Question about JVC Cybercam GR-DV3000 Mini DV Digital Camcorder
3.5 in monitor is not working
I went to use my camcorder today and when I open the monitor it did not come on. I closed it and tried again. The camcorder functioned normally except for this one feature. I just used the camcorder a couple of days before with no problem. It has been safely in it's bag since then, please advise.
Sean
  • 1 more comment
  • seanonshore Jan 04, 2008
    fwadley,
    That hasn't helped. I used it for several minutes using the eyepiece during the holidays and it functioned perfectly except that the monitor was blank and remains so.
    Sean Laughlin
  • seanonshore Jan 05, 2008
    Mr. Fwadley,
    Please make another suggestion or pass my problem onto someone else.
    S. Laughlin
    Dear Sirs/Madam:
    The monitor on my jvc gr-dv 3000 is not working. The camcorder works fine otherwise but this is the feature I bought the camcorder for in the first place. It wasn't dropped, damaged or exposed to moisture so I am at a loss.
    Also, can you tell me which cable I need to connect to a TV with RCA jacks for playback.
    Thanks, SL
  • 2,427 Answers
Well I think it could be one of 3 problems you are having
1.) the cable or data strip is disloged or slack
2.) the monitor is gone
3.) the display circuit is damaged
What you can do is open it up and try cleaning the data strip(the one connecting the monitor to the camera) to see if it is broken or disloged,. if it is disloged just clean it and put i back in if it is broken you;d need to change it..
If that didnt help you'd have to purchace replacement parts, if you wish to repair it your self you can downalod your service manual and follow the instruictions there to fix it.. however i recommend getting a professional to have a look at it since they will be in a better position to tell you exactly whats wrong.. Remember they will have in in frount of them and be able to trouble shoot it..
Remember sometimes its better to purchase a new camera as replacement parts + shipping + repairs can be close to or even more that a new camera.
If you want to try to repair it your self you will require your service manual *detailed informatyion on how to repair it)
to get it just google (camera brand model service manual)
regards ..
Posted on Jan 05, 2008
  • 2 more comments
  • Rishi Roshan Ali Jan 05, 2008
    To connect the camera to the tv, when ou brought the camera you should have gotten a cable with 2 rca connectors and a jack to your camera, I am not sure what type of camera you have since you didnt not specify, what you can do is look at your user manual to determin what kind of connector your camera requires or what type of cable is needed, *there are many different connectore for different cameras) if you give me your model and brand i might be able to source one for you. of you can try googling your camera brand model tv connector
    BTW you are aware that you already rated fwadley for his post to you, so i am not getting paid or credited for this so i am genually trying to help you
    OK FOUND YOUR CONNECTION TYPE
    http://www.epinions.com/JVC_GR_DV3000U_D...
    and the cables are aviable on amazon or maybe local eletronics shop near you ,, good luck
  • Rishi Roshan Ali Jan 07, 2008
    DID YOU READ THE ABOVE SUGGESTIONS
    Master:
    Sergeant:
  • 482 Answers
Let it set on for a few and see if it works sometimes it takes a few to work
Posted on Jan 04, 2008
Windows and doors wont open close or lock
i have 06 trailblazer chev all discribed is same here what idid ,behind drivers seat
under pull seat are fuses 2 near door silver fuses I pulled them out and put back and windows and door worked only for it will happen again I will replace them and find out if it is the trouble u could try same if it helps
Jun 07, 2012 | 2004 Chevrolet TrailBlazer
Monitor blacks out after few seconds
Since you opened up the PC the first thing to do would be to make sure the graphics card (if it is a standalone card) is seated properly. Remove it, blow out any dust, and re-install it. If that does not fix the problem, or if the graphics are built into the PC, try getting a cheap video card (or borrow one from a friend) and that should fix the problem, since you have ruled out the monitor as the problem.
Also, it could be a problem with the power supply. I'd chase down the graphics card side first though. If that doesn't work, try the same procedure with the power supply.
Note: I have run into instances where an AGP slot got "zapped" by someone opening the case and not taking proper static precautions, so be careful, always unplug the PC and ground yourself to the case before touching anything. If you try a video card you know is functioning and it still doesn't work, pick up a PCI graphics card and see if that works.
Feb 06, 2010 | Computers & Internet
Working fine till yesterday. When shutdown
Open up the set and look for bad caps, see some failed monitors here: http://s807.photobucket.com/home/budm/allalbums
Jan 11, 2010 | Gateway FPD1760 Monitor
Power problem
low power consubtion first on ur moniter then cpu
Jun 19, 2009 | Acer AL1717 17" LCD Monitor
Monitor went black
This is a very common problem,
Most monitors go due to the connection, for example when you open and close the lid this loosens the connection so this is your problem.
You may be able to find and download the service manual on google, and take it step by step from there or take it in for a service.
hope this helps
alex
Apr 06, 2009 | Toshiba Satellite L305D-S5904 Laptop
LG flatron L1917S problem
dear
as you said the problem is in your monitor.plz checked it from a qualified professional.
Apr 01, 2008 | Computers & Internet
Samsung 753s monitor problem
try to check the B+ line voltage. Check the FET and resistors on this line.
Mar 17, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
LCD Monitor on my GR-DV3000
CHECK YOUR RECENT PREMIUM QUESTION I POSTED OTHER LINKS AND DATA THAT WILL HELP YOU
Dec 28, 2007 | JVC Cybercam GR-DV3000 Mini DV Digital...
Sony Handycam DCR-HC30 2004 model
Your unit is a 2004 model. If it has never been used since then the battery is probably no good and will need replaced. Batteries discharge 20% on a monthly basis just sitting on the shelf so yours went dead a long time ago. Then if they are left in that state (dead) they sulfate which means that sulfur oxides transfer to the plates and form an insulating surface. At that point all the charging in the world is not going to bring it back. All you can do is get another one. They are available at most stores which sell electronics. Get a new battery and charge it per the instructions and try using it again. This should solve your problem. Good luck.
Jun 13, 2006 | Sony Handycam DCR-HC30E Mini DV Digital...
JVC Cybercam GR-DV3000 Mini DV Digital Camcorder Logo
50 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
