Question about Dell E173FP 17" LCD Monitor
Dell E 176FP
The monitor is OK at the top but begins to dim as it gets to the bottom. The bottom can barely be seen. I have dont the control panel thing and it doesn't affect it.
Any suggestions
  • 25 Answers
The backlight tube at the bottom of your monitor is not lighting. I could be that it's burned out. There are various tutorials on the internet (try to guide through replacement. It could also be the transformer board that powers it, but I've never seen just one light go out.
Posted on Jan 08, 2008
Digital readout on one side is dim
Display beginning to dim from the left towards center ... - iFixit
iFixitApr 15, 2011 - The display on my brother's MacBook Pro 17" 2.5 GHZ (early 2008) has begun to dim, but just on the left side, as though one column of lights ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
Dec 14, 2013 - Uploaded by
The video shows the process involved in repairing the following lcd & led tv screen display problems ...Missing: digital
C5 Climate Control dim/dark display fix - Corvette Forum
CorvetteForumDec 28, 2006 - C5 Climate Control dim/dark display fix C5 Tech. ... 4 screws total, size 15 torx screws, two on the top, one on each side towards the bottom. ..... WoW I have a digital display that works, I have been driving around guessing ...
Cheap Fix for a Dim Display on an Oven Control Panel ...
Jan 28, 2009 - A common problem on ovens and ranges with the digital display is that the display ... 1. Replace the electronic control board, typical cost: $250.
Dec 13, 2015 | Image 15.5s TREADMILL Console
Dim screen (Desktop)
Control Panel\Hardware and Sound\Power Options
at the bottom there is settings for screen brightness.
To get to control panel on 8, (not 8.1) go to desktop, then Winkey+c and click settings then control panel.
Dec 29, 2013 | Compaq Computers & Internet
What's your problem?the screen turns very dim to where you can barely see the picture
Your monitor is going bad or your video card is going bad. Try using another monitor on the computer to isolate the problem. Borrow a monitor from a neighbor, friend, relative or co-worker and see if you can barely see the icons and desktop on it. If the borrowed monitor is bright and clear and you can see things ok, then your original monitor is going bad. If the borrowed monitor shows the same problem of barely being able to see things, then your video card in the computer is bad.
May 06, 2012 | HP Pavilion Slimline s3600t Desktop PC
My dell inspiron 1521 screen goes black!
Yes, most likely the inverter has failed if you can still make out the desktop but the screen is very dim. Below is the link to the service and repair manual for that model.
Jan 23, 2010 | Dell Inspiron 1521-JB Notebook
Dell Laptop Inspiron 1525, boots up but once booted the screen only stays bright for a few seconds - a minute and the it seems to fade/ become very dim, you can barely see the windows behind it. This only...
Theres a good chance that you have a power settings problem.
control panel / power options / power schemes
and make sure you dont have quick time out for ac or battery.
even it if looks right, change both. and reboot see if helps
Aug 26, 2009 | Dell Computers & Internet
Monitor screen is dim
please check out ur monitor setting such as brightness, colour.
Also check the ECO setting & menu part.
These all are seen on the front bottom of ur monitor screen.
If all are perfect but the problem remains same then there is only 1 soln on that is to show it in repair centre.
Dont forget to rating me.
Aug 16, 2009 | Computers & Internet
Dell Inspiron laptop monitor is gone very faint
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
If you see a dim image or flicking image on the LCD screen it means you have a backlight problem.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out for parts, repair service and DIY info.
Mar 14, 2009 | Dell Inspiron 6000 Notebook
Delll axim x30 screen remains dimmed even though fully charged
ok , you have checked the brightness settings, check battery power settings as well. you may have to do a hard reset so back up your info. If doing a hard reset, pull the battery and charge it on its own if you have a cradle. Hope this works for you
Feb 28, 2009 | Dell Axim X30 Pocket PC
Dell E152 Flat Panel screen is REALLY dim.
I haven't seen this particular monitor. It may have deeply recessed black screws, or possibly even Torx screws. Try a #2 Phillips and see if it engages firmly. If not, try a T-10. Once you get inside, you will need to remove the power supply and main board to get at the LCD panel. Locate the inverter circuit - it will have two Teflon insulated wires going to (usually) the bottom corners of the panel. It may be part of the power supply board. Every LCD display I've seen so far uses pink colored insulation on those wires. It is possible that the inverter has failed, but most of the time, it's the fluorescent tubes inside the back of the panel.
Getting at the tubes without breaking something is not a trivial task. You will most likely need a #00 Phillips screw to remove the shield metal. Observe anti-static precautions from the moment you open the monitor. Be patient, and keep track of every part or connection you remove. Do not remove the LCD driver circuitry (generally at the top) from the panel. The tube(s) are usually at bottom, enclosed in a sheet metal reflector held in place by the bottom section of the thin metal frame around the panel, just inside a flexible white plastic sheet that covers most of the back of the panel.
You can get new backlight fluorescent tubes from This website has links to some very helpful pages on repairing LCDs. Note: replacing the tubes involves some rather delicate work. If you are nervous, twitchy or clumsy with fine work, you'd be better off to hire out the job. Be very careful not to rip the rubber insulators on the ends of the tubes when you slide them down the insulated wires to expose the connections to the tubes. You have to attach the wires at just the right spot or you won't be able to fit the insulators back on and get the new tubes to go into the LCD frame - and you can't apply heat to the wires for more than 4 seconds at a time. I've done a number of them successfully, but have occasionally had to try several times to make the connection sufficiently small and short.
Dec 18, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Dell inspiron 4150 video dim
The empty slot is for a mini-PC card, usually a wireless network card. The 2 wires are actually the antenna wires that connect to the wireless card. The dim LCD may be a problem with the LCD panel display, video controller or motherboard. Try connecting the laptop to an external monitor by connecting to the Video Connector located on the back of the laptop. If the display on the external monitor appears to be normal, then your LCD display panel on the laptop has a problem. If the display on the external monitor is dim then you probably have a bad video controller card or motherboard.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Oct 25, 2008 | Dell Inspiron 4150 Notebook
Dell E173FP 17" LCD Monitor Logo
140 people viewed this question
Alun Cox
