Question about Samsung DLP HL-P5663W 56" TV
Samsung HLN567W whining sound from front bottom middle of tv
No problems with this set since September 1993 but all of a sudden it's whining from the bottom front. Any ideas?
  • kenmp Jan 04, 2008
    Is there some sort of fan in the bottom front of the set? That fan sound the tv normally makes after it starts (which eventually stops after it's turned off) is what's now accompanied by the whine. I'm in the Rocky Mountains near a ski resort so a technician will be hard to come by. I don't use the tv sound, only a seperate audio system, so I know it's not the sound.
  • 689 Answers
Hi
Here is the steps that I will suggest you to check.
Mute the sound completely and make sure sound is not coming from speakers. If you totally concluded that sound is not coming from speakers probably its from internal coils on the circuit or high voltage cable leaks statical electricity. that case asking assistance a qualified hands on technician will be best idea.
Good Luck
Posted on Jan 04, 2008
The sound on my tv is just clicking
First, try to connect ext speakers. If the sound is OK just replace speakers. Otherwise the problem in amped sound output.
Feb 09, 2015 | Samsung HLN567W 56" Rear Projection HDTV
How do I replace the lamp in a Samsung HLN567W tv?
You should see small trap door on Letf hand side in the Back of TV remove screws holding it there, behind it is Lamp remove 2 screws holding Lamp in remove and install New Lamp.
Mats Electronics has best deal on Lamps 1-800-628-1118
Mar 28, 2010 | Samsung HLN567W 56" Rear Projection HDTV
Have Samsung HLN567W and recently started having
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 12, 2010 | Samsung HLN567W 56" Rear Projection HDTV
No Picture No Sound
First look for Bad Capacitors on [power supply board,if anyone of them is puffed up on top they are bad,Then if you do not have any bad caps How old is the Lamp in Set? if TV recycles 3 times for turn on and you have 2 greenlights on front and one red light---- lamp needs to be replaced.
Jun 23, 2009 | Samsung HLN567W 56" Rear Projection HDTV
Samsung tv hln567w
This was a $4000 TV 5 years ago. I own one, and it is still a very good TV. The biggest thing that can go wrong (and is worth repairing) is the light bulb can go out & it costs about $200 to replace. If anything else major goes out, it is probable better replaced than repaired.
Feb 23, 2009 | Samsung HLN567W 56" Rear Projection HDTV
Fuzzy connection on my samsung DLP HLN567W
Try the DVD player on another component connection on the TV. If the picture is still distorted try another DVD player or something with component output. If thre picture is normal with another input device then the issue is the DVD player,
Nov 28, 2008 | Samsung HLN567W 56" Rear Projection HDTV
COLOR WHEEL
you can check the settings on the manual of your tv or the configuration of the menu in the front panel.
Sep 08, 2008 | Samsung HLN567W 56" Rear Projection HDTV
Samsung HLN567W DLP whining problem
If it is the bottom front, it is the color wheel. To tell for sure, take the back off (fake out the cover switch) and listen to the fans.
Jan 04, 2008 | Samsung DLP HL-P5663W 56" TV
Tv has what sounds like a humming noise by where the bulb is
sounds like the color wheel problem.
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
Dec 11, 2007 | Samsung HLN567W 56" Rear Projection HDTV
Samsung DLP HL-P5663W 56" TV Logo
139 people viewed this question
Jerry Greenberg
Jerry Greenberg
