Question about Brother MFC 210C All-In-One InkJet Printer
Brother MFC-210 Printer Trouble
I've have functionality problem.  Won't function.  says "Please wait"  been 2 hrs now.
  • Anonymous Feb 06, 2008
    unable to print
I cant print photos the glossy paper keeps jaming i have changed all the settings and still wont work. anyone know what i can do?
Posted on Feb 14, 2008
  • 233 Answers
Unplug for at least 20 minutes, then disconnect all the cables from the printer, plug power cable back in and turn back on
what happens?
look in your manual, is there anything to set back to factory default? if so do this if the first steps don't work
Posted on Jan 04, 2008
I replaced the door seal on a Whirlpool duet ht washer and now it won't power up. I've checked all the connections and they appear to be tight. Any ideas?
I have one idea. Could the new door seal be preventing the latch interlock from functioning to allow the machine to start?
Apr 17, 2013 | Whirlpool Washing Machines
My Garmin Nuvi 660 GPS is Silent. It won't even beep when I push the buttons
Try plugging in a set of headphones. If you hear sound, then your speaker is blown. Please see this link for more info.
http://www.sharc.net/gps_audio_repair.htm
Feb 06, 2013 | Garmin Nuvi 660 GPS Receiver
I've been given a new company Samsung P530 laptop - but none of the function buttons work - I can't change the brightness or adjust the volume, turn on/off wi-fi etc etc. I've just tested all...
Try removing the battery wait for 10 mins insert the battery back into the notebook and boot it up again. If it still does not function properly then it is faulty and it will be under warranty.
Take it back to the supplier for a replacement or warranty repair. If you try to fix it yourself you most likelt void your warranty.
Sep 09, 2011 | Samsung R530 Notebook
Says it requires 24 hrs time to program channels by zipcode 91042. Is this the case??
if you are programming a TV Guide type function yes.
The info is downloaded twice daily, around 2:10 pm EST and 2:10 am EST from your local PBS station.
The TV will wait for that down load before it gives any info in the TV GUIDE.
Apr 12, 2011 | Televison & Video
How do i reset the change oil light on a 1040 cub cadet 1000 series
The Service Monitor meter contains a service minder function that utilizes the 4-digit LCD display. The letters "CHG" will display followed by the letters "OIL" and then followed by the meter accumulated time. "CHG"/"OIL"/TIME will alternate on the display for five(5) minutes after the meter reaches 50 hours. The display will also flash as described above for five(5) minutes every time the tractor has been started during the maintenance time interval. The interval will occur every 50 hours and will be in effect for two(2) hours ( Example: this feature will display from 50-52 hrs., 100-102 hrs., 150-152 hrs etc...). While the LCD is displaying the "CHG"/"OIL"/TIME letters, the red LED "oil symbol" will also be flashing for the entire five(5) minutes. The meter display will return to normal function automatically after the reminder maintenance time interval of two(2) hours.There is no method of manually re-setting this Service Monitor gauge.
Aug 30, 2010 | Cub Cadet Street Sign- tractor lawn riding...
I am charging Remington Shaver FS360 for the first time I have put in charge for almost 12 hrs (the instruction is to charge it for 24 hrs at the first time) but still the charge led is not glwoing. I am...
Wait the full 24 hours then try using the shaver. If it functions normally, then I would say only the charger light is not working. If the shaver runs down before the end of the 2nd shave, then you may have a defective charger and/or shaver. In that case, take it back where you bought it for a replacement.
Jan 06, 2018 | Vacuums
KEEPS TURNING OFF AND THEN HAVE TO POWER UP AND WAIT. WNAT IT ON ALL THE TIME.
you need to go into the additional functions setting and change the power save setting to 4 hrs... it won't shut of and go into power save mode unless it hasn't been used for 4 hrs strait. i don't belive there is a way to turn the power save mode off completly that is the best you can do.
Jun 21, 2010 | Canon imageRUNNER 5000 Copier
Hi, i just bough an automatic watch with a Sellita sw200, is 2 (Two) seconds to fast in 27 - 30 hrs consider ok? I fully hand winded and let it sit for that period of time it is stil functioning after the...
This deviation is perfectly acceptable. Even a certified chronometer may deviate -4 to +6 seconds per 24 hour period so you should be pleased with +2 seconds.
It is highly unlikely that any exchange will fair better. Also, the deviation will depend on the position of the watch. So, if you wear it, you will know its average deviation much better.
Dec 14, 2009 | Ebel 1911 1087221 wristwatch
I insert a disc. It loads, then either 1 or 2 shows in the display, but nothing functions and the disc will not play. It is a region 2 disc I tried
\usually when a disc won`t play ,it just displays "No Disc".
Is the disc matching the dvd code?
Is the region code correct?
Have you checked what discs the dvd will play, in front of manual.
If those are ok the dvd must have condensation in it.
Place in a warm room,turn on and leave for 2-3 hrs
Then try again fingers crossed for you.
Dec 03, 2009 | Toshiba SD-3800 DVD Player
Put disc in recorder says no disc why gary
usually when it says "no disc" is when condensation will form on the circuit boards.
Best thing to do is bring it into a warm room, plug it in and turn and wait 2 hrs roughly then see if it functions.
Nov 09, 2009 | LG RH1999H DVD Recorder/HDD Recorder
Brother MFC 210C All-In-One InkJet Printer Logo
120 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
