Error code F 20
Sometimes the error light will come on because of mixed signals sent. If everything works, then just ignore it. Unplug the oven or turn power off in fuse box. This may reset the light control. Be very careful around the power source. Wear rubber bottom shoes, have dry hands and floor. Don't touch exposed wires with anything. This is 240 volts that can hurt or kill you!!!!!!
Testimonial: "Appreciate the advise, but would still like to know the exact meaning of error code F 20. Thanks."
The "F20" error code means "Function switch problems".
This oven has a very comprehensive diagnostic program and if you just bought it I would recommend to call the Gaggenau because the oven should be under the manufacturer warranty. other wise this is not your home handy person fix. This oven will need an electronic diagnoses.
