Print Servers
Generic problem for all Print Servers
Network printer not printing properly
posted by sillypuddy15 on Jan 03, 2008
I have a network printer that is not printing all the text I send to it. Another lap top on the same network has no problem. It used to print properly, just stopped printing properly after the holidays, Merry Christmas I guess!
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Feb 10, 2008
Not Rated (0)
petrumusic
Rank:Apprentice Apprentice
Rating: 92%, 4 votes
Hello Begg, I don't think your solution is right. I agree, Silly
Puddy isn't clear either "printer stopped printing properly".
If we asume the printer didn't print anymore after a while,
it is a cable-conectivity / or firewall problem.
XP Service Pack 2 has a new feature
DEPdata execution prevention (DEP). This precents code execution in memory regions already marked as storage. This is a powerful tool against buffer overrun exploits.
If a program is failing and you want to disable DEP to see if that is the cause. Here are the steps. (Just disable DEP for the program in question... don't disable it for your whole system.)
    1. Click Start
    2. Select Control Panel
    3. Select System
    4. Click the Advanced tab
    5. In the Performance region select Settings
    6. Click the Data Execute tab in the dialog box that opens
    7. Select Turn on DEP for all programs and services except for those I select
    8. Click Add.
    9. The open dialog box will open. Browse and select your application. (printer software in this case)
    10. Click Open
    11. Click Apply
    12. Click Ok
    13. Reboot
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Network printer not printing properly:
I don't want to Accept this solution
Solution #2
posted on Jan 07, 2008
Not Rated (0)
BggFixya
Rank:Guru Guru
Rating: 87%, 109 votes
Hi Silly,
Try going to the Add/Remove programs and remove the drivers for your printer, then reboot, reinstall then, connect to the network printer, and try again,
Good luck.
Thank You!
Can you Help with these Print Servers problems?
Print Servers
i am trying to print a brochure in Word 07 and the...
Canon (6981A002AA) for imagerunner 2200,...
when I go to copy a plain white piece of paper I get...
when I go to copy a plain piece of white paper I get black...
TallyGenicom (048959) for T2265, T2280,...
i have a tally t2265. when i switch it on it comes up with...
D-Link DP 301U (DP-301U) Print Server
i have this print server with hp laserjet 3005 printer. i...
Loading problems.
Repair Service
Find Print Server Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Computer Networking Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
