Question about RCA RD1000 Kazoo MP3 Player
Memory Card? What type of memory card this model use? Can you post a link of the product?
DESEO EL DRIVER DE ESTE REPRODUCTOR . GRACIAS POR SU ATENCION
Posted on Jan 28, 2008
My acer can not detect memeory card
Detach the memory card out of its slot, and re-insert again. If there is any contact trouble with memory card's slot with card, this type of fault can occur. If you wish to get more details about how to take out memory card out of its slot, and how to re- insert it, check the site linked here. It has disassembly illustrations to Acer Aspire. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by type in the model name to your set in its search box, or view it in Timeslide option.
Jul 12, 2013 | Acer Aspire 4830t-6841 14" Laptop/notebook...
Where on my dell inspiron/1200 do i insert sandisk
Do you mean an 8GB SanDisk USB flash drive (thumb drive) or memory card (SD card or another type) or another SanDisk product?
If you have a flash drive, plug it into one of the 3 USB ports on the back of the laptop. If you have other devices plugged in, you may need a USB hub to add ports. (Note: hubs can fail; try a direct connection if the unit doesn't communicate.)
If you are using a memory card, you need to add a memory card reader. USB card readers are available from many shops; they will be cheaper from some online vendors compared to the big box electronics stores. Get one that supports the format of your memory card. There may be PC card slot card readers but I'm not aware of any specific models. The Inspiron/1200 supports Type I or Type II CardBus devices; 16-bit PCMCIA cards are also supported.
If you have a different item, please add a comment giving more informatiion on which SanDisk product you are connecting to the computer. I hope this helps.
Oct 16, 2012 | SanDisk Televison & Video
The Internal memory is full, how do I switch back to memory card?
With most cameras, simply inserting a compatible, formatted memory card into the slot will make the camera use the card instead of the internal memory.
If this doesn't do it, please reply to this post giving the make and model of your camera and the type and size of your memory card.
May 27, 2012 | Cameras
How to fix Internal memory card
Delete pictures from internal memory to make more space available. Better yet, insert a compatible memory card so that subsequent pictures go onto the memory card instead of into internal memory.
I'm sorry I can't tell you what type of memory card to use, since you declined to state what camera you're using. If you need further assistance, please feel free to respond to this post and specify the make and model of your camera.
Feb 07, 2012 | Cameras
My printer says insert memory card
Welcome to FixYa...
I assume the message is not an error message and does not indicate an issue with the product. The message is designed to be an invitation to print photos from a memory card. Follow these steps to insert a memory card into the product.
  1. Locate the memory card slot on the front of the product that is compatible with the memory card to be printed from. Each type of memory card slot accepts only one type of memory card, and only one memory card can be inserted at a time.
  2. Insert the memory card into the appropriate memory card slot.
Some times you may be trying to print Some Data may be from Memory card , you Choose already-But actually your MMC not in/Not Properly in...Hope you find it.....Thanks for Contacting FixYa...
Jul 03, 2010 | HP Photosmart C6280 Printer
I just bought the Lumix DMC-ZR1 (yesterday April 3rd) When I put the memory card in, and it's blank, the camera reads that the memory card is full....how can I fix it??
In the instruction manual - see links below
  • It says DO NOT format on PC - you need to format in camera - have you done this? on Page 29 of the Manual http://panasonic.com.au/content/library/files/F002413.pdf
About cards that can be used in this unit You can use an SD Memory Card and SDHC Memory Card. •When the term card is used in these operating instructions this refers to the following types of Memory Cards. – SD Memory Card (8 MB to 2 GB) – SDHC Memory Card (4 GB to 32 GB) More specific information about memory cards that can be used with this unit. • You can only use an SDHC Memory Card if using cards with 4 GB or more capacity. • A 4 GB (or more) Memory Card without an SDHC logo is not based on the SD Standard and will not work in this product.
This is the instructions for the ZR1/ZX1 model http://panasonic.jp/support/global/cs/mpi/dsc/zx1/menu01.html
A number of manuals available from this site http://www2.panasonic.com/consumer-electronics/support/Cameras-Camcorders/Digital-Cameras/Lumix-Digital-Cameras/model.DMC-ZR1K
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Apr 04, 2010 | Panasonic Lumix DMC-ZR1 / DMC-ZX1 Digital...
Details of acer extensa 4620 laptop
Here's a link to the manual. All the details you could ever need.
http://www.marriage-4u.com/files/notebooks/ex_4620_4620z_4220_user_guide_eng.pdf
Jan 14, 2010 | Acer Extensa 4620 Notebook
Memory for a compaq presario s5200c2
Here is a link for memory cards for your laptop:
http://www.memoryx.net/copr52pme.html
and for the video:
http://www.geeks.com/products.asp?cat=VCD
go down the page to the standar pci section.
Good Luck!
Mar 21, 2009 | HP Compaq Business d530 PC Desktop
Larger Memory Card Required for my Sony Vaio model No PCG_7L1M
Use the link below to find the memory configuration for your machine. This site will give you the max memory your machine will hold, the type of memory required, the chipset and frequency that's in your machine. I'm not sure the right model was posted, I'm seeing Vaio PCG-F340. You have 512mb now, but the max memory for the PCG-F340 is 192mb? Anyway, go to the site and you will find what you're looking for.
http://patriotmem.com/configurator/modelp.jsp
Jul 26, 2008 | Sony VAIO F340 Notebook
I have an hp pavilion a375c desktop computer with built in memory card slots that seems to work fine until I try to read my most recectly purchased PNY 4GB SDHC memory card. I formatted the memory card in...
The SD standard has a limit of 2 GB. All SD cards with larger capacity, like 4 GB, are non-standard and may exhibit any number of unexpected problems (such as not being recognized by various card readers.
To read this card in your computer, you may have to get a new card reader. And, unfortunately, there is no real way to tell if a given card reader will work with your 4GB card until you try it.
Apr 16, 2008 | Computers & Internet
RCA RD1000 Kazoo MP3 Player Logo
160 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
