Home | Philips | 30PF9946 30 in. HDTV-Ready Plasma Television | I Have a Philips LCD TV ...
Philips 30PF9946 30 in. HDTV-Ready Plasma Television
Problem for Philips 30PF9946 30 in. HDTV-Ready Plasma Television
I Have a Philips LCD TV model#30PF9946D/37.
By kvladimirov on Nov 03, 2009
I Have a Philips LCD TV model#30PF9946D/37. Recently the picture disappeared and only sound and can change chanels too. I was told I need to repair the power supply! Can I change It my self ??? I read it's not so hard to replace the power supply board.Thanks!
Solution #1
posted on Nov 03, 2009
Somewhat Helpful)
mikeoldfield
Rank: Guru  Televisions & Videos  Expert
Rating: 97%, 23 votes
Oh yeah, you can most certainly change the power supply by yourself.
It's easy to locate - just follow the power cable - and easy to replace.
Only make sure to let it discharge before you operate it. 10-15 minutes disconnected from power should do.
However, there's no guarantee that the problem is in the power board.
There is a very good chance it is, in fact, not there.
There's another board which commonly fails on many plasma TVs and the effect is exactly as you describe. It's called Y-Sustain board and you can tell which one it is by looking at the side of your TV and seeing which large board has manny plastic connections that enter the display on the side.
That board often has one or two fuses on it - I'd check those first.
Was this helpful?
Yes
No
Solution #2
posted on Nov 11, 2009
Not Rated)
ohmsupplies
Rank: Apprentice  Televisions & Videos  Expert
Rating: 0%, 0 votes
You have an Inverter Board fault. This is an LCD TV.
Please check the links for a solution
http://www.ohmsupplies.co.uk/epages/62027733.sf/secMseDNBBr2Fo/?ObjectPath=/Shops/62027733
Was this helpful?
Yes
No
Popular Solutions for Philips 30PF9946 30 in.
Questions and Unsolved Problems for Philips 30PF9946 30 in.
Do you recommend Philips 30PF9946 30 in. HDTV-Ready Plasma Television?
Answer
Answer
When you turn on the tv the green on lite comes on for approx 10 seconds but no picture comes on. ... (More)
Answer
hp 50'' plasma. Tripped breaker and blew fuse on power supply. Replaced fuse. Disconnected Power... (More)
Answer
BEKO 22WLM550DHID LCD TV A CD will not eject. Any ideas please?
Answer
Have you fixed it or gotten rid of it yet? Because if not, I have a solution for you. I had the... (More)
Answer
I use this tv for a PC monitor, HD satellite viewing, and XBOX 360. I was having intermittent... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Philips 30PF9946 30 in....:
Top Flat Panel Television Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Flat Panel Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
