My fax machine cannot receive fax or send to all stations
I need to know if I can change my baud rate to 1600. Als can I shut off ECM.
  • 1 more comment
  • Lloyd344 Jan 05, 2008
    Baud rate explanation is okay but there is a part two to my question.
    part two can ECM be shut off?
    The reason I said it was inappropriate was you shoukd know the fax machine that I have as I have given it to yoyu many times. Here it is again. Fax-885mc.
    Now can ECM be turned off!
  • jamiehurst Mar 27, 2008
    Does anyone know how to change the baud rate on a canon i sensys 4140 also how to turn the ecm off?
  • 159 Answers
Make and model of fax machine? and no you can't fall back to 1600.
Posted on Jan 05, 2008
  • Rob Fauchon
    Rob Fauchon Jan 05, 2008
    Usually ECM can be set to off. Each machine is different tho. Sometimes ECM is set by user and the switch is accessed through system settings. Sometimes it is set trough service access. Depends on machine.
  • Rob Fauchon
    Look, I don't know who you think you are conversing with. I am simply a volunteer willing to share my knowledge. Innapprpriate or not, I have never heard of you before. Now take it or leave it.
How do I access system settings to change the baud rate and turn off ECM.Thanks in advance.
Fax settings for VoIP ' How to lower the Baud Rate ' Faxing ...
How to Lower the BAUD rate to 9600 on fax machines for better VoIP faxing success.
Faxing over VoIP, the correct configuration settings that you ...
How to fax over VoIP and the settings and configurations, like BAUD rate that you need to set.
Dell VoIP Fax Settings, how to lower the BAUD rate and ...
VoIP Fax settings for Dell printer/fax machines/multi-purpose machines.Missing: kyocera
Faxing over VoIP - Sfax
Dec 15, 2015 | Kyocera FS-1128MFP FS-1128MFP...
Whenever i send a fax, the machine confirms by viewing 'TRANSMITTING OK' but the addressee receives a blank document
Check the baud rate of your transmissions. Slow them down to the slowest setting and send a test fax to a helpful person. Slowly increase the baud rate (communication data speed) and send the fax test. When the fax doesn't show up on the receive site, then step one baud rate speed back, and save the setting.
It could also be your fax that is faulty, or even the receive sites fax, also being faulty.
To test your copy-head, insert a document into your loading section of the fax and press copy. If the copy prints out fine, then you know the head is reading correctly.
It is also possible that the receiver fax (the other end) has a printhead failure.
Nov 25, 2013 | Canon FAX-JX200
Change baud rate on okifax 5050
The baud rate is automatically set by the machine when it connects to the remote machine. The machines start at the highest speed and drop down until both machines can send/receive without any errors then they send the pages. You can not manually set the speed.
Feb 27, 2012 | OKI Office Equipment & Supplies
How do I change the baud rate to 9600 on an HP Laserjet All in one 3015
The baud rate is usually determined by the receiving machine. When one fax contacts another, they negotiate their send/receive rates. That's an automatic function and not generally adjustable on modern faxes.
Nov 26, 2009 | Office Equipment & Supplies
Need the baud rate to be 9600
fax machines are ANALOG devices and will not work reliably on a DIGITAL phone line.
Dec 03, 2008 | Brother IntelliFAX 2800 Laser Fax
Sending fax
Wow. Digital lines are difficult to fax over. Most are still set to use analogue lines.
Those are also very odd changes. Most fax machines no longer even have a setting as low as 9600 baud.
Your fax may not have the ECM mode as changable, may just be built in, but that is not a function you normally would want to turn off. ECM is Error Correction Mode.
This honestly just sounds like a disclaimer to excuse their system's poor fax service.
Mar 16, 2008 | Panasonic KX-FPG376 Plain Paper Thermal...
Baud rate
# Lower the fax transmission speed to 14400 or even 9600 bps, as some older fax machines are not capable of receiving a fax at a high speed. To do so:
1. Press the Fax button, then press Options untill it gets to ADVANCED FAX.
2. Press Select.
3. Press Options untill it getsl MAX SEND SPEED appears on the LCD display.
4. Change it to 9600 BPS using the - (left arrow) button.
5. Press Select.
# Turn off ECM (Error Correction Mode) by pressing the following keys on the operator panel:
1. Press the Fax button, then press Option untill it gets to ADVANCED FAX.
2. Press Select.
3. Press Options until ERROR CORRECTION appears on the LCD display.
4. Change the setting from On to Off using the + (right arrow) button.
5. Press Select.
Note: Turning off this option makes it possible to receive a fax when the receiver fax machine does not support certain error correction modes.
Mar 15, 2008 | Lexmark X5470 All-In-One InkJet Printer
Any way to manually LOWER the Fax Connection Baud Rate?
Newer fax technology adjusts transmission speed automatcally, so no adjustment is necesary. therefore, there is no menu option to change it. Your problem resides either on your phone line or the one you are trying to connect to. Call the other people and ask them if thei are receiving without problem. If you are able to transmit elsewhere and the other party is receiving from everywhere, try turning off the ECM option on your unit.
Oct 27, 2007 | Samsung SCX 4521F All-In-One Laser Printer
467 people viewed this question
