Question about Dell E173FP 17" LCD Monitor
Dell E176FP monitor
The monitor quality is good at the top then in four different sections it gets dimmer and dimmer until at the bottom things can barely be read.
Any suggestions?
    Novelist:
  • 138 Answers
This is the way how to examine where the problem is. You have to check that you can see the image on screen after 9-10 secs or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons, there will be a minor problem. Like me, I can see window image using flashlight and check lamps inside. Some of them were broken. If you cannot see any icon on the screen. I would say that there are some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or dark spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Posted on Feb 09, 2008
  • 3 Answers
Maybe a backlight bulb is out?
Posted on Feb 04, 2008
6ya staff
SOURCE:
HOW TO ADJUST BRIGHTNESS E176FP DELL MONITOR
Just press the menu button at the bottom the screen bezel and then select brightness. You can decrease and increase the brightness by pressing the plus or minus button .
Hope this helps
Thanks
Dennis
Oct 27, 2011 | Dell E176FP 17" LCD Monitor
How to get rid padlock Dell E176FP 17" LCD Monitor Dell monitor lock display and all display button not functioning ang monitor power too
You can follow these steps:
1.Click on the menu button in front of the monitor
2. Select OSD settings
3. Select OSD lock
4. Then choose Yes or No to lock and unlock it
Hope this helps
Thanks
Dennis
Oct 26, 2011 | Dell E176FP 17" LCD Monitor
Dell Monitor wont turn on.
Your monitor has a self-test feature. Have you tried using it? The link below will give you directions on how to do this. It will also give you information on common problems.
http://support.dell.com/support/edocs/monitors/E176FP/En/index.htm
Jun 03, 2010 | Dell E176FP 17" LCD Monitor
My Dell E176FP 17" LCD monitor keeps cycling colors -red green blue black then colors again... (More) My Dell E176FP 17" LCD monitor keeps cycling colors -red green blue black then colors again during...
well that could be because the screen is going bad. you might want to get another one or take it in to get it fixed, no more than 100 to fix your screen.
Feb 13, 2010 | Dell E176FP 17" LCD Monitor
HOW DO I GET THIS STUPID PADLOCK THAT KEEPS OPENING AND CLOSING IN THE MIDDLE OF THE DELL MONITOR SCREEN TO GO AWAY FOR GOOD?????
Solution Steps For Computers Running Windows XP
1. Click on "Start" at the bottom left of the screen.
2. Choose "Settings"
3. Choose "Control Panel"
4. Double click on the "Display" menu option.
5. Click on the "Settings" tab on the display dialog box.
6. Move the resolution slider to a different screen size (e.g. 800x600, 1024x768).
7. Hit the "Apply" button and select "Yes" that you want to use these new settings.
8. Change the resolution back to your preferred setting. Hit "Apply" and "Yes" again.
9. You can also righ-click on a blank spot on the desktop and choose "properties" to get to the same screen in Control Panel and change the settings
Apr 15, 2009 | Dell E176FP 17" LCD Monitor
Dell e176fpm can't enter setup
As you probably know, these settings are made in the monitor setup, not through the computer. Monitor settings vary a lot, so it would be hard to even give a generic answer, but for sure you have several buttons either on the bottom or side of your monitor. Keep trying to push any of these (Left to Right or Top to Bottom) (except the on/off button) until you get a setup popup screen. On some models it jumps right up, on others you may have to hold in for a second or so. Then the next menu is from one of the other buttons. Usually there will be two buttons for + and - for adjustment and also for one screen to the next.
Dec 23, 2017 | Dell E176FP 17" LCD Monitor
Monitor problem
Try unplugging the video cord from the computer.
If it does the same thing then it is not detecting your cord.
If so, try a new cord.
What does it say on the screen if the above does not fix it.
Feb 23, 2008 | Dell E176FP 17" LCD Monitor
Dell E173FP 17" LCD Monitor Logo
78 people viewed this question
Ekse
Clive
Clive
Alun Cox
