no boot up..
    President:
  • 4,402 Answers
Call Sony tech support 1-800-345-SONY
Posted on Jan 04, 2008
When i turn on my tv it tries to boot, blue mitsubishi home screen come up, i hear fan then it all shuts off while green light blinks.
Try a reset. Start by unplugging for 1 minute, then plug back in & if still won't restart try the following. If none of the following work, you will need a technician.
Initializing the TV in many cases can remedy a problem.
In the 2006 product line Initialization is now a user function.
Pressing the front panel "INPUT' and "FORMAT"
buttons at the same time activates Initialization. When
complete all user settings will have to be set again. The
table in Figure 4-3 list the User Initialization procedures.
Note: Pressing INPUT and FORMAT is the same as
the Initialization in the Option Menu (MENU-2-4-7-0)
Order Name Procedure Results Notes
1 System Reset Press <System Reset>
on Front Panel
Hardware & TV operating
software reset.
POWER/Timer LED flashes for 60
seconds. No customer settings
are changed.
2 User Initialization
Press <INPUT> &
<FORMAT> on Front
Panel at the same time.
All customer Audio &
Video settings are reset to
factory default.
All customer settings will need to
re-configured.
3 Reset System
Defaults
From the remote, press
<MENU> <1-2-3>
<ENTER>
except V-Chip are reset to
factory default.
Netcommand, Channel Memory,
etc., will need to be re-configured.
SERVICER
PROCEDURE 4 Initialization
<MENU> <2-4-7-0>*
select "INITIAL" press
<ENTER>
All customer settings are
reset to factory default.
re-configured.
MITSUBISHI RESET / INITIALIZATION CHART
CUSTOMER
PROCEDURES
Figure 4-3
Figure 4-4
LED Indications
The front panel LEDs, refer to Figure 4-4, also assist in
determining the cause of a symptom. Figure 4-5 illustrates
normal LED operation. Figure 4-6 shows the
LEDs response when a problem is detected and indicates
the possible cause.
Power/Timer
Indicator
Status
Indicator
Lamp
Indicator Condition
Off Off Off Off (standby)
Blinking green
fast Off Off Initialization (10 - 65 seconds)
Off Off Blinking
green fast Lamp runs for 1 min after PTV off
Green Off Off Power On
Blinking green Off Off Power On Timer is set
NORMAL LED INDICATIONS
Power LED Status LED Lamp LED Condition
High Temperature - check ventilation air flow.
(Temperature sensor is disconnected.)
Off Off Blinking yellow Lamp cover is open.
Lamp failure (Lamp fails to turn on)
Off Off Red (Lamp turns off after lighting)
Lamp is broken
Off Blinking Red Off Fan Stop
Off Red. Off Circuit failure. (Run Error Code Check)
Apr 08, 2015 | Mitsubishi WD-65731 65-Inch 1080p DLP HDTV
Have changed water filter, but indicatot panel calls for order h2o filter, and comes on every time we dispence water. why?
Most models also have a filter indicator reset button located in the same area. After changing the filter, reset the filter status light by pressing the Filter Indicator Reset button or by pressing and holding the Filter button for 3 seconds. The status light will change from red to green or the status display will change from "Replace" to "Good" when the system is reset.
If your model has a water filter indicator, but no reset button, press the light switch in the refrigerator compartment 5 times within 10 seconds to reset the system. The status light will change from red to green when the system is reset.
Oct 16, 2012 | KitchenAid KBFA25ER Bottom Freezer French...
Red light stays on after changing the water filter and running about 2 gallons through it
Water Filter Status Indicator
Light (select models)
The Water Filter Status Indicator Light serves as a
reminder to replace the water filter. A green light
indicates that the filter is in good condition. A red light
indicates the filter should be changed. Once light turns
red, it will remain red until function is reset.
To Reset Indicator:
• Press and hold both the Lock and Water
buttons simultaneously for four seconds. The
green filter status indicator light will flash
three times when the function has
successfully reset.
Nov 27, 2009 | Maytag MZD2665HE Side by Side Refrigerator
PS2 Won't turn on!
try this:
1) turn off the PS2
2) unplug the PS2 and wait a couple minutes before plugging back in.
3) turn on PS2
hope this helps :D
Aug 23, 2009 | Sony PlayStation 2 (PS2) Console
Changing light after installing new water filter
(select models)
To Reset Indicator:
• Press and hold both the LOCK and WATER
successfully reset.
Aug 12, 2009 | Jenn-Air 21.6 cu. ft. Side-By-Side...
Whenever i try to turn on my ps2 it goes green for 2 seconds then red again. whats wrong?
try this:
turn off your PS2.
unplug the PS2.
wait 1 minute before plugging it back in.
turn on PS2.
hope this helps :D
Aug 05, 2009 | Sony PlayStation 2 (PS2) Console
PS2 No Green Light
Maybe it has something to do with your power supply, try replacing it with a different one.
Jun 09, 2008 | Sony PlayStation 2 (PS2) Console
Ps2 not spinning and light turning green then back to red
Hi
Your PS2 is probably experiencing a short circuit on the motherboard or the Emotion Engine is burned up. Sometimes the fan goes dead and the PS2 overheats and shuts down showing the red light. You can open the PS2 and clean up the motherboard and maybe it will recover.
Jan 30, 2008 | Sony PlayStation 2 (PS2) Console
My Ps2 light turns green then turns red
check to make sure your power cable is securely in, and check for any damage in the cable
PS2 not booting up
http://www.cdrom-guide.com/forums/archive/index.php/t-179062.html heres the link:
Feb 18, 2007 | Sony PlayStation 2 Slimline Console
Sony PlayStation 2 (PS2) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
