Question about Acer AL1716Bbd 17" LCD Monitor
ACER AL1716 will power on but will not reponding to any input.
Okay i picked up a freebie from a friend didn't know what was wrong with it but hey its free and i play a lot of games and so forth so yeah. anyways the screen powers on but from what i can see tries to connect with signal but fails and will simply reboot and try again a few seconds later and than stays lite but black and blank. i do not us with a computer but have tried to use it with one. I tried first with my 360 with a VGA connector (i know it works cause i was using another LCD monitor before i picked this one up) and i would use a DVI input if i could but it does not come with one so I'm stumped, I've tried everything to my knowledge. Anyone have a suggestion?
  • immi1974 Sep 18, 2008
    Bought a load of these for our office. Out of the 40 we have had around 6 that do exactly this. While under warranty they were replaced by Acer. Now they aren't we have to bin them. It appears to be a hardware fault with the Acer. I would love to know if they can be fixed with new capacitors or the like. Am happy to solder to fix.
Riziel
  • 116 Answers
SOURCE: monitor goes black
Sorry to have to tell you this, but this is common in LCD monitors. The reason that it is going black when it boots is for one of two reasons. You either have a bad power supply that powers your LCD or your LCD's backlight is blown. These can be repaired or you can purchase a new one. But if it goes black 9 times out of 10 is because the backlight is bad. These can be repaired!
Posted on Nov 26, 2007
headstrong
  • 233 Answers
SOURCE: Acer AL1716 blank screen but powers.
Probably a bad inverter board, the inverter board powers the bulbs that display the image. this is VERY common problem on all LCD tv's,laptops and monitors.
usually a small transformer blows open on the inverter board. the innverter needs to be replaced if this is the this case.
Posted on Jan 05, 2008
Mark_Webber
  • 472 Answers
SOURCE: Acer LCD Monitor only displays "acer" logo
You are correct, it could be a power surge that has caused it.
Try this..
Unplug the monitor from the wall.
Remove all the video connections at the monitor end.
Wait 10 minutes then plug the monitor back into the wall (do not connect the video leads)
Turn it on and see if it goes past the ACER logo now. If so, replace the video cables and try the computer.
If not, then one of these will apply and a tech will be required..
  1. The internal bios has been corrupted.
  2. The power supply inside the monitor may have issues preventing the video board from starting correctly. This could be as simple as a few failing capacitors.
Number 2 is the most likely cause with an Acer monitor though. Any local tech will be able to correct it fairly cheaply, but phone around for quotes..they can vary a lot.
Posted on Jun 16, 2008
Fix-4U
  • 293 Answers
SOURCE: Acer AL1716 Blank screen & blinking green power LED
Hi..there,
You've got a busted backlight inverter... Need to replaced a new one...
Posted on Dec 18, 2008
budmrtn
  • 11361 Answers
SOURCE: acer al1716 monitor input not supported
You get the message because the game try to run at the PC video resolution that you monitor cannot display/support. You need to run your game at native resolution of the monitor.
Posted on Mar 25, 2010
What is the screen resolution for acer al1716 monitor
Hold the power button down for at least 10 seconds till the light goes out, then turn it on and the problem is gone.
May 16, 2010 | Acer AL1716 17" LCD Monitor
Acer al1716 monitor input not supported
Mar 25, 2010 | Acer AL1716 17" LCD Monitor
There is no indication of power to the monitor. I
You need to check the caps in the power supply section, please see my pictures here so you know what to look for inside.
http://s807.photobucket.com/albums/yy352/budm/ACER%20AL1716/
Feb 19, 2010 | Acer AL1716 17" LCD Monitor
Acer al1716 dont work
When the LCD monitor display flickers and or has a black screen then the fault is usually a faulty inverter or the CCFL lamp. When you look at the screen at a sharp angle and you see a dim image then it is a backlight problem and it is caused by a faulty inverter or a CCFL lamp.
Check out LCD Parts for parts, service, and DIY info. Use this link to their WEB site :-
www.lcdparts.net
Sep 03, 2009 | Acer AL1716 17" LCD Monitor
Mine is Acer AL1716 and doesn't display anything, I have black screen monitor.
this kind of problem is very common to acer due to hot pessure inside some of capacitor become budged. pls check the secondary power supply.
Jun 25, 2009 | Acer AL1717 17" LCD Monitor
Hi..there,
Dec 17, 2008 | Acer AL1716Bbd 17" LCD Monitor
MONITOR ACER AL1716
1. Unplug the AC power cord to make sure the power is off.
turn the monitor upside down, you need 2 people for this.
2. Pull the 4 hooks on bottom side of the base and hold.
3. Separate the monitor and base.
Nov 05, 2008 | Acer AL1716 17" LCD Monitor
Jan 05, 2008 | Acer AL1716Bbd 17" LCD Monitor
Head phone is not picked up the sound
check your line out pin thts a problem i think this is motherboard problem
Oct 31, 2007 | Acer TravelMate 3260-4874 Notebook
Acer AL1716Bbd 17" LCD Monitor Logo
69 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
