Maytag MER6772 Gemini Electric Kitchen Range
Problem for Maytag MER6772 Gemini Electric Kitchen Range
The lower oven door locked shut.
By kkriccomini on Nov 03, 2009
The lower oven door locked shut. Accidently pushed wrong button & lower oven locked and I can not get it to open.
Solution #1
posted on Nov 03, 2009
Not Rated)
jyappl
Rank: Guru
Rating: 89%, 29 votes
stop pushing all the buttons. Turn the power off for a few min. It should un lock when power is back. If not set clock, set oven into clean cycle, wate a few min then hit cancle. wate till door unlocks. If nothing happens make sure you dident hit the child lock button. It looks like a pad lock on touch pannel. push and hold it to unlock. Re try clean cycle. let it lock then wate ,then cancle .
Was this helpful?
Yes
No
Popular Solutions for Maytag MER6772 Gemini Electric
Questions and Unsolved Problems for Maytag MER6772 Gemini Electric
Do you recommend Maytag MER6772 Gemini Electric Kitchen Range?
Answer
Answer
maytag gemini range; First I had the ignition spark clicking and would not stop then there was a... (More)
Answer
I have a Maytag MER6771 Gemini Electric Range. When I turn on the oven, none of the buttons work on... (More)
Answer
getting error f2-9 and f1-a can you help this is on a maytag gemini double oven electric
Answer
hi, the top oven only works randomly. Bottom oven can only be set to auto -325.
Answer
f1-1 error code Replaced top oven sensor, when I use the bottom oven the same code. when I use... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Kitchen Ranges Experts
Top Range & Oven Repairmen
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
(972) 859-0929
Honest, Dependable, Available &...
Accurate Appliance Repair & Parts Supply
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
