Question about Samsung RS2534 Side by Side Refrigerator
Ice maker the ice maker will not make ice I have push the reset bottom and the only thing it will do is make the ice tray rotate and stop i also have to push the button again to make it return and the water is not filling up tray Please, Please Help Me!!!!!!!!!!!
  • fred mosley Jan 11, 2008
    i have the same problem....the ice maker will not make ice I have push the reset bottom and the only thing it will do is make the ice tray rotate and stop i also have to push the button again to make it return and the water is not filling up tray Please, Please Help Me!!!!!!!!!!!
  • Anonymous Feb 27, 2008
    Hi, I'm from Italy, I've the same problem too. Don't think it's a long tube issue. I have a pump that take water from a container with pure water.
    The water within the ice container has always worked ok. But suddenly it doesn't work anymore. I don't know how in the past having the same problem I resolved it, but now anyway it doesn't work.
    Any other suggest?
    Thanks
  • 3 Answers
I had the same issue. there was ice built up inside the feed tube. Used a haid dryer to melt it out and it sterted filling again.
Posted on Sep 10, 2008
Water pressure may not be enough.
if ur using a long coiled up water pipe try cuting it short
Posted on Jan 16, 2008
2 Suggested Answers
SOURCE: ice maker not ejecting ice and then tries to fill tray and leaks
The Ice Maker Tray had a small plastic piece break off. This piece aids the tray in bending to dislodge the ice from the tray. Bosch does not just sell the tray, you will have to buy the whole ice maker assembly. You will need to order Part # 0422 from Bosch. I was not very happy about having to spend $112.00 for this whole assembly when all I really needed was a simple ice cube tray.
Save the $112 and remove the ice maker. Buy Ice at the grocery store.
Posted on Jul 24, 2009
Just recently, the ice maker stop dumping the ice cubes from the tray into the bin.
I believe the "tray" is supposed to get heated at end to let the ice release. Faulty "heater connection?" May need repairman diagnostic.
Jan 09, 2018 | Liebherr Refrigerators
I need to thaw the ice that is in my ice maker (Kenmore Elite, 106.56709500), how do I do this? Can I just remove it?
Just get a new ice maker on cheap on ebay since the heating element (for ice removal) on tray will cost more than a new maker!
Aug 25, 2017 | Refrigerators
Whirlpool bottom freezer ice maker will only make ice if I pull and then replace the ice container, why?
The ice maker works off a timer that controls the discharge of ice, water fill, etc. Right before the tray discharges ice it is heated slightly so the ice is just slippery enough to discharge the ice. Unfortunately, now and then (for us) a chunk of ice remains in the tray. This chunk prevents the blades from rotating and eventually you have a mass of new ice with the blades in the wrong position. The blades have to be in a certain position for the heater to kick in. You are stuck with cracking up the ice stuck in the tray to get the blades to rotate again. We have an Electrolux ice maker but this problem occurs periodically. The root of the problem is it's failure to heat up the ice tray adequately to discharge ALL the ice. One thing to remember is that next time this happens you have to manually break up the ice in the tray and push the timer advance button until the 2 set of blades are fully closed (hidden) and at 90 degrees. From that point on at least the ice maker can start making more ice.
Aug 23, 2014 | Refrigerators
Ticking sound from ice maker and no ice?
ice maker heater is bad.fingers have rotated to push out ice ,the mold heater did not heatup.replace ice maker.google model no. for rplacement ......always cheaper online
Apr 10, 2013 | Kenmore 52632 / 52634 / 52639 Side by Side...
We have a Samsung RS2530BBP. The ice maker works ok... water stop coming out... What do I need to do to fix the problem?
My Samsung RS 2530BBP frige Ice maker stop tp make ice.
The water tray stays verticly after pushing the reset button and the water pours in the container instead in the tray. I purchased a new ice maker but it did the same. Any idea how to fix it
Aug 12, 2010 | Samsung RS2530BBP (25 cu ft) Side by Side...
Jenn-Air bottom freezer ice maker not working
I took the arm of the ice-making machine out of the slot and put it back in, pushing it snugly inside the slot, then raised and lowered it several times. Then, with the arm in the up (stop making ice) position, I felt inside the ice-making tray, where I noted there were ice cubes as well as a sheet of ice at the base of the ice-making tray. I poured approximately 24 oz. of hot tap water into the tray to melt the sheet of ice. I turned the freezer temp control to "warmer". I think the freezer temp setting was too cold, causing the ice maker to freeze the water before it could make cubes. I have a working ice maker again!
Cynthia
Sep 07, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Samsung Refrigerator makes ice, but then quits.
I have this same thing happening, also. I have not been able to find a solution to this issue, however. The ejector blades push against the ice, apparently a gear pops loose with a loud clicking sound and the heater either does not work or never turns on. I end up killing the breaker to thr refrig,`removing the icemaker, letting it wrm up dumping the ice and putting it back in.
Aug 21, 2009 | Samsung RF265AA Bottom Freezer French Door...
Amana Side-by-Side Fridge Model SBD21VPSE Problem started when water stopped flowing from in-door dispenser and ice maker stopped making ice. I emptied fridge and freezer, left unit off for several...
If there is a reset button on your ice maker try pushing it. Many ice makers have two holes for reset. A general rule of thumb is if the ice maker fingers are stopped in a slightly vertical position then your ice maker unit is working. If the fingers are stopped anywhere else then it needs some sort of attention or replaced. Make sure there is water, or ice in the ice maker tray, if not then the problem is with water supply.
Nov 29, 2008 | Refrigerators
Ice maker not working
Depending on the ice maker style, they typically work off a motor timer. The timer motor rotates to set up the ice making process... starting with letting water into an empty ice mold tray, allowing ample time for that water to freeze and then to rotate that mold so that the cubes fall out into the bin. In conjunction with that process, a small heater is turned on to release the frozen cubes from the tray. The 'ice tray full' lever signals the system to stop making ice so you may want to verify that the lever is down and not causing the ice maker to stop, If that's down then I suggest you monitor the position of the motor gearset underneath an access cover. With power applied, the gears should rotate and cycle thru an ice making process. If it does and ice fails to fall out, your heater may be defective. Hope that helps...
Jun 22, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
Ice maker cycling but getting stuck
Either you have a bad heating element (soften the ice to eject) or a stripped gear in Ice Maker either way it will have to be replaced by the time you buy the parts and install them you can just replace the ice maker as a unit
May 10, 2008 | Frigidaire FRS23KF7AB Side by Side...
Samsung RS2534 Side by Side Refrigerator Logo
223 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
