We've got the CT 420 and need any documentation and setting info for connecting it with Powerpath in order to print accession labels here in our pathology lab.
Is the printer showing solid green? any blinking red or green? It could also you need to reinstall the printer driver. If all fail, then it could be the printer itself is faulty.
The only places I found for the manual were pay sites. Here is one for you to choose from. They both were the same price. http://www.user-manuals.com/advanced_search_result.php?keywords=casio+ct-420+manual&forward=plist
1.Log into router 2. Verify wireless router name( on the computer) >>> ( on/off) 3.Note router name you are connecting to. 4.. Check the laptop,desktop,printer do ipconfig /all to see current IP addresses. 5. Set the laptop up in the router by WEP KEY or MAC address. 6.Note router name you are connecting to. 7. Move the device about 20ft away and try to log on to the internet. This is for all routers to set up wirelessly.
I am not sure is all Sato part numbers are the same across the globe so it may it may depend on your location if you go to the world wide stie at www.satoworldwide.com it can provide the support links in your area. If you are in America than you can go to www.satoamerica.com Click on Downloads then scroll down and click on Documentation and from there you canl click on Parts List and they are all available from that list new models as well as old models.
Although the system "sees" the drives, it also must have the new drives included in the RAID method you are using within the SAN system. Depending on the RAID type and controller used this can be accomplished in several ways but it should be done within your RAID manager. you are basically expanding the RAID. Then the SAN will be of the new dimensions.
CAUTION: backup first! Most RAID controllers can do this on the fly, but some will cause data loss during this operation!!!
I recommend that you use the drivers from www.seagullscientific.com, they have the best drivers and let you adjust all the printer settings. Roberto Martinez
2 ways you can determine the IP setup.
1: You can use Sato's ip net software, available from the Sato web page. This software will discover the printer on the network through a connected PC.
2: With the NIC carad inserted, the IP address can be set through the front panel by depressing the line key while powering up the printer. You can scroll through to the settings and change to the needed IP address
