Question about Toshiba Satellite A105-S4004 Notebook
Boot failure I have a toshiba satellite pro, it was working very well but suddenly one day got this problem, when I press the power button nothing happen it did not boot,but the power led is on after pressing the power led goes off.tried to boot also with battery alone,tried also with current alone without battery, but still my portable is able to charge its battery, one thing sure there's current coming in but press the power button it goes off, PLEASE HELP.,,,,THANKS
  • 233 Answers
Does it beep at all?
take it into a dark room, can you see anything on the screen, even if it's very faint?
take battery off and plug in same thing?
Posted on Jan 04, 2008
Toshiba lap top - satellite - when i turn it on it brings up a black screen with red writing - saying TOSHIBA and under that it says press F2 for boot selection - pressing f2 does nothing - if i hold
try pressing the F2 key during the boot process to enter set up (bios)
using the arrow keys navigate to advanced bios features press enter make sure its set to boot from your hard drive
press F10 to save to cmos restart
hope the helps
Oct 06, 2012 | Toshiba Satellite Computers & Internet
My granddaughter pushed the F2 button while the start screen was on. how do i get out of this i keeps saying media test failure exiting PXE ROM
The F2 function on this laptop merely cycles the power plans (see link below)
http://static.compusa.com/pdf/Toshiba-Satellite-Pro-S300-Laptop-Manual.pdf
The symptom you describe is that of the OS or a boot device not being recognised. Try removing any USB dongles from the laptop if any are plugged in, eject any CDs in the tray and retry
If this does not work, as the laptop starts up, press the ( I think) F1 key and enter the Bios, see if in the BOOT screen, the hard drive and CDRom are shown. Repost your findings for more guidance
Dec 28, 2010 | Toshiba Satellite Pro S300-EZ2501 Laptops
My Toshiba Satellite pro s300 ez2501 , is being stuck and fan should run fastly with rough sound, we cant do any thing at this time, only function key can work but nothing will happened.
This is an open ended question as I am not aware of your problem, however,
Disconnect your power supply and remove the battery.
Refit the battery and plug in the AC adaptor, check the power light and battery light are illuminated.
Keep disconnect any periferals, (USB devices) and ensure the DVD drawer is empty. Press the power button. The POST should now start up flashing a line of led's across the top of the keyboard first followed by the hard drive light.
The BIOS F2 or F12 choice screen will now appear. If it doesn't the laptop hasn't completed POST and can go no further however, if it gets that far;
Press F12 and select Hard Drive for the boot device, the laptop will then try and boot from the hard drive, just as the boot chioce menu dissapears press F8, this will opem a further menu allowing you to repair your system. This, if selected, will collect data stored on drive E and repair the main system putting the OS back as it was when you first purchased the machine.
If that won't work or there is a corrupt file or serious error, you will require an OS system disk.
Place the System disk in the DVD drive, press power until the system tries to boot and when you get to the boot selection menu, press F12 again but select CD/DVD as the boot drive.
Follow my last instructions again and you will have a fresh/repaired system and a working laptop again.
When all is OK go to www.computers.toshiba-europe.com and let toshiba download and install the latest drivers and BIOS.
Hope that helps.
Nov 25, 2010 | Toshiba Satellite Pro S300-EZ2501 Laptops
MY TOSHIBA SATELLITE PRO LAPTOP WONT GO PAST THE WINDOWS XP LOGO SCREEN AND HAS BEEN FROZEN LIKE THAT FOR HOURS BUT THE LOADING BAR IS STILL MOVING
Hi Good day!!! Try to boot in safe mode, to boot from safe mode, do this: while booting just keep pressing f8 button until advanced boot menu appear after that choose safemode. after that your OS will boot in safemode. if not booting there should be a files missing in your OS you will need to repair it using a CD of you OS. reply to me to help you more
Thank you for using FixYA
Please accept if my solution helps you
Nov 24, 2010 | Toshiba Satellite Pro L300 Notebook
My toshiba Satellite A215-S7422 System unit, dose not shut down until the batries runs down.
1. It means the normal shutdown process is not working!
2. Try to press the "Power" button continuously untill the system shuts down!
3. Restart the system.
4. Press F8 key to get the advanced booting options.
5. Select the last option "Last Known Best Configuration"!
if it don't helps tell me...tc! :)
Jan 05, 2010 | Toshiba Satellite Pro A210-EZ2202X...
Cant get into the BIOS on toshiba satellite pro 6000i've tried several things on boot up but the only thing i can get to is boot order.
press F8 after u press the power on button...it will get u into BIOS....if ur F8 function key is not working then try Alt Del together....
Dec 28, 2009 | Toshiba Satellite Pro 6000 Notebook
Starts then shuts off.
Go to ur toshiba website and enter ur service tag...u might see few recommended downloads...Der download the bios driver and save it in a usb and boot the system from usb...if the bios is corrupted this will rectify the problem..if else u need to change the motherboard...
Jul 13, 2009 | Toshiba Satellite A75-S206 Notebook
Toshiba Satellite A200 -AH9 Wont Turn On.
maybe you have power conection problem
your problem maybe on the circuit after the battery
so you must check your circuit
or you can contact your Laptop manufucturers
Jan 21, 2009 | Toshiba Satellite A15-S129 Notebook
Toshiba S200 not starting.power LED blinking with beep sound
Please try to take out the battery and power on using the ac adapter alone. If it works, it is okay to put the battery back in. Leave battery in for a few minutes then try to restart using the battery alone. Hope this helps. Thank you.
Oct 02, 2008 | Toshiba Satellite A105-S2001 Notebook
Toshiba satellite pro l40 boot up problem
If you run a repair with the recovery disc you won't lose any info. The only time you'll lose the info is if you run a complete reload. Run the system disc until it gets to the point of finding installed operating systems, at this point instead of deleting the partition, press R and it will reinstall the operating system files only leaving other installed files and programs intact. Keep in mind that many times when this happens, it's a hard drive failure. If it is a hard drive failure, then you will have to replace the hard drive and you will lose the info, sorry.
Jul 02, 2008 | Toshiba Satellite A135-S2276 Notebook
Open Questions:
See all Toshiba Satellite A105-S4004 Notebook Questions
Toshiba Satellite A105-S4004 Notebook Logo
140 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
