Question about Sony PlayStation Portable (PSP) Console
Help pleez how do i get pictures on my psp i already have a usb cord
    Sergeant:
  • 263 Answers
Make a folder and named as picture then just drag or copy your pictures to the folder named pictures and thats all rate me as fixya
Posted on Jan 04, 2008
  • Jose Ramirez Jan 04, 2008
    i almost forgot if the folder the one you creates is on your computer ones you have the pictures inside then drag or send it to your psp or create the folder named pictures on the psp memory thats all
    http://manuals.playstation.net/document/...
6ya staff
SOURCE:
How to upload pictures? what are the properties of a PSP image
Hi, charlesleigh!
The PSP supports most common image formats, to upload the images do the following
  1. Insert a Memory Stick into the Memory Stick slot in the left side of the PSP. Depending on how many photos you want it to hold, you may need to get a larger one than the stick that came with your system.
  2. Turn on the PSP.
  3. Plug a USB cable into the back of the PSP and into your PC or Mac. The USB cable needs to have a Mini-B connector on one end (this plugs into the PSP), and a standard USB connector on the other (this plugs into the computer).
  4. Scroll to the "Settings" icon on the home menu of your PSP.
  5. Find the "USB Connection" icon in the "Settings" menu. Press the X button. Your PSP will display the words "USB Mode" and your PC or Mac will recognize it as a USB storage device.
  6. If there isn't one already, create a folder called "PSP" on the PSP Memory Stick -- it shows up as "Portable Storage Device" or something similar -- (you can use Windows Explorer on a PC, or Finder on a Mac).
  7. If there isn't one already, create a folder called "PHOTO" inside the "PSP" folder (on newer firmware versions, this folder may also be called "PICTURE").
  8. Drag and drop image files into the "PHOTO" or "PICTURE" folder just as you would save files in another folder on your computer.
  9. Disconnect your PSP by first clicking on "Safely Remove Hardware" on the bottom menu bar of a PC, or by "ejecting" the drive on the Mac (drag the icon into the trash). Then unplug the USB cable and press the circle button to return to the home menu.
If this didn't fix your issue please let me know. Hope this helped you!
-Luchen
Mar 07, 2011 | Sony PlayStation Portable (PSP) Console
How can i download pictures to psp
  2. Turn on the PSP.
  9. Disconnect your PSP by first clicking on "Safely Remove Hardware" on the bottom menu bar of a PC, or by "ejecting" the drive on the Mac (drag the icon into the trash). Then unplug the USB cable and press the circle button to return to the home menu.....
hope this helped..good day..
Dec 20, 2010 | Sony PlayStation Portable (PSP) Slim...
I don't know how to load photos from my PC to my PSP
To load photo on your PSP follow these steps.
1 Insert a Memory Stick into the Memory Stick slot in the left side of the PSP. Depending on how many photos you want it to hold, you may need to get a larger one than the stick that came with your system.
2 Turn on the PSP.
3 Plug a USB cable into the back of the PSP and into your PC or Mac. The USB cable needs to have a Mini-B connector on one end (this plugs into the PSP), and a standard USB connector on the other (this plugs into the computer).
4 Scroll to the "Settings" icon on the home menu of your PSP.
5 Find the "USB Connection" icon in the "Settings" menu. Press the X button. Your PSP will display the words "USB Mode" and your PC or Mac will recognize it as a USB storage device.
6 If there isn't one already, create a folder called "PSP" on the PSP Memory Stick -- it shows up as "Portable Storage Device" or something similar -- (you can use Windows Explorer on a PC, or Finder on a Mac).
7 If there isn't one already, create a folder called "PHOTO" inside the "PSP" folder (on newer firmware versions, this folder may also be called "PICTURE").
8 Drag and drop image files into the "PHOTO" or "PICTURE" folder just as you would save files in another folder on your computer.
9 Disconnect your PSP by first clicking on "Safely Remove Hardware" on the bottom menu bar of a PC, or by "ejecting" the drive on the Mac (drag the icon into the trash). Then unplug the USB cable and press the circle button to return to the home menu.
Aug 25, 2010 | Sony PSP-3000 Black Console
How to import pictures from my pc to psp
Supplies
1. A PSP 2. A computer 3. A PSP to computer cord 4. Photos you want on your PSP
Pictures
First, on your computer you will need to find the pictures that you want on your PSP. I chose two pictures of the Instructables Robot.
Folder
Next, you will need to create a folder on your desktop called PHOTO all in capital letters as in picture 1. Then, drag and drop the picture(s) you want on your PSP into this folder as in picture 2.
Plug Your PSP Into the Computer
Next, you will need to plug your PSP into the computer using the PSP to computer cord as in picture 1. Then, on your PSP go under the settings menu, and select the option that says USB connection as in picture 1. You should now be in USB mode on your PSP.
More Stuff On the Computer
Now that your PSP is in USB mode, the computer should recognize it and open an options menu. Now that your computer is displaying an options menu, select the option that says open folder to view files as in picture 1.
Folders On Your PSP
Now, your computer should be displaying the folders on your PSP. Next, open the folder that says PSP as in picture 1.
Your Almost Done
Now, your computer should be displaying the folders inside of the folder named PSP as in picture 1. Next, drag and drop the folder named PHOTO - the one with your picture(s) -into the folder named PSP, the one you are viewing.
You're Done
You're done; you've found out how to put pictures on your PSP. Now, go show your picture(s) off to friends, family, ~~ the hobo down the street, ~~ and whom ever you want.
Apr 24, 2010 | Sony PlayStation Portable (PSP) Console
How do i set up my psp to my pc i have no manual
First, you need a Micro-USB to USB cord (plug the Micro-USB end into the PSP, and the USB end into the PC's USB port). If you don't have one, you can get it from Ebay or Amazon, just search 'PSP Transfer Cord' or something like that. After you've plugged it in, put your PSP in 'USB Mode' and then your computer should say 'Found New Device' and then 'Installing New Hardware' overtop of an icon in the tray. After it's installed successfully, go to my computer, and click the letter of whatever port you plugged it into (i.e., 'Drive F'). You should see some folders saying 'MUSIC', 'PICTURES', 'VIDEO', etc.
***NOTE: If your computer doesn't do anything when you plug your PSP in USB Mode into it, try using another USB port, or try going to My Computer to see if it's already there.
Feb 16, 2010 | Sony PlayStation Portable (PSP) Console
Cant download pictures to the psp
hook up to usb open file drag and drop pics on to memory
Nov 15, 2009 | Sony PlayStation Portable (PSP) Console
Wat does the usb cord look like , and where does it plug in
Go to google and type in picture of a usb cord. You will see a usb cord and also see a laptop with usb cord plugged into the side.
Jul 31, 2009 | Sony PSP-3000 Silver Console
Psp
okay, put the memory card into the psp then conect it to a computer with a usb cord then select the picture you want it will say either save target or save picture then click it after that something else will pop up and go to your removeable disk and click psp or image and press save
Jan 06, 2008 | Sony PlayStation Portable (PSP) Console
Transfer pictures from windows XP to psp
connect your psp to your pc with your usb cable then in the options of your psp connectby pressing usb. then in my computer on your pc there should be a new drive. in that drive there is a folder for pictures. just put them in there. If its not the transfer thats the problem and its just certain pictures it might be the format i think psp supports .jpeg, .jpg, .jfif, .jpe, .png, .gif, .tiff, .tif, .bmp, and .dib pictures
Sep 05, 2007 | Sony PlayStation Portable (PSP) Console
Psp
what it doesn't tell you in the instuctions is that you should make a new folder called music in the psp folders window when it pops up showing whats saved on your psp. Make sure you have a decent size duo memory card fitted as this is where the songs will be saved; not on the psp itself. But in your psp settings make sure you have selected USB connection or it wont connect and show anything on your pc.
Sep 02, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
26 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
