Question about RCA 27F634T TV
Turns on and off by itself repeatedly
My RCA 27F634T TV will turn it's self on and off. We will start with it being unplugged. Say I plug in the set, turn it on. It might stay on for an hour or maybe only 15 minutes, the time varies dramatically. The tv also turns it’s self off. I have both the wake up and sleep timers turned off. There are times when the tv will stay off or on for maybe up to an hour, and other times it will constantly turn it’s self on and off. We have another rca tv that uses the same program on the remote. If you put both tv’s side by side, the problem still occurs. This I feel should eliminate the thought of outside signals. We have also put the tv in the basement and it still occurs. Any help will be appreciated Oh yeah, anyone having a wiring diagram would be nice. thanx a bunch
  • 1 more comment
  • JohnForJC Aug 08, 2008
    Duplicate problem, turns itself on and of repeatedly at random.
  • Anonymous Oct 27, 2008
    I am having the same problem
  • DuncanRoo Jan 05, 2009
    Same problem, two RCAs one 32V432T (YX5) - other one is yet to be determined. The listed model has degraded to the point of turning on and off with 1-20 sec delay repeatedly. Other has only exhibited this problem on occasion and operates fine otherwise.
Hello
Did i find the problem? Well yes, sort of. Knowing a little about electronics, my troubleshooting led me to beleive it was the sensor that receives the signal. The other thing i thought it might be was the plastic that pushes on the buttons. I eleminated this by removing the parts. As for the sensor, i couldn't find a part number and the best i came up with was to purchase a schematic for $40.00 I figured it was a five dollar part. With this all in mind, and not knowing for 100% sure it was the part, I called around and found a place that gave free estimates. I figured if i was correct, the fix would be $100.00. Sadly i was correct on all counts. But what could i do, I couldn't find the part number and it wasn't on the part. The repair guy said this was very common on the RCA"s If you are still interested, i could see if i could find the receipt, and see if the part number is on it. It is an easy fix if you are at all handy with a solder iron. Give me a yell if you want me to look jr@excel.net jeff
Posted on Jun 14, 2008
Hi..i have the exact same problem. Did you find a solution for this? Please let me know.
Thanks,
Srikanth
Rca F35720SB makes popping noise then shuts off
It may be arching from the flyback. If you are familiar with tv's remove the plastic case plug it in and turn it on and see if you can see anything visual happening. Make sure not to touch anything and keep a safe distance when inspecting.
Oct 30, 2012 | RCA 27F634T TV
Tv turns itself off
do the self test the set has.
when green light (power) comes on and then goes off, press and hold BOTH the Menu and Input buttons for at least 5 seconds and release both buttons on the front of the set.
The power light will display a error code: for example 2 blinks, a pause and 2 blinks (this is the most common one) and it will repeat the code about 5 times.
To get it to repeat it you have to unplug set, plug it back in and turn it one and when it fails repeat the check.
Let me know what error code you find and I will tell you what may be wrong. I hope it is 2,2 as it is the least difficult to resolve.
SD TECH
Jun 16, 2010 | Mitsubishi WS-55809 55" Rear Projection...
RCA model 27F634T
on that one ive had the button board causing problem--remove board--spray wd40 on buttons--push buttons a few times--wipe off bwd--reinstall bwd
Sep 16, 2009 | RCA 27F634T TV
Problem with RCA TV Model 27F634T
You almost certainly have a bad picture tube. The green screen was from one of the elements inside shorting out. The static sound you're hearing is the high voltage arcing out through the end of the picture tube to other parts inside the set. It's more economical to buy a new TV than to repair this one.
Sorry to have such good news, but this is one of the ways a picture tube can go bad, and it happens quite often.
Mar 11, 2009 | RCA 27F634T TV
TV TURNS ON BY IT SELF AND CHANGES CHANNELS AND FPA LOCK IS ON
the problem is there is engaged button there..only technician can do the job by replacing the button that is always engage.
Oct 22, 2008 | RCA 20F420T 20" TV
RCA 27F634T
Have you tried to access the menu features and tried to retune the stations on digital, or are you hooked up for analog.
If you don't know about what i speak, give me a yell. jr@excel.net I believe my remote sensor card is bad. While this might explain why you can't turn yours off, it would not explain the blank picture. If the menu does show, i would think the picture tube is O.K. if the menu does not show, there are some other things to look at.
Dec 29, 2007 | RCA 27F634T TV
Rca f27450 TV
It sound like your set have dryjoints
Oct 11, 2007 | RCA 32F531T 32" TV
TV turns on and off by itself
you need change memory ic 24C08 near microprosessor.
Oct 10, 2007 | RCA 27F530T 27" TV
RCA 60" projection tv Turns on and starts flipping channels by it self
replace the keyboard or remove the switches for channel up/down to see which one is bad. if neither does it, there are some components around the microprocessor that can cause this.
Jul 27, 2007 | RCA P60921 60" Rear Projection Television
RCA 27F634T TV Logo
220 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
