Compaq Evo D500 PC Desktop
Problem for Compaq Evo D500 PC Desktop
My pc tells me that I'm running out of hard drive
By kevinbrookes on Nov 03, 2009
My ancient pc tells me that I'm running out of hard drive space. I've done some cleaning up. Should I get an external hard drive or interna? Also, would the external drive move all the software from the internal one to the it? My internal drive has just under 10 Gb's. It's windows xp.I can't see what make it is, other than it's compaq 'evo'.
Best Solution
posted on Nov 03, 2009
Very Helpful)
ameerm
Rank: Wiz
Rating: 83%, 115 votes
You can use either.
You can also use external portable hard disk, you can move all your software and stuff to it.
Better would be installing a new operating system to new hard **** with larger capacity, it will make your system fast.
You can also fit hard disk in your computer PC cabinet, you will just need to set it as "Slave" or secondary hard disk, to do this, setting is available on the hard disk.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Somewhat Helpful)
sarasvatas
Rank: Wiz  Computer Hardware  Expert
Rating: 83%, 97 votes
you can go for both driver internal as well as external......the thing is what type of data you have stored in 10 gb hdd......if its user data file then you can move it to other external or internal hdd.....if you have installed some heavy software or program then you need to internal hard drive. because you can not copy installed software from one drive to other....for tis you have to install windows on other internal hard drive with bigger size like 160 gb or 250 or 320 gb.....its your wish which one you chose according to your need....
Was this helpful?
Yes
No
Popular Solutions for Compaq Evo D500 PC Desktop
Questions and Unsolved Problems for Compaq Evo D500 PC Desktop
Do you recommend Compaq Evo D500 PC Desktop?
Answer
Answer
connecting to the Gnutella network with Bearshare 5.2.5
Answer
Umax 2200 usb scanner & Vistascan 3.55u in Windows XP Scanner installs to the default XP... (More)
Answer
no sound on 17 inch LCD Monitor , Model LCm 17v2
Answer
no sound no picture already ruled out hd converter as the problem . only 3 yers old. what are the... (More)
Answer
Hello, new problem. My uncle has asked me to fix his iWin media player. It plays it all and has an... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Compaq Evo D500 PC Desktop:
Top PC Desktop Experts
Rank: Guru Guru
Solutions: 745
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Desktop Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
