Question about Linksys Wireless-G Broadband Router
Missing SSID Recently (after making no known changes) my network SSID stopped appearing in my list of available networks. Coincidently a "linksys" unprotected network with a full signal strenght has appeared. I'm guessing this is my network but how do I get it so appear as such and get it back to a protected network? Thanks Justin
    Problem Solver:
  • 10 Answers
Well more then likely someone reset your router. now securing it again will depend on the model but typically from the internet explorer window type in the address bar 192.168.1.1 it will prompt you for a username and password username by default is "admin" and leave password field blank and click ok. this is for most models.(if you are not able to access this you are going to need to find the manual or get then model # and goto linksys.com to find the default password for that model"
from here click on "wireless" at the top then click on "wireless security" here you can choose the security mode either wep or wpa enter your encryption key click save settings and now your router is protected again.
If you still are having problems write back the the model # and I or someone else will be glad to help you.
Posted on Jan 04, 2008
Keeps saying error code 051031
Assuming you are referring to the Wii console, this is suggested troubleshooting:
Hit the link below for access to the posted troubleshoots listed
Nintendo Customer Service Nintendo Wi Fi Connection Error Code Results
Error Code: 051031
The only wireless network within range of your Wii console is not configured or is not compatible with the Wii.
  • Check for interference that may be preventing a successful connection. Click here for tips.
  • Check to see if the router you are using is a known to be incompatible. Click here to view our list. If your router is known to be incompatible, we recommend using a different router if possible.
  • Make sure that the SSID (network name) matches exactly to what you have entered in the Wii console's settings. To verify:
    1. Login to your router's settings (click here and select your router, if available, for information).
    2. Look for the section for SSID (typically in the "wireless settings" area).
    3. After you find the SSID (network name), verify in the manual settings of the Wii console that the SSID appears exactly as listed in the consumer's router. This includes making sure capitalization, spaces, or special characters match exactly.
  • Look up your router, if available, in our list of wireless routers, and check for any special notes that may be necesary to get the connection to work properly.
  • The router may not be assigning an IP address to the Wii console, and a connection using the "Manual Settings" may be necessary. Click here for help.
  • Your router may require a firmware update to work properly with the Wii console. Firmware updates can usually be found on the router manufacturer's website; consult the manufacturer for more information.
  • If the problem persists, try our general troubleshooting steps.
Sep 30, 2015 | Video Game Consoles & Games
Error code 51032
  • Login to your router's settings (click here and select your router, if available, for information).
  • Look for the section for SSID (typically in the "wireless settings" area).
  • After you find the SSID (network name), verify in the manual settings of the Wii console that the SSID appears exactly as listed in the consumer's router. This includes making sure capitalization, spaces, or special characters match exactly.
afor more help visit CBR Tech Solutions
Oct 20, 2012 | Nintendo Wii Console
We went from a windows xp to windows 7 and now our linksys won't work. it comes up error 322. help. model # WRT54GS v7.2
NOTE: For instructions on how to "Get Downloads" from Linksys Support site, click here.
Connecting to Wireless Networks Using Windows 7's WLAN Autoconfig
Follow the steps to connect to your wireless network using Windows 7's Autoconfig.
Step 1:
Click on this icon kb20600-001_en.png at the bottom-right of the screen and you will see a list of available wireless networks.
Step 2:
Select your wireless network's name or SSID then click Connect.
NOTE: If the wireless network's name or SSID is not listed, the SSID broadcast on the router is disabled. To connect to the wireless network with SSID broadcast disabled, click here.
If the computer does not connect, it is probably because the computer cannot detect any signal or cannot see any wireless network. In this case, you should change the channel of the router. For instructions, click here.
If WEP/WPA is enabled on the router:
NOTE: To learn more about WEP/WPA and other Wireless Settings, click here.
Step 3:
You will be prompted for your wireless network's security key. Click OK after entering your security key.
Step 4:
You will see the following screen and you will be soon connected to your wireless network.
Nov 24, 2010 | Linksys Wireless-G WRT54GS Router...
How do i setup my wireless linksys model wcg200?
The wireless settings that you need to take note of are:
a. SSID - this is the name of your wireless network
b. SSID Broadcast - an indication if your SSID is showing on the list of networks available
c. Wireless Security - serves as the password for your wireless network
To check the wireless settings on the Linksys router, follow the steps below.
Checking the Wireless Settings on the Linksys Router
Step 1:
Access the router's web-based setup page. For instructions, click here. If you are using a Mac computer to access the web-based setup page, click here.
Step 2:
When the router's web-based setup page appears, click Wireless.
4678-009.png Step 3:
Look for Wireless Network Name (SSID). If it's still set to "linksys", change it to something unique then click 6-4680.jpg NOTE: Take note if SSID Broadcast is Enabled or Disabled. If it is Enabled, it means your SSID will show among the list of wireless networks available when any wireless device will search for a network to connect to. If it is Disabled, it will not be visible.
Step 4:
Click the Wireless Security subtab and take note of the current Security Mode.
If Security Mode is set to WEP:
4678-007.png If Security Mode is set to WPA:
4678-013.png You can change your WPA shared key if you want to personalize it. It should be a minimum of eight and a maximum of 63 characters long.
Step 5:
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 23, 2010 | Linksys WCG200 Router
How do i make my unsecured network secure? using linksys WRT54G v8
Access the setup page of router by typing 192.168.1.1 in the address bar.
By default, leave the username blank and the password is admin.
Once on the setup page, go to Wireless. Under Basic Wireless settings, change the default SSID Linksys into any name. This will allow you to easily determine which is your wireless network.
Then go to Wireless Security and enable WEP. Type a passphase and click the generate button. Take note of the Network key. Remember that you will use this network key to all wireless computers.
On your wireless computer, view the available wireless networks or site survey. Select your SSID and enter the network key to connect.
I hope this helps!
Jun 20, 2010 | Linksys Wireless-G WRT54G Router
Set ssid for wrt54gs
You do that in the router setup an SSID is simply a "Name" that You give it. You log into the router, 192.168.1.1 use admin/blank and admin as login & password..once in the router you set it up with the wizard.
here is a manual to help you.
http://www.retrevo.com/support/Linksys-WRT54GS-Wireless-Routers-manual/id/421ci076/t/2/
Feb 23, 2010 | Linksys WRT54GS Wireless Broadband Router...
Error code #51031
Error Code: 51031
  • Your router may require a firmware update to work properly with the Wii console. Firmware updates can usually be found on the router manufactruer's website; consult the manufacturer for more information.
Dec 05, 2009 | Nintendo Wii Console
Having problem connecting wii to internet. get error code 51030. unable to access point. please confirm ssid.i'm using static ip and have go throug all the steps. i'm also using a new router by linksys,...
Error Code: 51030 The only wireless network within range of your Wii console is not configured or is not compatible with the Wii.
  • If you are getting this error after completing a system update, this is usually because the console resets to using the first connection slot after an update. There are two things you can do:
    • If you know which connection file you were using before, you can select that connection file, then select "Use this connection" to change that to the default. You will need to do this each time they download an update.
    • If you don't know which connection file you are using, or if you would prefer not to update the active connection file each time, try to clear, and then re-create your connection setting in slot one before doing the remaining troubleshooting.
Oct 21, 2009 | Nintendo Wii Console
Linksys WRT150N
I only have 3 suggestions.
1st one is to make sure the ssid is not similar to other routers you are using on your profile. ie.(change it to a unique name)
2nd is to make sure you check the box that says broadcast your ssid.
3rd check to make sure you select the router as an access point and not adhoc or infrastructure option. Finally you can try to change the channels eg. i like channel 3 b/c it doesnt interfere with any phone lines.
good luck
smeags.
Jan 06, 2008 | Linksys Wireless-N WRT150N Router
Linksys Wireless-G Broadband Router Logo
421 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
