Question about Onkyo HT-SR800 System
No sound today after wrong button on remote ??
My HT-SR800 had been working fine, and still works normal with a DVD. But when my wife turned the system off, I think she accidently hit a wrong button on the remote before shutting it off. (remote for system being used, and a separate one for the T.V. and cable) Now today when turning on T.V. picture appears as normal, and the when turning sound on separate as in past I have no sound with my T.V. I tried everything I know to try with the remote, and manually with the receiver also. Any suggestions as to what i'm doing wrong. I checked the input button to make sure it is on cable..any help greatly appreciated
  • bacchus 63 Feb 08, 2008
    I have the same problem as Capt4. I have sound with the DVD, radio, but after my wife turned of the TV last night I don't have any sound trow the speakers. I need help please
    Thanks
I had this happen with mine also and finally determined the A/B speaker. That is my only experience.
Posted on Jan 06, 2008
Remote control failure with Onkyo HT-SR800
If you have several audio/video devices, which is probably the case if you have this system, you might consider buying a Logitech Harmony All in One remote.
I got one as a present - it now controls all my devices intelligently and is fully programmable to switch all boxes to the correct settings for a particular activity with one button. It connects to a pc with a simple but sophisticated GUI to set up, and codes for hundreds of devices are available and automatically downloaded.
Brilliant, and my wife can now use our systems without having to ask me what to do! It even has an on screen help function.
Jan 22, 2010 | Onkyo HT-SR800 System
TV to Reciever Sound Problems
MAke sure your channel selection is correct.
Sep 17, 2007 | Onkyo HT-SR800 System
Onkyo ht-557; picture dropped out, now just green screen
don´t you activate the progressive scan by mistake
Apr 23, 2009 | Onkyo HT-SR800 System
Samsung HT-A100 Home Cinema system plays cd only with tv on!
You need to put away the remote for your TV and use only the remote for your HT system. Your HT remote should work on your TV by default. Your Samsung HT remote should have a TV button and a DVD/Receiver button (or HT button). When using only the TV, press the TV button and then use it for just the TV and when using the HT system, press the DVD/Receiver button and then you can use the HT system.
If for some reason your TV is not set on the Samsung HT remote by default, your HT users manual should have a list of codes that you can use to program your HT remote. Hope that helps you. Gary
Mar 18, 2009 | Samsung HT-A100T Theater System
Onkyo HT-SR800 won't turn on
If you call Onkyo directly, 201-785-2600, there is a procedure to "reset" the system, something like holding the power button on and holding down another button for a few seconds. Can't remember which, so I can't be sure, but try giving them a call.
Jan 02, 2009 | Onkyo HT-SR800 System
SONY KP 51WS500 - Volume & Menu won't stay on
This would be weird for a sony but it sounds like the volume down button on the front of the set is stuck...very very uncommon for a sony. Try taking the bottom front cover off the set and unpluging the button assyembly then see if the remote works the set with it unpluged.
Tim nolan
Sep 17, 2008 | Sony KP-51WS500 51" Rear Projection...
Cutting off and stayin in Stand by mode
To me it sounds like you might have blown a channel(s). The speakers that you are using with unit, did they come with it? If not you need to check the ohms of the speakers. It looks like the Onkyo HT-SR800 can only handle a minimum of 8 ohms. If your unit is under warranty definately send it in for repair
Jun 03, 2008 | Onkyo HT-SR800 System
ONKYO HT-SR800 REMOTE CONTROL CODE FOR PIONEER CD
PD-M406 units came without remote control. Try the code for PD-M426? I'm not sure 406 will remote.
Jan 03, 2008 | Televison & Video
Surround sound
It must be about the sound quality need of your amplifier. The sound processor simply needs to get clear signals from sources such as fm/am receiver, dvd/cd players etc. in order to manage'em to give you the optimum surround sound. If the fm receiver has an "FM MUTE" option, I recommend that you turn it on. By doing so, you'll receive only good quality fm stations, furthermore your amplifier will let you get surround sound. The second issue you mentioned has its own answer inside. Use a "new" cd player, you can get optical cables, digital coax cables to improve the performance if you like..
Jun 07, 2007 | Onkyo HT-SR800 System
CORRECT SETUP CODE FOR RECEIVER
that is because i think that your reciever would have its own code
Jan 29, 2007 | Onkyo HT-S790S System
Onkyo HT-SR800 System Logo
179 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
