Question about Philips 42FD9954 42 in. Plasma HDTV
Philips 42" plasma blue line down left side
Blue line down left side.
  • 3 more comments
  • jmpamme Jan 06, 2008
    Blue speckles down left side and top edge after on for some time. - Seems to go away after pulling power for few mins and turning back on. Blue blur seems to be best seen when screen is showing a lighter color in that area.
    Any help?
  • torrey36 Jan 15, 2008
    I also have the same prob. I have the 50in plasma HD version and it was fine for a few months. But now I have vertical blue/green lines on the right side of my tv. It started with just a few lines that would sometimes appear. Then it went from that to several now it is it about a foot wide of blue/green lines. Anyone have any suggestions?
  • achiscachis Aug 02, 2008
    I also have the same problem, only mine is on the top left side, and everytime the program is on a light setting, you see little blue squares transpassing trought.
  • Anonymous Jan 11, 2009
    panasonic 42" plasma blue line down left side problem,
  • Anonymous Mar 27, 2014
    just half the screen is got 2 green lines running down the left side the other side is fine.can it be fixed
  • 92 Answers
The lines are most likely the panel which isnt cheap
the blue speckles are just a voltage adj. on the y sistain if you feel confident enough you could try this yourself(though expensive equipment is usually required i do without). what you would have to do is take off the back panel if you have a stand put it back on that. easier to work on. then plug it. BE CAREFUL not to touch anything inside!!! from the back you will see a board on the left side on that board will be a small board attached vertically it will have a gray screw attached(very small). with the tv on you adj. the screw until the blue goes away(a little does alot).
Posted on Jan 20, 2008
I had the same prob...called philips and they sent out a repair man. thought he would have to replace the whole board.. end up and had to adjust a few readings. he removed the back so the whole panel was exposed. think there is four panels each is has a defalt reading which is labled in the back once panels are exposed and he had to adjust each one. each one is like a small dial that was adjusted with small screw driver. ...ever since havent had a prob...tell this to the repair man and hopefully they will be able to adjust. keep watching him so you learn to do yourself if this happens again.
Posted on Aug 16, 2009
Just had the tech leave. Fix was to adjust some voltages that have drifted up about 8 volts. - you can call them at 610-582-5351.
Posted on Jan 22, 2008
    Problem Solver:
  • 5 Answers
I found that putting a fan behind my tv to cool it down makes the blue lines go away. Hopefully this works for somebody else.
Posted on Jun 02, 2010
My LG 42 Plasma works sometimes then half the screen goes black but the right side stays perfect???
have almost the same problem left side is black with sometime blue line red lines or a whole bunch of different lines some one help please have sound and right side of tv works fine
Sep 26, 2010 | LG 42PC3D 42 in. Plasma Television
Got a blue vertical line on me plasma
Ohh you have a problem with the PLASMA gass ( RGB balance failiure )..don't switch it on again run to service center....
causes ;- heavy nonstop use, heavy impacts , can have probs from LG factory , we have nothing to do the only advice is run to a service center...don't try to do it yourself ....
so i identified your prob...PLEASE VOTE ME AS "FIXYA" (Successfully solved) for my help
May 29, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
TV has blue vertical lines and no picture
I have a 42" Electrograph plasma and it has a 2" black vertical line on the left side of the screen.
Aug 02, 2010 | Electrograph Systems DTS4230 42 in. Plasma...
I have a samsung 42 plasma tv with a blue line down left side what is the cause and can it be fixed?
It sounds like a lower right buffer board issue. I recommend having a professional in your area look at it. You are dealing in a very delicate area of a plasma set. If you were to damage the ribbon cable that goes directly to the display, you'll end up buying a new set.
Aug 26, 2009 | Philips 42FD9954 42 in. Plasma HDTV
Blue haze on my plasma screen
I had the same problem, I had to send it back to Philips to get a $900 part replaced. Thankfully I had the warranty with it.
Aug 05, 2008 | Philips 42PF9630A 42 in. Plasma Television
Blue bleed through
Try resetting the television by turning it off and unplugging it for about 30 seconds. Video Game Systems have been known to cause pixel damage on Plasmas.
Feb 19, 2008 | Philips 42PF9631D 42 in. Plasma Television
Blue glow
I have the same issue with my phillips tv. There is a blue ghosting/pixel issue on the left side. It's still under bestbuy's warranty so I am going to call it in for service. It's more visible with hdmi and high resolution inputs. It does take a while to happen. Looks to be a bad screen possibly.
Jan 23, 2008 | Philips 42FD9934 42 in. HD-Ready Plasma...
42" philips plasma flat panel television
same problem anyone know what his is please send me an email. real unhappy!!! this tv cost me $900!!!!! rami7344@bellsouth.net
Oct 22, 2007 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
Philips 42FD9954 42 in. Plasma HDTV Logo
3,731 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
