Question about Samsung ML 2010 Laser Printer
Pint help with ML 2010 (wireless\)
Hi:
Printer is not recieving message (I guess) as it is not printing.
Thanks Christine
  • l6h3e7 May 27, 2008
    printer won't respond to Print when I drag item to be printed to it's icon.
    Word print is dimmed in menu.   Mac OS Leopard  J
  • 233 Answers
Un-intsall printer and driver and re-install from CD
Posted on Jan 04, 2008
6ya staff
SOURCE:
I have just put new ink cartridges into my Kodak ESP 3 printer and I have recieved the message that the printhead is missing or not installed properly. I have taken out the printhead and put it back in but...
Hi
Try to clean the print head manually until ink flows. Rub the print head into a plain paper with rubbing alcohol until in flows. Then try to print again.
Clean also the contact point of the ink cartridge by a cotton swab to clean some dirty on it and try to plug back ink cartridge again.
Try this solution also,
Remove the USB cable into the printer and leave the printer on.
Remove all the cartridges.
Close the cartridge door and wait for the INSERT INK MESSAGE to appear.
Disconnect the power cable and from the power source supply.
Move the carriage using your hand from the original position to the other side of the printer and then move it back to original position. Wait for couple of minutes
Reconnect power cord and turn on the printer.
Return all the ink cartridges and close the door. Wait for the calibration process.
Print the test page to check if it working.
Reconnect the USB cable and try to print again.
If still not working, maybe the ink cartridge is defective. If under warranty, return it for free replacement.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
Apr 25, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Hi, I bought the deskjet 3050 printer and recieved it yesterday. I have not yet been able to print any documents from my laptop. I have correctly installed the ink cartridges and the printer is able to...
It looks that you can receive data (eg.scanned) from your MFC but cannot send information to it {eg. reference to 2-ways communications not working):
I suspect that it is a 'Firewall' problem or 'Antivirus' issue: review possible logs and try turning both Firewall and Antivirus to check if they are the problems.
Jan 07, 2011 | HP LaserJet 3050 All-In-One Printer
Printing streaks on all faxes I recieve
clean the rollers in the paper path
Please rate my help++++Thanks for using FIXYA
May 07, 2010 | Canon MX300 Office All-In-One Printer
My Printer won't print, Amber light won't stop flashing.
Install the new cartridge for permanent solution for this error.
Sep 17, 2009 | HP DeskJet 940c InkJet Printer
My L295 fax machine does not recieve and print
The Fixing unit of the fax is blown.Replace the fixing unit.
Aug 12, 2009 | Canon Office Equipment & Supplies
Printing error message: cartridge problem.tri-color.I wasn't even
hi,
its becoz even if ur print contains only black text in it, while printer printing in black it needs a cyan or yellow ink to give very clear print out. work around for this issue, go to the printer icon and right click and go printing preferances and change the option to print only in blak or print only in gray scale. it should resolve ur issue............
Regards,  raj_p5983
Jan 21, 2009 | HP OfficeJet J4580 All-In-One Laser...
Printer
Christine, most printers, whether they just print or if the also have other functions, come with maintainance software that is installed along with the software needed for printing. I would first go to the start button, then to programs. Locate the printer program that you have, if there is an arrow to the right of your printer model, that means that there are other functions that you can perform from that program other than just printing. Point the mouse to the arrow, a small menu should come up , look for either "toolbox" or maybe "printer maintainance" , something to that effect. All printers and their software are similar but determining the exact operation of yours is impossible without knowing the make and model that you have. If you can find this maintainance option, I would try that first. If you can first try the cleaning option,and if that runs, you should also have an option to print a test page .If you are still having difficulty, either check the printer manual, or if you do not have the manual, you could look up the manufacturer online and go to their support section. They normally have a section to type in a question.
Sep 29, 2008 | Brother DCP 130C All-In-One InkJet Printer
Phaser 8200 error message - lamps out
I was wondering if any of you have the guide with pictures on the instructions. I got to step 5 and I am stuck trying the remove the upper transport.
Thanks
[email protected]
Jun 26, 2008 | Xerox Phaser 8200 Laser Printer
HP officejet all in one fax/printer
hi,
try this
> print a fax test
> decrease the speed at which the faxes are being sent.
you can perform these from the menu button on the printer
thanks and regards
agnel
Mar 14, 2008 | HP Officejet 5610 All-In-One InkJet...
WON'T PRINT TO DESKTOP
did u check your printer with another system or laptop
i guess that will help u...
thanks
Dec 27, 2007 | HP DeskJet 5150 InkJet Printer
Samsung ML 2010 Laser Printer Logo
76 people viewed this question
Top Samsung Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tareq Bin Mostaq...
Tareq Bin Mostaq...
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
