Kenmore 63942 Dryer
Problem for Kenmore 63942 Dryer
Kenmore Dryer Model 110.646.02300\r\nBlower,
By drperryj on Nov 03, 2009
Kenmore Dryer Model 110.646.02300 Blower, heater run. Drum does not turn. How do I access belt?
Best Solution
posted on Nov 03, 2009
Very Helpful)
jsrock516
Rank: Guru  Kenmore Washers & Dryers  Expert
Rating: 96%, 7228 votes
To access and/or replace the belt on this model dryer follow these steps:
1. UNPLUG the dryer and remove the lint screen.
2. Remove the two screws that were under the lint screen and lift the top panel.
3. Unplug the door switch conector plug and any ground wire that may be installed on the casing.
4. Locate the two screws that hold the front panel in place. There should be one screw on each side in the cabinet interior.
5. With the door shut, lean against the front panel and remove the two screws that hold it in place. Once the screws are removed, grasp the front panel at the top center and lift straight up to remove.
You should now have complete access to the dryer interior. If the belt is broken, this may cause the idler pulley (tensioner) to come loose. This is normal with no tension on the pulley to hold it in place. To install a new belt and re-install the pulley, follow these steps:
1. Loop the drive belt around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum from the previous belt).
2. With the tensioner in your left hand, insert the clip end of the idler pulley into the grooves on the dryer bottom casing with the idler wheel pointing to your left. (The grooves are directly in front of the drive motor.)
3. While holding the tensioner in place, insert the belt UNDER the wheel with your right hand and pull it up and over the drive motor pulley.
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for Whirlpool and refer to diagram H.
Once you have the belt installed, re-install the dryer front panel by holding it as you did previously. Line up the holes on the inside bottom edge of the front panel with the small mounting cleats on the front edge of the side panels. This can be done by yourself, but an assist may make it easier. Once you have the front panel in place, lean against it to hold it in place and install the mounting screws.
NOTE: Don't forget to reconnect the grounding wire and door switch connector plug. Without the door switch connected, the dryer will not run. Lower the top panel back in place and reinstall the two screws.
NOTE: Placing a piece of duct tape over the dryer vent chute will help safeguard against dropping anything down in the blower fan assembly. If you drop any screws down the chute, you will need to remove the dryer back panel to retrieve them.
If you still have questions, please let me know. I hope this helps you.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" Detailed, precise written solution. Very appreciative of prompt response. First time to site. Very impressed! " - drperryj
Popular Solutions for Kenmore 63942 Dryer
Questions and Unsolved Problems for Kenmore 63942 Dryer
Do you recommend Kenmore 63942 Dryer?
Answer
Answer
The dryer will start when the button is pushed but as soon as the button is released the dryer... (More)
Answer
how do you open the bottom to reset the dryer
Answer
Is there a reset button on a Kenmore Dryer model 76990800. The dryer won't start initially but I set... (More)
Describe your Dryers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dryer Experts
Top Washer & Dryer Repairmen
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
