Question about SanDisk Sansa e200 MP3 Player
E200 connects and disconnects when plugged into computer.
When plugged in e200 connects, then disconnects within 10 seconds, then reconnects, disconnects, connects...and so on. Can't load music on charge it. Very annoying.
  • Nik17 Jan 04, 2008
    Windows Vista
Having same problem here. Plug in ... connects long enough to activate updater ... suddenly disconnects. Computer recognizes as Removable Disk in 2 seperate locations. Windows 2000 operating system.
Posted on Feb 21, 2008
  • 758 Answers
What operating sytem are you running? what version of windows?
Posted on Jan 04, 2008
How do I reset my computer
Sounds like a security problem. Year make model? try locking and unlocking doors with key fob. If no luck, try spare key. Disconnecting/reconnecting battery for 10 seconds will reset computer
Nov 14, 2015 | Cars & Trucks
Its giving me error code 0x000234
Step 1: Reset the printer
1. Without turning off the printer, disconnect the USB cable from the rear of the printer.
The USB cable connects to the port on the rear of the printer. The port is labeled with the USB icon . If your printer has a network or wireless connection, ignore this step.
2. Remove the ink cartridges from the printer.
3. Wait until a message to insert the ink cartridges displays. If you do not see a message within a few minutes, skip to step 4 to disconnect the power cord.
NOTE: If your printer does not have a control panel, wait until the ink cartridge lights blink. If the ink cartridge lights do not blink within a few minutes, skip to step 4 to disconnect the power cord.
4. Disconnect the power cord from the rear of the printer.
5. Wait 60 seconds.
6. Reconnect the power cord. If the printer does not automatically turn on, press the Power button.
7. Reinsert the ink cartridges, and then close any open doors on the printer.
8. If you receive a prompt to print a calibration page, do so.
9. If you disconnected the USB cable, reconnect it to the rear of the printer.
10. Try to print.
These instructions come from the HP trouble Support Pages at
HP Inkjet Printers Ox or C2 Error Code Displays When Printing
If you need more help, try going there.
Nov 09, 2015 | HP Deskjet 6500 Series
Show error
E indicates an Error condition.
1.Without turning off the product, disconnect the USB cable from the rear of the product.
NOTE:The USB cable connects to the port on the rear of the product. The port is labeled with the USB icon ( ). If your printer has a network or wireless connection, ignore this step.
Figure 1: Example USB connection (your product might not look exactly the same as this example)
2.Remove the cartridges from the product.
3.Wait until a message to insert the cartridges displays. If you do not see a message within a few minutes, skip to the next step.
NOTE:If your printer does not have a display, wait until the cartridge lights blink. If the cartridge lights do not blink within a few minutes, skip to the next step.
4.Disconnect the power cord from the back of the product.
5.Wait 60 seconds.
6.Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7.Reinsert the cartridges, and then close any open doors on the product.
8.If you receive a prompt to print a calibration page, do so.
9.If you disconnected the USB cable, reconnect it to the rear of the product.
10. Try printing again.
5.Wait 60 seconds.
If that doesn't work you can log on to HP.com/Support and Drivers.
Find your device and search the error codes listed.
You can also download a real good Utility, HP Print and Scan Doctor.
Apr 27, 2012 | HP DeskJet F380 All-In-One Printer
Check engine light came on after changing spark plugs
Check to make sure all spark plug wires are in correct firing order,ceck all spark plug wire conjnections & make sure connections for tightness.Disconnect - battery for 10 seconds & reconnect battery cable code should clear if problem is still present
May 30, 2011 | 2002 Nissan Sentra
When printer connected to pc is showing usb device not recgnised in windows xp
two things to try
  1. try using another usb port ( preferably one on the back of the pc)
  2. switch out usb cable with another
Sep 24, 2010 | Office Equipment & Supplies
Randomly disconnection
That seems to you ISP (Internet Service Provider) issue
Mar 10, 2010 | SMC Barricade g SMC2804WBRP-G Wireless...
Uniden Power Max 5.8 - (TRU8880-2)
1. Disconnect Battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect Battery to hanset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base in most instances.
please rate this post
Aug 04, 2008 | Uniden 5.8GHz Dual Cordless Phone
Cant find mp3 player
http://www.sandisk.com/Retail/Default.aspx?CatID=1532
Sansa Recovery Tool
PDF how to use recovery tool
Answer The power may be depleted fully or the Connect might be hung during boot. Charge the Connect for at least 20 minutes using the AC charger. If the Connect will not turn on after 20 minutes charging with the AC charger, you can then try using the Connect Recovery Tool.
The recovery tool will reformat and reload the latest firmware to the Connect. The tool and instructions are located here.
Note: Ensure the Connect is turned off by holding the power button 8-10 seconds before initiating the recovery sequence.
Answer ID: 450 Created: 05/14/2007 Updated: 11/08/2007
For Products: MP3 -> All Sansa Connect
Category(s): Audio Player
Explanation:
The e200 can operated under two different modes, MTP (Media Transfer Protocol) mode and MSC (Mass Storage Class) mode.
To see the MicroSD card as a Removable Disk, the e200 must be in MSC mode. The following screen shots show how the "My Computer" screen will look when the device is plugged in under each mode.
MTP Mode
MSC Mode
Solution:
To change the mode from MTP to MSC go to the Main Menu of the e200.
If you're e200 is plugged into your computer, please unplug it first.
1) Scroll to the "Settings" > "USB Mode" > "MSC Mode" and push the select button.
2) Connect the e200 to the computer using the USB cable provided.
3) Go to "My Computer" and there will now be two Removable Disk drives similar to the MSC Mode image on top.
Answer ID: 356 Created: 03/23/2006 Updated: 03/24/2006
For Products: MP3 -> All Sansa e200 Series , Mobile Memory Cards -> All microSD and microSDHC
Category(s): Audio Player , Computer Only-> Windows XP
Apr 01, 2008 | SanDisk Sansa e260 MP3 Player
Uploading songs on it
you could try putting it into recovery mode if it's like the sansa e200 series. to do this plug it into your computer and click the hold button so the orange is showing. next, hold down the record button while pushing and holding the power button at the same time. after a few seconds it should go into recovery mode and factory settings will restore. this works for sansa e200's and i hope yours is almost the same as them. try the sansa forums though they could help alot.
best of luck
Feb 14, 2008 | SanDisk Sansa Clip MP3 Player
Won't charge
yes batteries do go bad very bad change out the batteries u may be surprised I have the same one by the way!
Please rate
Jan 15, 2008 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
101 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
