RCA HD52W58 52
Rca r52wh74 projection 52" tv
shared by 6 users
posted by pamz on Jan 04, 2008
convergence problem
Comment posted on Jan 04, 2008
what was the 9.99 for?
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
5 Other Users Have The Same Problem
Posted by Guest on Nov 16, 2008
Convergence problem.
Posted by Guest on Aug 31, 2008
i checked the fuse and it looks ok the little wire in side looks ok not burnt or seperated, anything else?
Posted by tonyharwood on Aug 16, 2008
my problem is the same please help
Posted by janiejanie on Jan 25, 2008
I have the same Tv. The auto convergence menu starts but doesnt finish and there is a big black in the middle of the screen when doing this, The colors on the plus are sideways a little when trying trying the red and blue convergence. When not in menu, there are three colors half way down and black above so half the picture is cut off. Is this the convergence board or ajustment of some kind?
Posted by tif813 on Jan 21, 2008
I have an RCA R52WH74 tv. One of my kids hit it, now the picture is slightly bowed and the convergence is off. The manual says you can access the auto convergence in the setup tab under the main menu. When I select setup, auto convergence is not in the list. When I initially bought the set and plugged it in, it went through an initial setup. At the end it checked the convergence and it could be adjusted. I cannot get back to this initial setup mode again, even after leaving set unplugged overnight.
Best Solution
posted on Jan 18, 2008
FixYa! (100)
willtab
Rank:Guru Guru
Rating: 89%, 508 votes
Convergence in this unit can be one of 3 possible boards. can you adjust any ...do the crosshairs move in customer setup convergence menu
Comment posted on Aug 30, 2008
convergence is a very common complant in this set. and can indicate one of 3 boards. the first question is always is the convergence option in setup menu. if it is this means you have a very common problem known as Fl231 fuse. I repair alot of these at the shop it is a simple fast inexpensive repair. if you know how to solder. faulty solder connection causes vibrations in this very small fuse and blows it you have to put some more solder on the flyback transformer joints when you replace this fuse
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on rca r52wh74 projection 52" tv:
I don't want to Accept this solution
Best Solution
posted on Aug 31, 2008
FixYa! (100)
tonyharwood
Rank:Apprentice Apprentice
Rating: 100%, 1 votes
that fuse is ok ichecked it and the little wire inside is still there
Comment posted on Aug 31, 2008
i check that fuse and it looks ok theres nothing burnt and the little wire in side is still there and not seperated, also i checked the soder on the flyback and they seem to be ok too, please help
Thank You!
Solution #3
posted on Nov 21, 2008
Not Rated (0)
DFan
Rating: 0%, 0 votes
Hi:
I have the same RCA (R52WH74) on a ITC222 chassis.
Same convergence problem (RGB color separation on image - lost convergence option on Setup manual). Sucks because mine is 2 month out of warranty and RCA is not helpful.
There is a site where I am getting excellent help and the also have the parts.
http://servicemanuals.vstore.ca
I would suggest that you go there and email Sonny for assistance.
Good luck.
Dominic
Thank You!
Solution #4
posted on Oct 12, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
500ma fuse open located by flyback and mosfet part #stf3hnk90z bad on convergence power supply board rca hd61w66 no convergence
Thank You!
Can you Help with these Standard Televisions problems?
RCA HD52W58 52" TV
My RCA 52" tv turns off by itself and won't turn back...
RCA HD52W58 52" TV
the power button turns the tv on and then it turns it off....
RCA HD52W58 52" TV
We were changing the colors around one day because it...
RCA HD52W58 52" TV
Some how the zoom got turned of and I can not figure out...
RCA HD52W58 52" TV
Do not know how it got this way and I can not find my...
Loading problems.
Repair Service
Find Standard TV Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Home Media Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
