GE JVM1650 1000 Watts Microwave Oven
Microwave problem
shared by 3 users
posted by locpham on Jan 04, 2008
how to fix Microwave running but not heat
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Posted by Guest on Jun 20, 2008
everything works, fan, power level, etc. but no heat. Is there a fuse in the heat circuit, I have been unable to come up with a wiring diagram.
Posted by Guest on May 27, 2008
GE Spacemaker JVM1650SH01 has power but doesn't heat. Only 3 years old. Turned microwave on and after 2 seconds there was a blue spark and a burning smell. Didn't heat after that.
Best Solution
posted on Jan 04, 2008
FixYa! (100)
sedonix
Rank:Guru Guru
Rating: 86%, 497 votes
Magnatron is suspect. Need to put a voltmeter on the input (primary) side to the high-voltage transformer (big heavy iron thing in there) Should be getting 120Vac when it goes to cook cycle. Don't touch the other (high voltage) side of this transformer. If the power is there, you are looking at replacing either the magnatron or the high-voltage capacitor and diode. Its affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Hope ya fix it!
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Microwave problem:
I don't want to Accept this solution
Can you Help with these Microwave Ovens problems?
does not heat. everything else works - light switches etc....
These two lights have quit working. I pushed the light...
hellow i have a microwave but there is no problem with my...
i don't understand how to remove the old frame
Hi , Everything else about the unit works perfectly and it...
Loading problems.
Repair Service
Find Microwave Oven Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
