H4, not heating up, replace fuser unit complete or work with hivolts and replace an expensive and tricky lamp/thermister . wont be cheap.
. Here use the reset for it first, sometimes power surges can just flip them out but most times will just reappear shortly after reset, indicating the want of a working fuser assembly
Fuser (not fuse) is the hot bit with rollers at paper exit if code fails it needs to be replaced, wont come cheap no matter how you approach it
C-Exposure key-C-Exposure key-14-copy key to clear ... but it will come back I bet...
The cooling fan goes bad and generates false signals. Replace the fan if everything else checks good. It may also cause intermittent power failures "machine goes dead"
I have an older Xerox 5614 black and white copier. Copies keep coming out dark. I have changed...
(More)
I have an older Xerox 5614 black and white copier. Copies keep coming out dark. I have changed toner, copy cartridge, and cleaned mirrors and glass. Any suggestions on what my problem might be?
