Question about Mitsubishi WS-65869 65" Rear Projection Television
Mitsubishi WS-65905 DTV is green
Plugged in new HD cable box into the DTV inputs, but all I get is a green washed screen. Looks like old B/W image with a green overlay. Image seems clear, but no real colors except the green. Played with the color control settings, but no real help there. Driver board for DTV bad? Other inputs (inputs 1, 2, 3) all work fine with normal color. Only DTV inputs give the green screen. NO HELP from Mitsubishi, since they don't support anything prior to 2002.
Bob
  • 2 more comments
  • rfrysztak Jan 04, 2008
    Nothing but top of the line Monster Cables connecting the equipment, so
    it is NOT a problem with inferior cables, etc. Same thing happens
    with my son's XBox connection to the DTV. So it must be something
    in the set.
  • patsycline Nov 22, 2008
    I have a Mitsubishi WS-65905 TV and DirecTv says we need to switch out
    our existing HD receiver to a new one that they provide because they
    are switching to a different system.
    Problem is, the tech guy they sent out 3 times can't figure out how do
    accomplish this. Everything that he has done results in a very nice
    picture, except that everything is tinted GREEN!
    Does anybody know what the problem might be and how we can fix it? If
    we don't, we won't be able to get any HD programming at all.
    Thank you for any help.
  • Anonymous Dec 03, 2008
    Mitsubishi WS-65969 "Famous Green blinking light" I move the TV to make room for the Christmas Tree - now the TV will not come on - I have the green blinking light!!! I called a technician and he quote $400 to $500 to repair. I bought the TV in 2003 and paid $4200 - after reading the other quotes I will not get it fixed.
  • jason May 11, 2010
    do you have the format setting set on box and tv ?
  • 979 Answers
A compatibility issue rears its ugly head. The format that was to be back then has changed slightly over the years and this is what it's come to...Sorry...accordianman
Posted on Feb 27, 2008
Cable box connections
The model listed has only ONE HD input and it is on the rear and marked DTV--it is a component input with red, green, blue and a red and white for audio---cable box would have to have same outputs on its rear.
Apr 18, 2012 | Mitsubishi WS-48313 48" Rear Projection...
How do i get 1080i, my tv shows im only in 480i. i think i might have it hooked up incorrect. my other tv of another brand is much newer so all i did was connect the hdmi cable from the tv to the cable box...
Hello
Your TV will display all High Definition signals as 1080i True HDTV™ and all standard definition signals will be displayed as 480p.
Component Inputs 1-2
YPbPr(480i/480p/1080i)
These inputs can be used for the connection of A/V equipment with component video outputs, such as a DVD player or external HDTV receiver. Please see Appendix B for signal compatibility.
Input DTV (480i/480p/1080i)
This input is used to connect an external DTV receiver, and can be configured for YPrPb and RGB plus H&V signal types.
As a special feature, you have the ability to adjust the red and blue light beams in reference to the fixed green light beam. This process is called convergence. There are two separate memories for convergence. One, for SD 480i/480p signals; the other for HD 1080i signals. SD convergence should be adjusted while watching an SD source and HD convergence should be adjusted while watching an HD source.
Wide Expand: Enlarges the picture, cropping some of the image on both sides. This Expand format is useful to remove or reduce black side bars on HD broadcasts of 4:3 images with black bars. Available for analog 1080i, digital SD 16:9 and digital HD signals.
InputDTV
This input is compatible with most standard DTV and satellite receivers with component video (YPbPr) outputs. Compatible DTV signals are SDTV 480i/480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Please check the DTV receiver specifications before connecting.
This input is compatible with some DTV receivers using RGB with "separate H and V sync". Compatible DTV signals are SDTV 480i, 480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Industry standards for DTV RGB signals (systems, synchronization, timing, and signal strengths) are not currently established. These inputs will not be compatible with all DTV receivers that offer RGB, HV outputs. RGB, HV signals with less than 5 cables are not compatible.
If your DTV receiver offers both DTV component video signals and DTV RGB, HV signals, we suggest you use the DTV component video signals. Check the DTV receiver specifications before connecting.
Ok.
Feb 05, 2011 | Mitsubishi WS-73909 73" Rear Projection...
Mitsubishi WS-65907 rear projection TV HD goes blue.
I would look at the source for the Hd signal as being the problem--if you are using some kind of cable or sat box it will deliver the signal to the DTV input on the back of the set--this is the HD input for this set.
It is possible to have a problem like you describe be one in the set--but very unlikely----have you looked on that green signal board for any signs of Glycol?
Anything that will produce a 1080 signal to the DTV input should tell you if the problem is the set or the source of the HD signal that is causing the problem.
If you have questions or need advice let me know--I am here to help people.
if this information has helped you rate this solution as i do this here for free.
SD TECH
Dec 05, 2009 | Mitsubishi WS-65907 65" Rear Projection...
Blue screen with dtv input and HD channels
the left large button controls a dozen different ways your set is hooked up,easest is get the monolink cord at any store will need a dvi hdmi.if not keep rolling the left large button,if you have a blue screen on all your inputs ,There has to a man around to plug in the right cord.
Jan 28, 2009 | Mitsubishi WS-55807 TV
TV Picture is green
is your RGB cables are the same output from your tv...are you connecting from where dvd cable box sattelite box, if you are connecting from a box exs output of cable box is what colour are you using? for your your output to your tv and what input are you using of your tv set.[input 1is it video input 1,] or comp? let me know...
Jan 10, 2009 | Televison & Video
HDTV comes up green
there is a setting in the menu under setup i believe it is called "LABEL VIDEO INPUTS". check you owners manual. you need to make sure that the DTV input is set to YPbPr NOT RGB.
Feb 23, 2008 | Mitsubishi WS-55907 55" Rear Projection...
Mitsubishi WS-55857 55 in connection problem
Feb 22, 2008 | Mitsubishi WS-55857 55" Rear Projection...
Mitsubishi WS-65711 green tint only with DVD via Component
there should be a setting in the menu that you need to make sure is set to YpPbPr not RGB if set to RGB it will give you a green pic on the DTV Input.
Jan 03, 2008 | Mitsubishi WS-65711 65" Rear Projection...
Open Questions:
See all Mitsubishi WS-65869 65" Rear Projection Television Questions
Mitsubishi WS-65869 65" Rear Projection Television Logo
160 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
