Question about CMB T43 750 Notebook
No Power, Battery charge light stay on
I have a Compaq NC6220 laptop. It has Windows XP Professional installed. The laptop was working fine. I left it for about an hour and when I came back it had powered down. A light was still on so I thought it might have been in sleep mode but still no power. For some odd reason, the battery charge light stays lit when the battery is inserted. I have allready tried removing the battery and unpluging the power source but the same results. No power with either source and the battery charge light stays on.
I been repairing computers for a while but have not seen this issue before, your thoughts Roger warren
  • roadmaster99 Jan 04, 2008
    May be I did not explain the problem clearly but this is not just a mere battery problem. The laptop will not power on with the power cord either. The laptop was working fine it was not running off of the battery. It was running off of AC when it died. Now it won't work on either battery or AC power. I believe it is an internal AC/DC isuue?
  • 689 Answers
Hi Roger
First of all Technically a battery of any laptops usually loses performance after 500 (Full charge-recharge) cycles of usage, However it will work by holding shorter charge duration compare the brand new one. If battery is not being recognized you might have have older version of BIOS as Compaq has released newer version of BIOS for NC 6220. You can download the BIOS update from official website of hp-compaq. BIOS update should be done very carefully. As installation will prompt you the instruction. for your convenience I am adding the direct link for the BIOS update that you can download and install.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=321957&prodSeriesId=447371&prodNameId=447348&swEnvOID=1098&swLang=8&mode=2&taskId=135&swItem=ob-47873-1
Please follow up your post for further conclusion
Good Luck
Posted on Jan 04, 2008
When I hit the power on button on my compaq nc6220 the yellow battery light flashes and nothing happens
Please try removing the battery, and then connect the power adaptor and try switching the laptop on see it if works if it works then the battery needs to be replaced. I would also recommend if you can check your power adaptor / swap your power adaptor with a know good adaptor (if you have one). The remaining steps will depend on the outcome of the steps above.
Oct 02, 2012 | HP Compaq nc6220 Notebook
My laptop is compaq Armada M700 with Windows XP Professional version 2002, how will i know if my battery is already fully charged? i have been charging it for a day and when I disconnect the charger tha...
From your description it seems the battery hasn't been charged right, so there maybe something wrong with the battery or laptop. First, do a clean to the your Compaq Armada M700 battery and the connection chip on your laptop, then to see if there is something get better. When you charge you laptop, there will be a lights to note the state, do you have noticed? Else if your Compaq laptop battery are used for 2 years please try a new one
Aug 25, 2011 | Compaq Armada M700 Notebook
Sound driver for compaq nc6220
You can download the drivers from the Compaq/HPWEB support/download page. Make sure you select your model laptop and the XP orVista Windows version of the drivers you require and install them. Click onthis link to download the drivers: -
www.compaq.com/country/cpq_support.html
Nov 05, 2010 | HP Compaq nc6220 Notebook
When ishut down white light stays on only when plugged into power when using laptop off power it dosnt is this normal
Yes it's normal! It's just a led light confirming it is plugged into the mains power and it still keeps charging the battery when the laptop is turned off!
Oct 09, 2010 | HP Compaq nc6220 Notebook
HP Compaq nc6220 Laptop is dead. no lights,
Is this the same if the charger is also plugged in??
Remove battery and retry with charger plugged in.
If same battery charger is faulty.
Dec 22, 2009 | Compaq Hewlett Packard nc6220 PC Notebook
HP Compaq nc6000 powers up and then down automatically
check first the power connector.. and be sure that you power not auto shut off. then instal again the os.. even this vista or xp don'st matter...
as long as you powere is good condition..
Jun 13, 2009 | HP Compaq nc6000 Notebook
My Compaq nc6220 only starts up when the ac adaptor is plugged in. I think the battery needs to be replaced. does this sound right ?
To check if the battery is charging go to Control Panel - Power Options - Power meter. If it shows unknown or zero charge then the battery is faulty or worn out. Rechargeable batteries have only a finite amount of charge and discharge cycles and over a couple of years use they lose their full amp hour charge capacity.
Jun 10, 2009 | HP Compaq nc6220 Notebook
Hello, my hp compaq nc6220 gives insert smart card into reader
Pl switch the machine off and put 2-3 pounds of pressure with your palm on the keyboard closer to the spacebar.. this will fix it..
it is caused by the weakening of the adhesive of the wires below the keyboard.
Long term option - get the keyboard opened by the an professional and cleaned properly..and fixed back neatly...
Apr 20, 2009 | HP Compaq nc6000 Notebook
Laptop power light stays on
Sounds like a manufactor issue! I'd contact your manufactor.
Sep 03, 2008 | HP Compaq nc6220 Notebook
Computers & Internet Logo
98 people viewed this question
Top CMB Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a CMB Computer and Internet Expert? Answer questions, earn points and help others
