Power supply jack on Acer Aspire 3680 Laptop not macking connection. checked power supply and it is putting out 19.2 volts. How do I go about changing jack?
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot fix this yourself then I suggest you get a quote first.
Acer Aspire 3680 Laptop/Notebook 80GB 14-WXGA Vista Acer Aspire 3680 will not boot up Answer Acer...
(More)
Acer Aspire 3680 Laptop/Notebook 80GB 14-WXGA Vista Acer Aspire 3680 will not boot up Answer Acer Aspire 3680 will not boot up
isatap #14, 15,16 is flaged on the computer. what does that mean...does it have anything to do with...
(More)
isatap #14, 15,16 is flaged on the computer. what does that mean...does it have anything to do with not being to watch any thing on the net?
i have problem with my ctrl key it is always pressed example when i press only (F)then its open find...
(More)
i have problem with my ctrl key it is always pressed example when i press only (F)then its open find window.
