-   Same problem. I'm running Vista. Pen buttons work, but cursor won't move unless the setup dialog box is open to the pressure test tab.-   Guest
Dec 10, 2008
-   Same here. Also, the Hot Cells don't work anymore (they did the firstcouple of times). Oh, and some programs don't detect pressure levels(again, they did the first time), like ZBrush, but others (likePhotoshop) work fine. I came up with the same solution sbnunez: it getsthe tablet working, but it won't solve the Hot Cells and pressureissues.
-   dugerstein
Oct 08, 2008
-   It worked perfectly for a month, and now it will not work when trying to use then pen as a mouse. It will work fine however in drawing programs, just not as a mouse on the desktop or web browser. Which it did work perfectly for when i bought it new.
-   same problem here, mouse works on the tablet but pen does not, they work on other machines. just don't work on my desktop windows xp.
rebooted, reloaded soft ware over, over-   carnalgadfly
ok i had the same problem BUT i opened the mouse pen control panel and under info i unchecked the "support tablet PC feature" and to my amazement it worked. hope it works for you :)
1. Remove any genius drivers you may have. 2. Install driver 3.something (the one on the disc you get with the tablet). 3. Reboot 4. Download driver 5.something (from geniasnet. cam) and install. 5. Reboot 6. Pen should world fine now.
Same problem. The only way I could get it to work was to open up the mouse pen control panel and click the Pressure tab. After that it works fine. The mouse pen control panel will just need to be in the background. Kinda sucks, but usable until a better solution comes along.
my software that came with the mousepen 8x6 won't install upon putting it in my floppy drive. ...
(More)
my software that came with the mousepen 8x6 won't install upon putting it in my floppy drive. What's up?
I download the driver form genios web site, but it dosent istal.... look like windows do not...
(More)
I download the driver form genios web site, but it dosent istal.... look like windows do not regonize the file or some like that...
My Genius 8X6 Tablet Pen does not give off any sensitivity.. it is very annoying because I am an...
(More)
My Genius 8X6 Tablet Pen does not give off any sensitivity.. it is very annoying because I am an artist and I really need sensitivity. It used to work but it stopped about 1-2 weeks after I bought it. Help? p.s. The green light does not flash on the tablet and my computer did not recognize it as a tablet, but a mouse. Very annoying.
I just started having the same problem the other day. I got my tablet
less than 2 weeks ago and I really wish I could find a solution to the
problem already.
Comment by Guest, posted on Jan 08, 2008
I just got mine too, and at first it worked just fine but now it won't respond to the pen like before. It won't move across the screen anymore unless I click one of the barrel buttons, in which case it jumps to where it would have been. I don't know how to check the battery though, how do you get inside the pen?
