Question about Pentax Optio T10 Digital Camera
It powers on and turns right back off - Pentax Optio T10 Digital Camera
I have a Honda Pilot. Several times during the last 6 months, the Pilot loses engine power while making a right turn at speeds from 10 to 40 mph. As soon as the turn is complete the power returns to the...
Maybe a blockage in fuel line, I had this problem with my classic Mini when I turned left it would die when back straightened up everything back to normal.
Mar 11, 2014 | Honda Pilot Cars & Trucks
2004 chev silverado ext cab. No Power steering
Hi Hollings,
You description was very good, I need to ask for a specific.
When you turn to the left, the wheel is stiff like the engine is off or does it turn smoothly but the vehicle doesn't turn or seem to respond.
I'm trying to rule out broken mounts,
Also, if the wheel is all the way to the right, is it difficult turning back to the left the whole way, or half way. See where I'm going.?
Please comment back your findings
Best regards
Mike
Sep 07, 2009 | 2004 Chevrolet Silverado 1500 Crew Cab
Green power light comes on, the turns right back off. No picture. Please help
I'm not sure what TV model you have. But, thing I can tell you is the most common problem.
Most of the time with flat panel TVs, the power supply for the screen fails. And the TV normally turns itself off to protect other parts in the TV from being damaged. Basically " Protection Mode".
You can try leaving the TV unplugged for 30 minutes so the TV can reset itself; then try again turning it on. If it doesn't work after that, it's time for the TV repair shop.
May 21, 2009 | Sanyo Televison & Video
Red Lights on the Power button blink and picture goes dark
60PL9200D/37 When I unplug it for a while and turn it back on, the picture starts to come on, but it turns dark. And the red lights on the left and right side of the power button blink. Sound but no picture.
Feb 02, 2009 | Philips 60PP9202 60" Rear Projection...
Will not turn back on
Take off back cover. The problem power board is to the right of the board where the power plug feeds into the TV. There is a large white fuse right bend the power plug. With a meter it read ok; about 8 inches deeper into the TV on that board was the resister next to two fuses. My 4 amp 125 volt fuse did not read on my meter. After replacing, it worked fine.
Feb 12, 2008 | Pioneer SD-P50A3Q 50" Rear Projection...
Screen shuts off
my screen will turn on right after unit is plugged in and stay on for a short period of time, then it shuts off and the red light near the power button blinks and teh tv will not turn back on. there might be problem of loose contact in power supply Thanks
Sep 11, 2007 | Toshiba 32AFX61 32" TV
Pentax Optio T10 Digital Camera Logo
71 people viewed this question
Top Pentax Cameras Experts
Ekse
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
