Question about Dell Precision 360n PC Desktop
Memory upgrade I had 128MB x 2 ECC RAM in my precision 360N. I bought 1GBx2 Dual Channel DDR 400 MHz PC3200 non-ECC memory according to When I replaced the old sticks, computer made some beep sound but did not boot-up at all (black screen through out). Can someone help me?
  • 264 Answers
It sounds like you put the wrong memory in it you will have to take it to some one to rest the BIOS and upgrade the Bord
Posted on Jan 04, 2008
  • 2,351 Answers
Chances are you just need to reseat memory. Make sure the slot in the memory lines up with the DIMM. Flashlight helps.
Below is a link about BIOS beep codes & what they mean
There are others on the far right, like AMI ect
I bought 2 x 1 GB 128M x 72 333MHz PC2700 DDR SDRAM cards to upgrade my HP Compaq dx 6100 MT Pentium 4 Desktop - Upgraded the BIOS as prescribed...BUT if i insert these memory cards in any order in the...
wrong parts, its not support by chipset
One of the following
2-GB DDR Synch Dram PC3200 (400-MHz) Non ECC (2x 1GB)
Memory Speed Supported DDR Synch DRAM PC3200 (400MHz) non-ECC
Product documentation
Dec 20, 2014 | HP Computers & Internet
Got an AsRock P4i65G mobo and bought 2 gig RAM for it. However, I have bought ECC memory by mistake instead of Non-ECC. PC wont boot with the new RAM. Is there any way I can get this to work such as with...
Hi, you can download a manual here:
This ram type is ONLY intended for servers
or mainboards that are compatible for that ram type.
This is what your mainboard supports:
Dual Channel DDR memory technology
- 2 x DDR DIMM slots
- Supports DDR400/333/266 non-ECC, un-buffered memory
- Max. capacity of system memory: 2GB
Use only the asrock site when upgrading the bios.
And a bios upgrade does not supports the ecc ram anyway.
Hope this will help you.
Aug 20, 2011 | Asrock P4i65G Motherboard
I bought P3200 ddr 400 1gb memory and when i install it , it does not show up. any ideas why and if there is something i can do .
The Intel® Server Board S875WP1-E supports both ECC and Non ECC Unbuffered PC2100 (266 MHz), PC2700 (333 MHz), or PC3200 (400 MHz) compliant Double Data Rate (DDR) memory modules. Dual channel memory functionality requires two DIMM modules installed into DIMM sockets 1A & 1B, and then DIMM sockets 2A & 2B. The DIMM module size, speed and vendor must be the same.
You can install a single 128 MB memory module into DIMM socket 1A. The minimum supported memory size is 128 MB. The minimum main memory configuration is a single 128 MB memory module, and the maximum configurable memory size is 4GB. With only a single memory module installed, the system will only operate using a one memory channel.
Third party memory vendors may use the same module part number with different
DRAM vendors and die revisions. To insure proper system operation, verify that each DRAM
vendor and die revision has been separately tested and qualified. Please notify CMTL if there is a discrepancy.
Apr 10, 2011 | Intel Server Board S875WP1-E (S875WP1LX)...
What is the max dual channel ram i can put iin my msi 865pe neo2 motherboard.
Hi merlin_65,
Regardin your question:
• Supports four unbuffered DIMM of 2.5V DDR DRAM.
• Supports up to 4GB memory size without ECC.
• Supports Dual channel DDR266/333/400/433/466/500/533 MHz and up. (DDR433/466/500/533 are overclocking spec).
Hope this helps.
Feb 22, 2011 | MSI : 865PE Neo2 (Platinum Edition)...
HP Pavilion Media Center PC not detecting memory in slots 3 & 4.All memory works in slots 1 &2.Memory is all the same.
Info from the manual:
Memory configurations
You can install 128 MB, 256 MB, 512 MB, and 1GB DDR SDRAM DIMMs into the DIMM sockets using the memory configurations in this section.
• Install only identical (the same type and size) DDR DIMM pairs
using the recommended configurations.
• Make sure that the memory frequency matches the CPU FSB
(Front Side Bus). Refer to the Memory frequency/CPU FSB
synchronization table on the next page.
• This motherboard does not support double-sided 16-bit DDR DIMMs.
• Do not create a three-DIMM configuration in dual-channel mode. The
third DIMM is ignored in the dual-channel operation.
Recommended memory configurations
Memory frequency/CPU FSB synchronization
* Use only identical DDR DIMM pairs.
Single-channel (1) Installed - - -
(2) - Installed - -
(3) - - Installed -
(4) - - - Installed
Dual-channel* (1) Installed - Installed -
(2) - Installed - Installed
(3) Installed Installed Installed Installed
CPU FSB DDR DIMM Type Memory Frequency
800 MHz PC3200 400 MHz
533 MHz PC3200/PC2700 400/333 MHz
Feb 18, 2011 | ASUS PTGD-LA Motherboard
I wish to add RAM in the PC. Mine motherboard-Epox-EP-4BDA533(I). ID(identification)-05/09/2003-i845d-6A69VPA8C-00. On it costs RAM 256Mb -DDR PC2100 266Mg FSB-400Mg. How many Mb it is possible to add....
Manufacturer Specifications - EPoX EP-4BDA533I Number of Slots:
Slot 1
Slot 2
Each memory slot can hold DDR PC2700,DDR PC3200 with a maximum of 1GB per slot.*
*Not to exceed manufacturer supported memory.
  • 184-pin DIMM Banking: 2 (2 banks of 1)
  • Chipset: Intel 845D
  • Error Detection Support: ECC and non-ECC
  • Graphics Support: AGP 4X
  • Max Component Density: 512Mb
  • Max Unbuffered DDR SDRAM: 2048MB
  • Module Types Supported: Unbuffered only
  • Supported DRAM Types: DDR SDRAM only
  • USB Support: 1.x Compliant
Q: What memory goes into my computer, and will a faster speed be backward-compatible?
A: DDR memory with support for DDR PC2700,DDR PC3200 speeds.
Because DDR memory is backward-compatible, you can safely upgrade your system with any of the guaranteed-compatible DDR speeds listed below, even if your manual calls for PC1600 or PC2100 speeds.
Q: How much memory can my computer handle?
A: 2048MB.
Adding the maximum amount of memory will improve performance and help extend the useful life of your system as you run increasingly demanding software applications in the future.
Q: Do I have to install matching pairs?
A: No.
No, you can install modules one at a time, and you can mix different densities of modules in your computer. But if your computer supports dual-channel memory configurations, you should install in identical pairs (preferably in kits) for optimal performance.
Q: Does my computer support dual-channel memory?
A: No.
Your system does not support dual channel.
Q: Does my computer support ECC memory?
A: Yes.
Your system supports ECC. You can put non-ECC modules into an ECC system, but be sure not to mix ECC and non-ECC modules within a system. Install the same type of modules that are already in your system.
Jan 13, 2010 | ASUS Intel 845D Chipset P4B266 (P4B266-PA)...
Hi can u tell me how to choose RAM for my motherboard?D865gbf board, need to upgrade memory.
this motherboard supports Dual Channel DDR 400 MHz (PC3200), 333 MHz (PC2700), and 266 MHz (PC2100)
the limit is 4gb RAM
Jul 13, 2009 | Intel D865GBF Motherboard
I have an Elitegroup KT600-A motherboard (System model KT600 8236) manufatcturer VIA Technologies, Inc. with total physical memormy 640K. Processor is x86 Family 6 Model 4 Stepping 2 Authentic AMD ~998...
Hello, according to your boards manual page 38 you will have to use unbuffered memory (non-ecc) and depending on which OS your are gonna use, it might address up to 3 GBs of (SDRAM) my personal preferrence is 3x1 GBs with XP Pro 32 bits. The CPU you mentioned should work just fine, and with the added memory your rig should provide you better performance, hope this little bit of info helps.
May 09, 2009 | Intel Desktop Board D845GLVA...
Dell Demension 4600 motherboard memory
From the Dell specifications page for Dimension 4600:
Dual Channel DDR SDRAM
Memory connectors
Memory capacities
128-, 256-, 512-MB or 1-GB
Minimum memory
NOTE: Between 32 and 64 MB of system memory may be allocated to support graphics, depending on system memory size and other factors.
Maximum memory
4 GB
Memory type
PC2700 (333-MHz) or PC3200 (400-MHz) DDR SDRAM
Mar 09, 2009 | Dell (2336V) Motherboard
I need more memory on my hp m7248n media center pc, what product should I buy and what is the maximum memory I can get on my computer?
This is from HP.
  • Four 184-pin DDR DIMM sockets
  • Supports dual channel, eight memory banks DDR 333/400 DDR DIMMs
  • Supports 2.5v DDR SDRAM DIMMs
  • Maximum HP/Compaq approved memory is 4 GB* without ECC
4 Sticks of PC3200 400 Mhz is max.
Jan 19, 2008 | Computers & Internet
Dell Precision 360n PC Desktop Logo
200 people viewed this question
Alun Cox
