Question about XFX GeForce 6200 Graphic Card
Blank monitor after graphics card is installed
My monitor will not boot up after I install my new graphics card. I have been trying for hours to fix the problem. I disabled the other drivers through device manager, as I could not find it in BIOS. I havent yet checked to update the BIOS with the manufacturer. I 'm all googled out. HELP PLEASE!!! I previously had a onboard graphic. I have a nvidia geforce 7300gs card. It should be compatible with my mobo, as
    Problem Solver:
  • 7 Answers
I just installed a geforce 6200 with heatsink, no fan, in my computer. Fry's is having a sale and for $20 after rebate, how could I go wrong? Upon first installation, the computer failed to boot.
THE FIX
Discovered modern computers will not even atempt to boot if the power supply is below the minimum requirement for the video card's recommended wattage. More proof that over-powered supplies are not an absolute necessity. I upgraded to 250w from the onboard 180w and it fired up. The rest was disabling the integrated video which i found out was compatible with geforce 5200 level of operations.
My system:
Dell Opti-plex GX260, cut to bare minimum since it was from a commercial business with 1G RAM after upgrade.
Posted on May 24, 2008
    Sergeant:
    Champion:
  • 243 Answers
What motherboard do you have?
There will be somewhere in the bios to select which display device to use first.
Posted on Jan 04, 2008
MSI Video Adapter Cause Blank Monitor
From a cold boot- go into safe-mode. Install the drivers for the MSI video card and do a warm boot.
Mar 07, 2014 | MSI Computers & Internet
New display detected vista
Boot-up in safe mode; add the MSI video drivers and re-boot normally
Compaq Presario SR1750NX wouldnt come on, installed dynex 400 watt atx power supply now it comes on & fan runs but monitor is still blank. Installed ATI RADEON 7000 GRAPHICS CARD, still nothing, the...
After adding new graphics card monitor display will not work with motherboard display connector.
So, connect your monitor VGA cable with your graphics card display port.
Thanks for using FixYa.
May 22, 2011 | Computers & Internet
Blank monitor after installing new video card
One thing you can try is to go into the Bios and load the default Bios settings. Sometimes that helps in reassigning interrupts and I/O addresses with new hardware.
May 11, 2009 | Dell Precision 380n (380TNMIN) PC Desktop
I installed the ATI x1650 but the monitor is blank when I turn on
Yes the card does support the screen. If you have blank screen right from turn on, chack that you have not plugged the monitor into the onboard graphics port instead of your Radeon. If you have plugged it into the right port then you have hardware problems. Could be any of the following:
1. Monitior
2. Video Card
3. System memory
4. Motherboard
5. Powersupply
6. CPU
Try a different monitor and get back to me if you want troubleshooting tips.
Cheers
May 09, 2009 | ATI RADEON X1650 Graphic Card
Blank screen after boot up
Remove the card, plug into your built-in card. Start your PC in safe mode. Uninstall all ATI software and delete the card from Device Manager. Restart. Reinstall the ATI drivers. Power down. Install the card and connect your monitor to it. The OS will find the card in default mode - let it. Restart. When it comes back up, you will be able to select the full range of operating modes.
BACK UP :)
May 03, 2009 | ATI RADEON HD 2400 PRO Graphic Card
Blank Monitor
I have the same system and card. The problem is the system is trying to run two monitors at once. Use Windows safe mode (F8 during boot) to uninstall any Pny drivers you may have put on. Reboot. Install the pny drivers again. Before rebooting, use the device manager to look at the display drivers. There should be two, an Intel one, and the pny Nvidia one. Disable the intel driver and reboot. Worked for me. Youmay also want to upgrade the power supply. The 3000 has a 225W and the 8400 card wants at least 300W.
Mar 28, 2009 | Computers & Internet
Radeon X1650
before doing anything.. What do you mean you get no blank monitor? Do you see anything at all? Do you see the POST running? Also, when you put in the AGP, did you plug your monitor into the new card? Or are you trying to boot from the old intergrated one?
You can change your graphics input in the BIOS from integrated to AGP (after putting in the new card). But, It should pick it up fine without changing it. And if it doesn't work after doing so, your motherboard may keep the settings, and then a deeper problem arises..
Apr 16, 2008 | Sapphire RADEON X1950Pro 512MB Graphic...
Blank Monitor
hey maby the onboard van on it dont work well with yoru pci slow ok so unplug the onbord fan try again ok
Jan 21, 2008 | PNY Verto GeForce FX 5200, Graphic Card
Installing AGP video card
Don't boot with the monitor connected to the card. You need to let it boot into windows and install the drivers for it first. Once you do that,shutdown and restart with the monitor plugged into it and it should work.
Sep 13, 2007 | Sis 6326, (4 MB) Graphic Card
XFX GeForce 6200 Graphic Card Logo
256 people viewed this question
Top XFX Computers & Internet Experts
David
David
Alun Cox
KG John Justin
KG John Justin
Are you a XFX Computer and Internet Expert? Answer questions, earn points and help others
