Question about Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher
Maytag quiet series won't quit wash cycle
My dishwasher won't quit cycling back through wash cycle.  It doesn't ever reach a dry cycle, just washes, drains, and repeats.  Does anybody have any advice? Thank you!
  • 5 more comments
  • mmbeavers Jan 04, 2008
    It is a Quiet Series 100.  Is there any other information that might be helpful? Thanks for helping.
  • NoelP Jan 08, 2008
    my dishwasher starts, does wash cycle..drains, than same cycle about 4-5 more times than goes to dry. one time 6 hours, but always shuts off.
    MDB5600AWB
  • may-not-work Sep 24, 2008
    same exact problem. the wash cycle never finishes.. 3hrs later still running.. I sure wish someone would post a result..
    model#: mdb5600awb
  • jendave17 Nov 09, 2008
    Same problem, does anybody have the fix
  • richpiccolot Nov 19, 2008
    Mine does the same thing. With the holidays coming I have enough to do let alone babysitting the dishwasher. Someone please help!!!
  • Anonymous Mar 31, 2014
    Whirlpool 980, Model #GU9880SCGB2. Repeats total cycle over and over.
  • 148 Answers
There is an eye located in the bottom of this model that tells when the dishes are "clean", food particles or even glass can become lodged in front of this and keep the dishwasher from reporting that the dishes are clean. You will have to remove the bottom filter to get to this, give the filters a good cleaning while your in there.
Posted on Nov 11, 2008
    President:
  • 1,314 Answers
Give me your model # its important thank you
Posted on Jan 04, 2008
  • robert samples Jan 05, 2008
    yep i need your serial num
Maytag quiet series 100 dishwasher won't complete a wash cycle - just keeps running and running until I turn it off after 2 or 3 hours
washer timer is faulty, gets stuck, if this occur more often , you definite need parts replacement on the washer timer switch.
Dec 28, 2013 | Maytag Washing Machines
Brand new Matytag MDB7749AWB Dishwasher does not work correctly. As soon as the power was turned on, all three cycle indicator lights ('Wash', 'Dry', and 'Clean') came on and always...
Try putting the unit into a test mode. This my clear your issues otherwise call for service.
One of two ways to do this.
In standby (no lights) Press the combination of buttons:
hi temp wash > sanitize > hi temp wash > sanitize > hi temp wash
All lights will come on and the washer will run a test cycle anywhere from 5 to 10 minutes.
If that button comb doesn't work use:
heated dry > sanitize > heated dry > sanitize > heated dry
May 27, 2011 | Maytag Dishwasher
I have a maytag dishwasher model # mdbtt70awb quiet series 300 when you push any of the wash cycle buttons nothing works. the only button that lights up is heated dry so there is at least power there....
I had the same issue try hitting delay 1hr and start the 1hr was solid not flashing and an hr later it's running just fine. Think I need a new control panel but for now this is working.
Sep 04, 2010 | Maytag Dishwashers
Maytag Quiet Series 200 dishwasher doesn't start
The electronic control panel has gotten wet and needs to be replaced (about $200 for parts plus about $200 for service call/labor) I just had mine replaced about 10 month ago, stopped using the type of dishwasher soap I had based on Maytag Service staff recommendation, stopped using hot wash to prevent high condensation at the door and now its broken again and in need of a new control panel again. You may be money ahead to go buy a new dishwasher that does not have the plastic encased control panel at the top. My understanding is the control panels are poorly engineered and made for most dishwasher manufactures by one of the mega electronic/appliance companies.
Dec 05, 2009 | Maytag EPIC MFW9700S Front Load Washer
Maytag Quiet Series dishwasher won't start
Sounds like you have a bad Control Board
http://www.partstore.com/Part/Maytag/Maytag/MDB6600AWW/Maytag/Maytag/99003160/New.aspx
But with the price it cost, you might be better off buying a new dishwasher, preferably a different brand, cause that washer has some bad reviews
Oct 12, 2009 | Dishwashers
Maytag dishwasher quiet series 400. Dishes have hard stuck on grit and food particles after rinsed and dried.
Very common problem is soap build up in these machines. Try putting it into a wash cycle with no dishes, and no soap. Let it wash for about 5 minutes, and then open the door. If you see alot of soap suds, then soap build up is the problem. Try doing a couple loads with no soap, and no dishes, and throw a cup of vinegar into the machine halfway through the wash. Repeat as necessary. This should solve your problem.
Mar 14, 2009 | Dishwashers
Dishwasher soap cup lid will not open during a wash cycle
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
jj
Dec 31, 2008 | Maytag 24 in. MDB5651A Built-in Dishwasher
Kenmore Dishwasher displays the number "98"
I have a very similar problem. When I push a wash selection, every light on the panel shows up...and when I push Start, nothing happens. When I push cancel, it trys to drain, even tho no water is in there any more. Have you ever had an answer to your problem?
Feb 06, 2008 | Kenmore 16872 Built-in Dishwasher
Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher Logo
390 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
