My Acer aspire 4930 wont charge the battery. The power source from the wall outlet seems working fine. The power led light is blinking but the laptop refuses to power up. I have tried to use my adapter with another laptop and it worked fine. When i removed the battery and use only the power from the wall outlet, it wont turn on as well. Could it be my motherboard failure? help me please. Btw, sorry for my bad english.
You have done the right things by working on some process of elimination.
try
removing the battery and the AC adapter from the laptop hold down the power button for about 40 secs then try with power.
IF this doesnt work chances are its a Motherboard failure.
hope this helps a little
i can not get it to boot of the windows xp installation disk.(this is a bootabl disk) i have change...
(More)
i can not get it to boot of the windows xp installation disk.(this is a bootabl disk) i have change the 1st boot as cd drive yet this did not work and also tried other options like when it first start up pressing the esc key it brings up the menu and gives you the option to select which drive you would like to 1st boot drive selecting cd yet it still does not start from the cd i have also tried external cd rom and using removable drive still no joy so how do i install windows xp or any other OS on cybercom fid2010
