Question about Palm TX Handheld
Trouble syncronizing palm TX
Although it tells me that synchronization is complete, there is no information showing on my desktop.
  • 59 Answers
If you look on your handheld, tap the Hotsync icon once.
This will tell you the last time your Palm was synced.
Also if you hold your mouse over the Hotsync icon on your computer in the bottom right hand corner, this will tell you a last Hot sync date.
See if the two dates/times match up.
You can do a search on your computer for a "hotsynclog" file, this will give you a detailed list of all the processes that occurred during your sync. I would see if there are any errors listed there.
Also, you may want to make sure the Palm names match up with what you have on your Palm and the computer. When you click Hotsync on the Palm once, a name should appear in the upper right-hand corner. This name should also appear in the upper right-hand side when you upen Palm Desktop. There will be a white box with a name showing and an arrow pointing downwards. Make sure the two are the same as well and see if your information appears then.
Posted on Jan 04, 2008
Books on Palm TX
I would be happy to help you in finding resources for this issue. There are many places to get ebooks from and based on now much memory you have on your device will tell me how many books I can help you put on there.
As far as the battery is concerned I can help in finding a replacement.
Thanks Frank Z.
3868607368
http://www.attechcomputers.co.cc
Jun 24, 2009 | Palm TX Handheld
By typing hot Sync my palm makes a restart
Try this, uninstall your current version of Palm Desktop, then go to this link on the Palm support website http://kb.palm.com/wps/portal/kb/na/tungsten/tx/unlocked/home/page_en.html this will give you the link to the download for the TX version of Palm Desktop, this may or may not fix your particular problem but it is worth a try.
Mar 24, 2009 | Palm TX Handheld
Trying to hotsync my desktop and my 755, and I use Outlook.
if using verizon go into the wireless sync application and select settings> connection> advanced settings> and select enable other sync apps.
Apr 07, 2008 | Palm Treo 755p Smartphone
Synchronizing Tungsten T3 with desktop or laptop
I recently re-installed my T3 program
What do you mean?
  • Did you restore your T3 from a backup on the PC?
  • Did you install programs on the T3 using the PC's "quick install"?
Is Palm Desktop showing the correct Contact/To-do/Calendar Data?
How are the conduits set up? (From Palm Desktop, select Hotsync->Custom)
Nov 15, 2007 | Palm Tungsten T3 Handheld
Outlook not synching
This is how I got it working. Don't use wireless sync software, someting is definitely buggy with it. Here is what I did to resolve sync errors: 1. Perform a hard reset on the Palm 2. Go to the Palmone folder on your hard drive (C:\Program Files|PalmOne. Look for the Backup folder. Rename this folder Backup Old. 3. Connect the Treo to your computer. 4. Right click the Hotsync icon in the taskbar and click Custom. Change the four Outlook conduits (Calendar, Contacts,Tasks,Memos) to Desktop overwrites Handheld. 5. Run a Hotsync with the Treo. It should sync without errors. If you need to install additional applications you can add them now
Sep 12, 2005 | Palm Tungsten E2 Handheld
Switch from outlook to palm desktop
Remember to change (HotSync, Custom) settings before you perform your sync or else you will get duplicate records as I did. Good luck. Support Knowledge Library Click here to go back Click here to print Solution ID: 25263 Switching between Outlook and Palm Desktop synchronization Depending on your device, you might be synchronizing with Outlook using the Palm™ Outlook Conduits, or PocketMirror conduits from Chapura (find out which). Both of these types of conduits are installed and activated when you run the CD-ROM that came with your device. What do you want to learn about? * Switching synchronization: Palm Outlook Conduits * Switching synchronization: PocketMirror Conduits * Synchronizing partially with Palm Desktop, partially with Outlook * Note about data transfer * Macintosh information * Multiple users on the same desktop computer Switching synchronization: Palm Outlook Conduits These instructions apply to the Palm Outlook Conduits that are included with handhelds released after late 2003. The Palm Desktop installer determines which conduits are activated during the installation process. If you want to switch synchronization from Palm Desktop to Outlook, or vice versa, you'll need the original CD-ROM that came with your handheld. 1. Insert the CD-ROM into your computer. A window should open, containing the contents of the CD-ROM. 2. From the Discover Your Handheld screen, select "Install Microsoft Outlook Conduits" or "Change synchronization method" (depending on which device you have) 3. Follow the instructions for switching synchroniztion from or to Palm Desktop or Outlook. 4. See our note about data transfer Remember: Some applications will continue to synchronize with Palm Desktop. Use Palm Desktop to manage applications such as Photos and VoiceMemo
Sep 12, 2005 | Palm Tungsten T5 - Multilingual Handheld
How Do I hotsync w/Outlook
what software did you download for your outlook conduits? the installation cd already has the outlook conduits you need.. you just have to install palm desktop first then you'll be given options whether to sync your handheld with palm desktop or with outlook. choose sync with outlook
Sep 11, 2005 | Palm Treo 650 Handheld
Synch question
If you have PocketMirror from Chapura (included with certain Palm handhelds), you can choose to install conduits that synchronize MS Outlook with the handheld applications Date Book, Address Book, To Do List, and Memo Pad. You can choose to synchronize these applications with either Palm Desktop or Microsoft Outlook, but not both. If you want to synchronize with Microsoft Outlook, DO NOT install Palm Desktop from the Web. Instead, run the Palm Desktop installer from the CD that came with your handheld and select the option "Synchronize with Microsoft Outlook" when the choice appears. Visit www.PocketMirror.com for more information about Chapura(R) PocketMirror.
Sep 07, 2005 | Palm Tungsten T5 - Multilingual Handheld
Palm TX Handheld Logo
75 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
