Question about Kenmore 22422 Top Load Washer
Squeaking Washer Kenmore 90 Series Heavy Duty - it squeaks loudly during the rinse and spin cycles, like it needed a squirt of some lubrication - any ideas?
  • Anonymous Mar 09, 2008
    kenmore series 90 squeaks when washing only
  • Anonymous Mar 12, 2014
    It hums or squeaks in the spin cycle
    President:
  • 1,314 Answers
Did you remove the shipping pins pins when you installed it
Posted on Jan 04, 2008
Series 90 with loud buzzing/grinding noise, won't spin
It could have gone out of balance. See if the drum looks off center and center it if necessary. Turn it off and back on to reset the switch. If that doesn't work, try pressing on the lid either 2/3 of the way back on the right or all the way back on the left (depends on the model -- try both) and see if it starts. If it does, I would suspect the lid switch.
Jul 21, 2010 | Kenmore Washing Machines
Squeaking washing Machine during spin cycle
Hi
Loks that your machine is pretty old and hence the belt has hardened making a squeaking noise.
Good fix is get a new drive belt.
OR
Quick fix is you could put some oil on the drive belt..... it will work for now but not a permenant solution.
Regards
Berry
Feb 01, 2010 | Kenmore Washing Machines
Kenmore 70 series
hello mam for two years you have not used the washer so the bearings may worned out so lubricate the bearings and check the belt should not have any cracks on it,and after lubricating run the machine without loading clothes the observe the noise if seems to be same then change the bearing to change the bearing call the engineer.
Sep 29, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 Series Heavy Duty Washer - Agitator doesnt spin
THIS IS A TYPICLE PROBLEM . BETWEEN THE MOTOR & THE TRANSMISSION THERE IS A COLLECTOR ASSEMBY (THREE PIECE
SET) REAL EASY TO GET TOO EASY TO FIX . ALSO COST EFFICENT
Sep 21, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 series with speed selector switch set to heavy duty cycle it works fine any other setting , regular , hand wash setting the agitator makes a loud clicking sound as it agitates
sounds like a transmition problem. does the noise happen when it goes into spin on the other settings? If no noise in the spin cycle on the other setting, then it sounds like a the gears in the transmition internally when bad for the agitation.
Jul 30, 2009 | Kenmore 15864/15862 Top Load Washer
Kenmore 90 series loud whirring/howling noise during spin cycle
Sounds like you have a broken motor coupler. They are inexpensive. Can be a little tough to replace but I can walk you through it. You can purchase a coupler here.
http://www.shop.washermd.com/product.sc?categoryId=1&productId=1
Dave
Dec 18, 2008 | GE WBSR3140DW Top Load Washer
Squeaking/grinding/rattle noise during wash and spin
That sounds like a clutch problem - probably just worn and need replacement. Will definitely need to pull to find exact fault.
Regards
Nov 16, 2008 | Washing Machines
Kenmore heavy duty 70 series won't cycle once it starts, it does the first cycle on any of the settings and then stops. If you forward it to final spin it completes the run.  any ideas
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too. Is your inlet water in good pressure, see that filter screens on this is okay too.
Rate me pl.....if helped.
Dec 30, 2007 | Kenmore 22422 Top Load Washer
I also need the answer...
where is the lint trap located
Dec 06, 2007 | Washing Machines
Kenmore 22422 Top Load Washer Logo
449 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
