This is odd, one issue may be the external button may not be making contact with the button underneath if you're feeling brave you can try and pop the panel between the keyboard and the screen off and try and press the button manually and see if that helps, if not there may be a problem with the actual AC jack itself. Are you getting a charge light when the laptop is plugged in? It's also possible that your AC adapter may have gone bad. the only way to test this that i can think of offhand is to use a multi-meter and see if you are getting the correct voltage from the plug. good luck and let me know what you figure out
hello my laptop the green power light comes on and the fan runs...but nothing else happens and the...
(More)
hello my laptop the green power light comes on and the fan runs...but nothing else happens and the screen is black
my acer aspire 3680 sd card will not read anything. this same laptop also will take 10 minutes 2...
(More)
MY ACER ASPIRE 3680 SD card will not read anything. THis same laptop also will take 10 minutes 2 open a folder in windows Explorer. It has also reverted back to the classic theme permanatly.The Basic Specs of my System are: Windows Vista Home Basic Service Pack 2 32 Bit Operating System. The Manufacturer is Acer the Model is Aspire 3680. The Processor is an Intel Celeron M CPU 440 @1.86GHz 1.87GHz. I Have 2.00GB of RAM
my acer aspire will not start,power light comes on for a few seconds and goes back of.I have the ac...
(More)
my acer aspire will not start,power light comes on for a few seconds and goes back of.I have the ac power on.
Acer Aspire 3680 Laptop/Notebook 80GB 14-WXGA Vista Acer Aspire 3680 will not boot up Answer Acer...
(More)
Acer Aspire 3680 Laptop/Notebook 80GB 14-WXGA Vista Acer Aspire 3680 will not boot up Answer Acer Aspire 3680 will not boot up
