Question about Carrier IBM UNIT 2380 79F4796 Drive Case
Carrier FA4ANF030 Unit works non-stop trying to hit a house. To get from 70 to 74F took whole night. Any solution????????
2 Suggested Answers
SOURCE: carrier RADCO unit FA4ANF030
the best thing to use is any alkaline base with water
Posted on Aug 27, 2007
Carrier fa4anf030
Sounds like the reversing valve is the problem
The reversing valve is located near the compressor
It has four copper tubes coming from it
On this valve there is a solenoid which makes the valve open or close
You can check this by placing a strong magnet on it while the system is running which will activate or de activate the heating
You should hear a swoshing sound if it's working properly each time you remove the magnet if this doesn't happen it will need to be replaced by a licensed refrigeration technician if it does work you may have a gas leak which will require a friggy as well
Jan 04, 2014 | Carrier Computers & Internet
My blower motor works intermttently. If it stops i hit the motor and it usualy starts again. Can anyone help?
Had same thing, dealer replaced motor, started same thing. I took motor out cleaned, put 3 small washer between motor & housing. Bolted up, fan was hitting housing & stopping or rubbing. Just needed space between motor & housing. That was 2 yrs ago.
Jan 03, 2013 | 2004 Dodge Ram 1500
I have a carrier air conditioner 38TKB024. About 15 years old I think. Accidentally ran it with the cover still on after the winter. shut it off after about a day when I realized. Went to try it the next...
Hopefully its just the run capacitor that is shorted. The run capacitor looks like a big battery, located in the electrical section of the outdoor unit. If it is shorted, it will be "pregnant" or bloated. Not a very expensive part until you have to call somebody out to change it.
Jun 16, 2011 | Carrier KCA101P Air Conditioner
Our carrier air conditioner failed to cool down the house last night. changed the filter and still struggling to cool house down.
is it cooling some at night but none during the day basically ? Outside unit clean also ? Good airflow ? if yes on all of these feel the copper pipes that go inside the house from the outside and once a/c has been on for a few minutes the large line should be very cool or cold to where it would condensate.. Sometimes it may take up to 15 minutes..
Aug 20, 2010 | Carrier 38CKC024 Air Conditioner
Carrier Air V unit with loud noise
If it sounds like a scraping noise it could be the motor bracket ah broken and the squirrel cage (fan assembly) is hitting the fan housing, if it is more of a squeal than it very well could be a bearing. Very hard to guess without seeing or hearing it.
Nov 02, 2009 | Carrier Heating & Cooling
AC blower runs but compressor will not.
It could be the CONTACTOR. It could be dirty and when the system calls to run, the contactor won't make contact and complete the circuit. Worse case scenario, compressor is siezed up. If you hear a clicking noise at the condensing unit where the compressor is located, that could be the overload protector clicking and breaking the circuit if the compressor is seized up. Good luck. I hope it is a contactor or a capacitor.
May 31, 2009 | Heating & Cooling
Intermittent heat
It sounds like the unit has lost its first stage of Heat (It uses the outside unit to bring heat in with freon) When the thermostat is put 3deg higher than room temp it uses Heat Pump and heat strips, this is probably the only time yours heats. Have it checked as you will pay a lot on next month's electric bill.
Jan 19, 2008 | Heating & Cooling
Carrier RADCO unit FA4ANF030
Aug 16, 2006 | Carrier IBM UNIT 2380 79F4796 Drive Case
Computers & Internet Logo
248 people viewed this question
Top Carrier Computers & Internet Experts
Marvin
Marvin
Paul Carew
 steve
steve
Are you a Carrier Computer and Internet Expert? Answer questions, earn points and help others
