Question about Samsung PCL541R 54" Rear Projection Television
Samsung Projection TV - Yellow White Level and Auto Focus Failure
I have a Samsung PCN5425R projection TV. The picture is not terrible but the auto convergence (Perfect Focus) stops at 27% complete for each color. When I adjust the convergence manually, I still get a very slight green edge to the images. Can I adjust this or does it require repair? If repair is required ,would it be expensive?
I also noticed that the "white level" on this set is substantilly more yellow than my new Hi Res LCD TV. Is there a problem with the Samsung projection TV with its yellow color or are my expectations just too high relative to an LCD?
  • Morris1969 Jan 04, 2008
    Can I put the set in service mode and manually adjust the convergenace myself or does this require a technician?
    Will the convergence adjustment address the issue of the yellow tinged white level or is that a differnt problem?
    The progress bars only go up to 27% on both the red and blue adjustments when using Perfect Focus. Again the picture is pretty good, just a slight green edge. The yellow is more of a problem. I should mention that this projection set has been in use at least 12 hours/day every day for 4 years.
    Would this be a relatively inexpensive repair/adjustment or would you recommend spending the money on a new set?
    Genius:
  • 1,030 Answers
Perfect focus is based on service mode convergence. FActory setting as it were. the set needs to converged in service mode then these values stored then it should work
Posted on Jan 03, 2008
  • 2 more comments
  • Willie Howell Jan 04, 2008
    the yellow tinged may be a problem with dirty glycol fluid. ussally in the blue tube. i seen a few samsungs with that problem
    I just thought of another thing. Dirty GLYcol fliud also interfers with perfect focus. The sensors have trouble seeing.. does perfect focus stop when the blue is up?
    With that kind of use it will cause the tubes to grow dingy. these sets are really not that much trouble to fix... replaceing the glycol in the tubes is somewhat labor intensive. involve removeing the tube. the setup issue the green edges not difficult at all.. tech should be able to do in home. In my shop u would expect to pay 125 to 250 for repair. less if you can live with the yellow ting. Samsung doesnt generlly replace glycol..they replace the tube. depending on set. So if you can get the convergence touched up and the glycol replaced I think it would be a good option. I would have to recommend repair
Sony kp-57hw40 double picture. regular and the other right next to it is red. tried auto focus and nothing happens. while holding auto focus btton down get red cross and white next to it. tv is 9 years...
Auto Focus button no longer work.Tv have a problems known as a convergence problems,it dead.Tv have colors lnes R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts,must be replaced on the tv convergnce board to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 13, 2010 | Sony KP-57HW40 57" Rear Projection...
Problem with my Samsung PCN5425R 54 in. projection. I am seeing double and pictured is bowed and I see red and green colors on the screen. Is this the convergence board. Is this difficult to fix? I am not...
Your convergence ic’s have failed, this is a common problem with most all projection tv’s, the repair is involved. I suggest in your case calling a local repair shop.
Sep 01, 2009 | Samsung PCN5425R 54" Rear Projection...
The pictures is yellow.
hello it sound like convergance chip may be the problem get an engineer out as it's a big job to do yourself trust me i've done a few good luck
shaun
Aug 23, 2009 | Samsung HC-R5245W 52" HDTV
Purple/Green Outline surrounding picture
I have seen two different things cause this. The first and most common is the electrical failure of one or both convergence IC's. A handful of times, the data in the DCU became corrupted and I was able to enter the service mode, go to manual convergence and correct the one location that was off.
Apr 28, 2009 | Toshiba 50HDX82 50" Rear Projection...
Samsung SP43T6HCX displaying ghost images
May be it is effected with a virus
Apr 20, 2009 | Televison & Video
Auto focus problem
The auto focus is not actually focusing the tv. When it is running it is adjusting the convergence. Most likely the repairman that replaced your tuner didn't plug the sensor wires back in. I would call him back out and have him hook it back up.
There should be a convergence menu in the tv. Use the samsung remote and go into the menu and look for convergence.
Sep 11, 2008 | Samsung HCM553W 55" Rear Projection...
Samsung HCN4226W blue color outlines
Samsung parts for convergance problem
http://www.partstore.com/Part/Samsung/Samsung/BP9500142E/New.aspx
This convergence board works with the following Samsung television models: HCM4215W, HCN529WX, HCN559WX/XAA, PCN5425R, HCN4226WX, HCN529WX/XA
Mar 10, 2008 | Samsung HCN4226W 42" Rear Projection...
Samsung projection 54"
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
Feb 12, 2008 | Samsung PCN5425R 54" Rear Projection...
Samsung rear projection tv has multiple images with differnet colors
The auto self focus screws up if the picture does not remain constant or close to it while focusing. It is designed to self focus every fifteen minutes. Go to menu and then setup and turn the auto focus feature off. I have had mine off for the past year and have had no problems. If you slide the bottom portion of the remote down you will see a self focus button. My suggestion is to put a DVD in and hit the pause button during a scene and then hit the self focus button. It should align back up and may take a couple of tries. (If you have an aftermarket remote, just enter the menu and then setup and you can activate the self focus feature, just don't turn it to auto focus!)
Dec 31, 2007 | Samsung HC-P4752W 47" Rear Projection...
Loss of convergence after powering off.
you must enter the service mode and align your convergence and save it to the epromm also activate the auto focus to activate the sensors , power on /mute-1-8-2- / press enter to save and before you exit activate the focus key on the remote ,very inportant to do the last step./g
Apr 29, 2007 | Samsung PCN5425R 54" Rear Projection...
Samsung PCL541R 54" Rear Projection Television Logo
251 people viewed this question
Jerry Greenberg
Jerry Greenberg
