Home | IBM | ThinkPad T41 PC Notebook | How to fix black screen?
IBM ThinkPad T41 PC Notebook
Problem for IBM ThinkPad T41 PC Notebook
By hello1002062 on Nov 03, 2009
Solution #1
posted on Nov 03, 2009
Not Rated)
jennifer720
Rank: Guru  Computer Hardware  Expert
Rating: 88%, 152 votes
Hello and thank you for using Fixya's services.
I have a couple of questions and some troubleshooting tips for you:
Questions: Is the splash screen coming on at all? Any picture or text right when you boot up? What Windows are you running (Windows XP or Vista)? Are there any lights on when you boot up or beeps? If so how many beeps do you hear?
First troubleshooting: If it boots up and is at least showing the splash screen (IBM splash screen or text) then it would be that the operating system is corrupt. This can be caused by several things included viruses, power surges or hardware failure.
The solution for this would be to take the hard drive out and slave it to another working desktop computer to retrieve your data. The attach the hard drive back on and reformat it (I can add specifics to doing this once I know the operating system).
Second troubleshooting: If you hear the operating system chime but do not see a picture and all the lights are on, then this would indicate that the back light on the screen is out. You can test this simply by hooking the laptop up to a monitor and see if you get a picture. If the computer screen shows on the monitor, then your back-light is out. If it doesn't show up then your video graphics card is out.
If the back light is out, it is easier to order a new screen (new or used) from eBay and just switch out (simple process and you can find a replacement for under 50 dollars on eBay). If it is the video graphics card, then you can also purchase one from eBay and switch out (a little tougher because you have to take the top of the laptop off). You can get assistance with this from the manufacturers website and pull specs for free.
Third troubleshooting: If you do not hear any beeps and the above solutions did not work. Then your motherboard has failed. This can be caused by surges or dust. You can purchase a replacement from eBay for a fraction of the cost and replace (this is tough and I am not sure if they have specs for this). You can do it yourself, just be sure and put everything back together as it was.
Fourth troubleshooting: To test the battery, take the battery out of the laptop and turn on with just the adaptor. If it boots, then the battery will need to be replaced. There is no way of testing the power adaptor but 85% of the time, this is the problem. Even if lights come on, the adaptor sometimes gets so overheated that it silently goes out but gives just enough power to make the lights come on. The power adaptor can be found on eBay for under 20 dollars and is cheap enough to replace (first) to make sure that is not the problem. The battery can also be found on eBay for under 60 dollars.
Please let me know if you have any questions and I will be glad to assist.
Was this helpful?
Yes
No
Popular Solutions for IBM ThinkPad T41 PC Notebook
Questions and Unsolved Problems for IBM ThinkPad T41 PC Notebook
Do you recommend IBM ThinkPad T41 PC Notebook?
Answer
Answer
I bought used ibm t41 with windows xp pro. I need picture of layout so I know what all keys do.
Answer
Have Thinkpad t41 running XP Professional. Trying to connect to netzero dialup. Get a 633 modem or... (More)
Answer
hello there how to switch the letter key back to letter type
Answer
I am trying to replace my t41 monitor. I need instructions. Can you please help? THanks!
Answer
I had this T41 for 4 years. The only thing I've changed is an additional 512MB memory which was... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For IBM ThinkPad T41 PC Notebook:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
