my furnace works intermitantly. I cycle the power and it will work for 10 min. to 10 hrs. I appears as though it is blinking 3 times when it is not working. It indicates " internal error". Replace board?
-   I had an A/C guy out last week. He said I needed to replace the circuit board. I found one on the internet at bestbuy ac and heating for 267.00. I will probably replace mine in next couple of weeks.
Aprilaire Humidifier Mod 450-high whine from recirculating pump. Oiled motor per spec-same problem...
(More)
Aprilaire Humidifier Mod 450-high whine from recirculating pump. Oiled motor per spec-same problem exists- Thanks, Richard
I have my Honeywell Chrontherm III set on adaptive intelligent recovery. It is set on...
(More)
I have my Honeywell Chrontherm III set on adaptive intelligent recovery. It is set on "Leave" at 58 degrees at 7am and "Return" at 66 degrees at 4pm. The unit starts heating the house at 12noon to move it 8 degrees. According to the directions it should only kick on a max of 24 minutes per degree not 4 hours - any suggestions?
MY TruIAQ will read outside settings, and other times there are no readings for outside temps and...
(More)
MY TruIAQ will read outside settings, and other times there are no readings for outside temps and humidity. what could be wrong?
i just replaced solenoid and humidistat onn my furnace himidifier but when i turn on humidistat to...
(More)
i just replaced solenoid and humidistat onn my furnace himidifier but when i turn on humidistat to outside temp,and the blower turns off ,the humidifier water still comes into humidifier and wont shut offf unless i turn humidistat to off position
