The most common reasons an INFINITI I35 heater isn't working are a broken heater blower motor, a problem with the thermostat, or a failed heater blower motor resistor.
Model No Required below Model No AH-X18MEV Self diagnosis mode given
1. Indoor unit
(AH-X18MEV, AH-X18MEV-1, AH-X24MEV, AH-X24MEV-1)
To display the self-diagnosis, hold down the AUX button for over 5 seconds on the indoor unit when the indoor unit is not operating.
• The operation lamp (red), timer lamp (orange) and Super jet lamp lighter) flash to indicate the information of malfunction.
(Display of self-diagnosis result)
The operation lamp (red) and the Super jet lamp (green) flash in synchronization with the timer lamp (orange).
(AH-XP18MV, AH-XP18MV-1, AH-XP24MV, AH-XP24MV-1)
• The POWER CONSUMPTION indicator indicates the information of malfunction by showing the main category error (number) and the sub-category
error (-number) alternately in 1-second intervals.
Example: Compressor high-temperature error
Remark
• If the power cord is unplugged or the circuit breaker is turned off, the self-diagnosis memory is lost.
AUX
Operation lamp(red)
Timer lamp(orange)
Super jet lamp(green)
AHX18MEV
4 - 12
[8] SELF-DIAGNOSIS FUNCTION
1. Indoor unit
Remark
The white is the backlight showing threw this means the lc is in need of replacment just the screen alone will run you $75 bucks on top of any labor if you do not want to do it yourself.
Diagnosis= Bad lcd display
prgonosis= Repair lcd or replace camera
We here at fixya are community experts donating our time to help the internet community, please sow you support but using the thumbs above to rate your solution today.
Not sure about your hard starting problem, but the Done in the odometer is the conclusion of the computer test. If you turned your key on and off 3 times, it activates the self-diagnosis and will show the codes of any problems you are having. If you are getting no codes, and just DONE, it's finding no problem.
Maybe a Dodge expert will pipe up and give you some ideas about the no-start. According to a quick google search, it seems your problem is relatively common.
Hi, Focus motor in lens assembly is not working or jammed. so camera gives error code C-32-60 If you know how to open and pack camera, give a look there.
Your camcorder has a self-diagnosis display function. This function displays the current condition of your camcorder as a 5-digit code (a combination of a letter and figures) on the screen. If a 5-digit code is displayed, check the following code chart. The last two digits (indicated by ss) will differ depending on the state of your camcorder.
what does c31.23 mean when showing on the screen.can i fix the problem myself or do i have to get a professional to fix it.when i try to use the video a beeping noise and the above number is displayed on screen
i have the same camera.i am told that the powersupply board is not working.i can give tis for $100.00. MAY BE YOU CAN USE THIS TO SWAP PARTS.PLEASE REPLY [email protected]
