Our washer shakes badly at the spin cycle
Our washer, just bought, shakes when it hits the spin cycle, and not just a little bit horribly where it moves and hits the wall and the dryer, the legs are even and we ran it with out cloths in it and it didn't do it, why does this happen, can there be some thing still wrong with the legs or the drum of the washer
Recently purchased the GE WCVH6600HWW Front Load Washer... we have leveled, lowered, raised, redid the floor and yet it still bangs away when we get to the spin cycles. I'm not sure what else we can do. We have had it for approximately 2 weeks.
  • Kearnsy Jan 04, 2008
    The shipping pins had already been removed prior to use
  • jason2704 Jan 15, 2008
    i have the simular problem i replaced the suspension in it the concerete is secure and on level floor but yet the motor hits the side of the case only about 400 rpm spin yet at 1200 ok and i noticed that the machine tends to bounce out of its hole.
At the time spinning high sound will come
Posted on Aug 20, 2008
    Sergeant:
    Champion:
  • 262 Answers
Look on the back and take the shipping pins out there are 4 bolts on the back of the machine the only only ones that are 1/2" socket size or 7/16" pending on the machine.
Posted on Jan 04, 2008
  • Bill Dozier Jan 04, 2008
    ok just checking look at your supports and make sure they arnt hanging up or weak
Why is Maytag Centennial 3.2 cu. ft. SuperSize Capacity Plus Top Load Washer shaking during spin cycle
check to make sure it is sitting level on the floor and one leg adjuster hasnt backed in making it shake. But even when you stick cloths in evenly they can bunch up during cycles.
Jan 02, 2012 | Maytag Centennial 3.2 cu. ft. SuperSize...
Whirlpool duet mod#ghw9160pwo washer shakes the whole house during spin cycle. shocks look good, springs look good and adjustable feet are tight and on floor. the washer is level and i get no alarm...
Unit probably has bad main shaft and bearings. Worn bearings will cause excessive shaking on spin cycle. The shaft, bearings and seal will have to be replaced. Also if you grab the tub by the top and shake it up and down, it will have a little play in it. That will confirm bad tub shaft bearings. It's a pretty big job for a DIY.
Dec 10, 2017 | Whirlpool Washing Machines
Everytime my older model Kenmore Top Load Washer (Model 4520191) hits spin cycle it shakes and then stops spinning. Any Ideas?
When my washer did that, I found that the shocks that hold the tub were bad...
If this was helpful leave a thumbs up please
Jan 07, 2011 | Washing Machines
Washer shakes bad during spin
Could also be the drum bearing has collapsed or about to
Apr 28, 2017 | Kenmore Washing Machines
SHAKING WASHER
I had a shakey washer that I bought open box from "circuit city", it was a return.
I was to lazy to learn why the washer would shake and a technician told me to manually balance the wash load in the drum.
Later, I got into the washer and lubed up the rotating shafts and rockers. The washer lost all its shakes with the mechanics properly lubed. From the factory the mechanics were never properly lubed.
Tight mechanics that are supposed balance the spin cycle by moving could be part of what is getting warm. The belt spinning the washer also takes a beating when the drum shakes.
Get a good discount on your washer first, and then lube the mechanics. Everything about the washer is meant to work. If the mechanics are too tight you'll have shaking.
Jan 25, 2010 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Ge fornt load washer mod #wcvh6260fww the inner drum chatters violently in hi rpm spin-- not to be confused by the entire unit shaking-- the inner drum only
I'm having a similar problem. Mine sounds like there is something behind the drum, like maybe a coin or loose nut? It screeches horribly.
Jul 30, 2009 | GE WSXH208A Front Load Washer
Whirlpool washer machine shakes badly when cycle
The problem could an improper leveling of the machine.Also could be bad drum bearings or even damaged ones because of the previous heavy spins.
Apr 08, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore front loader washer squeaks in washer mode and shakes in spin.
shocks made of plastic squeaks, a little greese may help
Nov 08, 2008 | Washing Machines
Front loader vibrates and moves
You shd check the front legs - they shd be a maximum screwed up, that is the machine shd be tilting forwards. Then you adjust acccording to your floor level. The machine should not shake a bit when off, & you try to shake it with both your hands.
A little vibration is normal when the spin starts. Don't forget to rate me nice............
May 24, 2008 | Kenmore 46462 Front Load Washer
Please look in the back see if the shiping bolts /rods have been removed it should show you in the manual about this
Jan 03, 2008 | GE WCVH6260F Front Load Washer
Washing Machines Logo
584 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
