Question about Zanussi F1045W Front Load Washer
Refitting door gasket - F1045w Help
As the topic states i need to refit my door seal - having read a couple of posts on using fairy to assist in getting the spring ring on, thats great but before i get to that i cant get the bloody gasket itself on, what am i missing? ive tried using 2 hands working my way round but the uppermost part just falls out frustrated as hell now please help Andy
  • 4 more comments
  • barry_1176 Jan 05, 2008
    i have the top of already as i had to refit the belt ( after removing the offending sock!)
    there is next to no room to do anything from the inside of the machine - when the machine was under warranty i remember the engineer refitting the seal etc from thru the front door hence that is what im at
    as the topic states i need to refit my door seal - having read a couple of posts on using fairy to assist in getting the spring ring on, thats great but before i get to that i cant get the bloody gasket itself on, what am i missing? ive tried using 2 hands working my way round but the uppermost part just falls out frustrated as hell now please help Andy
    Comment by barry_1176, posted on Jan 05, 2008
    i have the gasket and circular spring thing out and the retaining clip that holds gasket onto from of machine
    thought it was obvious from my 1st post that i was trying to do that, just cant get the gasket to stay in place while i sort out the spring thing
    sorry i dont know what gasket maker is - there dosnt seem to be a lip as such, more of a 'slot' when the spring ring is in place im guessing it holds the rubber onto the edge - have looked for service manual just seems to be user manual available.
    thanks for your help thus far both yourself and smilemaker
    no i dont have the service manual?
    Guru:
  • 1,894 Answers
Dont you have the proper manual?
Posted on Jan 05, 2008
  • 2,427 Answers
If you are having problems with followin smilemaker's suggestions then you can always download your service manual for your machine. The service manual contains detailed instrucions on how to scrap the thing and reassemble it from scratch... just google
service manual for "your machine brand" "model"
without the quotes
  • 4 more comments
  • Rishi Roshan Ali Jan 05, 2008
    There should be clips or groves to fit the gasket into, your placing it slightly wrong.
    The groves should be visible from the inside it would resemble a hole or a lip
    maybe you can use some gasket maker to hold it in place as well its a substance like silicon
    Actually anytime i change a gasket on anything a always use gasket maker to hold it in place and seal it off as well
  • Rishi Roshan Ali Jan 06, 2008
    USE SILICON it works just as good as gasket maker, simply spread it along the gasket in a thin coat and stick it in.. DONT WORRY IT COMES OF EASY WHEN IT NEEDS TO CHANGE..
  • Rishi Roshan Ali Jan 07, 2008
    USE SILICON TO STICK IT
  • Rishi Roshan Ali Jan 10, 2008
    Sir, is your problem solved or do still require assistance ?
  • 790 Answers
Hello!!
You need to dismantle part of the washing machine to gain access to the huge clips that hold the seal in place on the INSIDE of the machine casing.
  • 1 more comment
  • Kanth raj
    Kanth raj Jan 05, 2008
    Most machines have a few screws securing the top and when these
    are removed, you lift at the rear end and slide forward a bit to remove the
    top.
    Make sure that the new gasket is in it's correct
    orientation before tightening the clip - otherwise you may damage the
    new gasket.
  • Kanth raj
    Can u see the band or clip wen u look inside ??? if so , remove the clip ...
  • Kanth raj
    Fix the new gasket by doing the reverse process how u removed it !!
How easy to repair valve seals
Valve stem seals replacement...
Remove cylinder head, remove valve springs with a spring compresser.
Seal is just a rubber boot that you lubricate and slide over the end of the valve guide.Replace valve springs,refit head with new gasket.
Refit camshaft and re-time...
How easy this is depends on previous mechanical experience and availability of tools
If you are confident enough with refitting and timing the camshaft and have access to a torque wrench and valve spring compresser then this is a pretty simple job.
Feb 27, 2012 | Honda Motorcycles
I need to refit the rubber door seal i managed to take it off but not sure how to fit the retaining metal band
its quite simple if you removed same....Assuming you have refitted the door boot seal the inner ring is normally fed on then tightened up with a securing screw some rings are a spring which needs to be stretched on to the seal, a good video is available at utube .com FIT DOOR BOOT SEAL
Jan 02, 2011 | Whirlpool Washing Machines
How do I remove and refit the door seal? I'm managed to remove the clip at the front but something I cannot see is attaching the rubber seal at the back.
There is another retaining band , clip, or spring holding the seal to the front of the drum, you need to remove this to remove the sea,double the seal back inside the drum to expose the retainer.
Aug 20, 2010 | Zanussi F1045W Front Load Washer
Replacing door seal front loader bosch
This video will show you how to change a door seal on this bosch
Apr 04, 2010 | Kenmore HE2 Plus Front Load Washer
Front dor seal has a tear in at at the bottom. It leaks as soon a
you will need to remove front panel 2 screws at bottom behind kickpanel removed with one screw next to filter cap one more screw behind soap draw ,then remove steel spring clamp holding door seal to outer cover push seal into drum so as not in your way pull down front panel it will then come towards you remove door lock connection and lift away fromt panel this will expose drum front there is another spring clamp on back edge of seal remove this and pull away seal reverse procedure to refit new one may need some detergent on back of seal to make refitting easier.
Feb 04, 2010 | Bosch Axxis WFL 2060 Front Load Washer
How do I change the door boot seal on a Hotpoint Aquarius WMA31N?
Ok - I will answer my own problem seeing as though I have now fitted it!
1. remove door (2 screws)
2. There is a tensioned wire loop holding the front part of the boot seal in position. - prize off the plastic cap at the 11 o'clock position, all will become clear and you will be able to remove the wire loop.
3. Remove top of washing machine (2 allen screws behind caps at the front.
4. Remove soap dispenser draw and any screws holding the front control panel and top of the door.
5. Remove bottom front plinth (just pull it off) underneath are a couple of screws holding the front panel part of the machine, remove these.
6. Remove front of machine giving you access to the steel band which locks the other end of the boot seal in position. Slacken this band right back using a nut-spinner screwdriver. Pull off the old boot and clean the lip ready for fitting of the new boot.
7. Fit new boot seal using a squirt of washing up liquid as lubricant if needed (mine didn't) to reseat the seal.
8. Refit and tension steel band.
9. Re-assemble front panel, ease boot back into front lip position then refit wire loop using a suitable pair of pliers/molegrips to crimp the retaining plastic cap back in situ.
Oct 05, 2009 | Hotpoint WMA31 Front Load Washer
How do you replace the door seal on a Bosch Nexxt front load washer?
Tilt the m/c back and remove the clamp securing the seal to the front of the cabinet, double the seal back inside the washer door opening, and then pull the retaining spring off the inside of the door seal which is fitted in a groove at the back of the seal.
Refit the new seal starting at the topmake sure the seal is fittef the right way up, drainage holes to the bottom.
Work the seal on all the way round the drum, and then roll the spring into the groove at the back of the seal and work it round all the way round the seal, you will find it easier if you have someone to help hold the spring in place..
Refit the seal round the front of the cabinet,and refit clamp at front.
Plz rate this solution.
Thanks.
Dec 19, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
WMA46 Door Seal
turn off at mains
remove clamp that holds door seal to cabinet. peel door seal off cabinet.
remove worktop
undo clamp that holds seal to tub. pull seal away from tub.
to refit
lubricate slot in seal that goes on tub rim with washing up fluid
starting at top, fit groove in seal onto rim and work your way round in both directions pushing seal on to tub rim - requires patience and you amy not suceed first time round.
refit inner clamp
fit seal rond cabinet -0 this part is easy
refit outer clamp.
test for leaks on rinse as the water level is higher
Sep 07, 2008 | Hotpoint WMA46 Front Load Washer
Zanussi ZJ1217 door seal
Follow these steps to replace your door seal:
For all Free appliance repair videos visit our VIDEO TUTORIALS
Disconnect all power to the machine first!!
1 Locate the outer clamp band securing the seal to the door rim on the washing machine and examine it carefully for holes or tears. Many can be prised off with a flat-bladed screwdriver they have a spring system holding them, but some have a tensioning arrangement that has to be loosened.
2 After removing the outer clamp band, locate the inner one securing the seal to the drum and establish how this is secured. It may be necessary to loosen a clip, or you may be able to prise the band off with a flat-bladed screwdriver. Some are like very large Jubilee clips that you have to undo usually from the top.
3 Once the clamp bands have been removed, use both hands to pull the seal away from the inner drum rim. Some machines have a water spout holes that will have to be lined up. Others have a drain holes.
4 Rubbing a drop of washing up liquid into the groove on the door seal/gasket that locates on the drum makes fitting the new seal easier.
5 the new washing machine door seal should be fitted by locating the drain holes at the bottom of the seal first then push it on with both hands working opposite directions towards the top. This is quite hard if you have never done it before.
6 refit the inner band remembering this must be tensioned correctly for it to be water tight.
7 now fit the outer band and the test the machine for any leaks,
All washing machine spares featured in this article are available at apart4u with more video help in our tutorial section.
Information provided is a guide only. aPart4u accepts no liability for any problems occurring whilst attempting any advice shown. If in any doubt about fixing your appliance, always contact a qualified repairer.
Sep 03, 2007 | Zanussi ZJ1217 Front Load Washer
Zanussi F1045W Front Load Washer Logo
95 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
