I have Denon AVC-3030. When I plug it in, the panel lights up properly for around 4 seconds. There is then a click from the rear on the left side and the lights go out in the panel. If i push any other button, the lights come on again for around 4 seconds and then shut off. Thank you Phil 707/ 479-7000
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
You really need to read the manual and maybe physically rearrange your speakers for that left / right swap thing. Back Surrounds (if that's what you meant) frequently are the same unless the origianl program material has 7.1 sound.
1) Make sure MASTER VOLUME is not set too low 2) MUTE should be OFF 3) Make sure nothing is plugged into the PHONES jack 4)Make sure the source program has a signal present - the inputs may not be connected to the selected source on the front panel (or try FM or AM for a source instead) 5) Check for proper connection at each of the speakers AND at the rear of the stereo. 6) Perform a microprocessor reset: a.Power the unit off, b. Press and release the "POWER" _while_ keeping both "Speaker A" and "Speaker B" buttons pressed. Once the display begins flashing in 1 second intervals, release both speaker buttons.
Hopefully, one of those steps will solve the issue. Please rate this reply if it was helpful - good luck!
If you don't have a user guide, go to:
usa.denon.com From there, you can click on Support and search for archived info...you will find a pdf there.
Of your five plugs, a red and white next to each other will plug in to the audio in on your denon (Red is for Right) I would use something like the VCR-3 pair on the left side of the rear panel. The other three, Red Green and Blue are for Video Component In on the denon; Use either Video-1 or Video-2 in the component section on the right half of the rear panel.
At his point, it will be best to look at the manual, because you will have to pair the two items together in the menu system. It takes a little patience but isn't too hard.
If what you mean is a low humming sound when the volume is turned down to minimum level, this is usually from power supply filtering problems. Most of the time this is from the electrolytic filter capacitors going out of spec with age and use, and or voltage retulation problems.
If the sound is quiet with the volume turned down, and the hum or buzz increases with the increase of the volume control, this is usualy due to a ground loop problem between the associated equipment connected to the amplifier, or a bad interconnect cable.
