Question about ASUS M2N-E SLi Motherboard
The right fan/heat sink
Will a nexus AXM-8200 heat sink/fan install on a Asus M2Nsli mobo retention module with out any modification, I mean will it stick and click, all done.
Thank you, for your time and help.
Will
    Master:
  • 619 Answers
You need a heat sink grease /to stable coolness of the proccessor, available computer near you/ if not available try visit/
AlfaAdhesive.com
Posted on Jan 05, 2008
Update... i have it working now... new fan, 4450 Rpm and due to some testing when pressure was added to the heatsink the temp went down dramaticly, so i add some new sink clips and its now at a stead 70 -...
50c is par.
at 90c the intel chip , (or amd) shuts it self down, all by itself.
so 80c is no good. its too near 90c. see?
my guess that is the Asus bios temp reporting, like mine does.
The CPU runs hot, some up to 100watts of heat, ever touch a 100watt light bulb? burns fingers, there you see what hot means.
the fan must blow well, yours seems to.
the correct matching heat sink ,matched to your heat rating of your unstated CPU is next, why not buy a max sized heatsink fan assembly and end this.? do not use 20w CPU fan-hs on 100w CPU. ever.
then use real heatsink compounds not that $1 junk sold on fleabay.(China cloned crapp, endless )
next is airflow in the PC case.
now photos by you of mobo in a case, or in toaster mom chucked.
haha..... but sure i cant see your PC, can I and matters , in the world of thermodynamics.
Air flow from, the front of the PC to the rear must happen!
case temps inside must be kept below 30c, so the Heat sink can even work at all.(and its fan)
this grease is best from JAPAN. no hype , it's commercial grade.
http://www.pcdied.com/Filth101/html/image_12.html
Mar 03, 2018 | HP Asus Motherboard P4SD-LA Socket 478...
Need to find a new alum&copper heatsink and fan combo
This is a standard micro atx board. The holes you are seeing will be on any 478 mobo, you just have to remove the black bracket, which is usually achieved by lifting the center pin in each of the corners.
Sep 02, 2009 | HP COMPAQ BUSINESS DESKTOP DC5000 SFF - 1...
I have a pc w/ asus k8v-mx mobo, the problem is it
scan for virus, if it is not a virus change the power supply unit.
Aug 14, 2009 | ASUS K8V-MX Motherboard
Cpu fan runs at high speed all the time
the problem is that the mother board you are now using has a 4th wire that sences cpu temp this allow the heat sink fan to change speed to get this to work correctly you will need to replace the fan with a 4 wire style. what is happening is your not getting a temp siginal back to motherboard so the fan controller think it hot and send full power to fan alll the time the stock fan in hp systems is not very good any way .Get a good heat sink and fan to fit your new board ebay has them very cheap 5.00 to 20.00 this will all so increase you system temp and all get the proper cooling when you really need it.
Jun 10, 2009 | ASUS M3A78-CM AMD 780V AM2+ Phenom FX /...
Pentium D problem
Hi oilian,
Be glad it did shut down. If it didn't, your new CPU could haveover heated. There are a few reasons for a CPU to over heat.
1.) There is no thermal grease or too little on the heat-sink assembly.
2.) The old thermal grease was not removed or the old thermal tape was not removed.
3.) The heat-sink assembly was not cleaned completely with alcohol before applying new thermal grease.
4.) The CPU fan is running too slowly.
5.) The heat-sink fins are possibly filled with dust build-up & the CPU fan can not cool the heat-sink assembly. Boot to the bios & go to Hardware Monitor. There you can check voltage, CPU fan speed, CPU temp & other bios monitored settings.
Good luck oilian!
Mike
Oct 01, 2008 | ASUS P5GC-MX/1333 - Motherboard - micro...
Mobo temp readings?
Have U checked the thermal paste under the heat sink and the graphic controller (integrated one)
Sep 24, 2008 | ASUS A7N8X Motherboard
K8S-LA mobo heat sink fell off.
That is the 'Northbridge' chip that provides the I/O interfacing for the main chip. The heat sink is normally held on with glue as you surmised, and should be re-done with a thermal conductive glue. The glue (a silver filled epoxy) is available from MCM electronics or from Mouser. Be sure to thoroughly clean the chip and heat sink before re-gluing.
Sep 01, 2008 | ASUS K8S-MX SIS 760GX CHIPSET SERIAL...
Dimension 8200 Upgrade Heat Sink Problem
you can contact online for techsupport at dell at www.support.dell.com this a live tech support session totally free they have helped me out numerous times keep me posted on how this goes ok best regards mike
Aug 12, 2008 | Dell Dimension 8200 PC Desktop
ASUS M2N-E SLi Motherboard Logo
56 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
