Question about RIM BlackBerry 8800
Rollerball not working
Tonight the rollerball on my Blackberry Pearl will not work in the upward direction; only the downward direction. Is this something I can fix or is this a hardware problem?
Similar problem on 8800, but I may have splattered a drink on the trackball. If I put a drop of water on my finger and roll like mad, the contacts will work...but only for awhile. And in the process, some nearby keys quit working properly or start doing commands on their own. I may try the rubbing alcohol solution suggested.
  • Cory T Jan 04, 2008
    Any suggestions where or what this costs? One solution suggested for the similar problem on 8100 was to use rubbing alcohol and do myself--what do you think of that? I'm afraid I could void any warranty by taking to a tech, or maybe also by doing it myself??
    Brigadier General:
  • 7,752 Answers
On the BB need to have the board service....this will solve the problem on your 8800 Blackberry.
the roll ball......on the need to have the pad on the board replaced so take it to a professional mobile technician and have that done.
Posted on Jan 04, 2008
My Rollerball won't scroll down - tried everything.
Cause: The sensitivity of the trackball/trackwheel might be less Faulty Hardware Resolution: Increase the sensitivity by following procedure Option -> Screen and Keyboard -> Horizontal Sensitivity and Vertical Sensitivity to 100 If not working check with the service center
Aug 11, 2009 | RIM BlackBerry Pearl 8100
Rollerball assembly help
this link tells you how to put it back in the correct way...
very good explanation includes pictures
May 04, 2009 | RIM BlackBerry Pearl 8100
My rollerball won't click.
I'm having the same problem with this. One of my friends and a Att worker have suggested that replacing the Rollerball with a new one which can be bought off Ebay for 5 or 6 bucks can fix the problem. If that does't work then check to see if water damage has taken place, if any moisture has gotten to the phone it may be that. Other then replacing the rollerball i have no other solution.
Apr 17, 2009 | RIM BlackBerry Pearl 8100
had same problem. used rubbing alcohol with a cotton swabb. Took a couple of applications, but worked brilliantly within 10 minutes. Thanks!
Mar 06, 2009 | RIM BlackBerry Pearl 8100
Rollerball of my blackberry8100 is nt working
Use Rubbing Alchohol on a Q-tip to clean the roller. This happens to me all of the time and this always solves the problem
Jan 28, 2009 | RIM BlackBerry Pearl 8100
Blackberry pearl turns off when i touch the rollerball
Try a different ball in the device they are fairly easy to remove. Borrow a friends entire track ball use nail file to remove the ring then look to make sure what way the mechanism and ring go back in and try your firends if his/hers works in your phone replace the defective part. 2b4daea.jpg fb71594.jpgeb3c8be.jpg
Dec 29, 2008 | RIM BlackBerry Pearl 8100
Blackberry Curve rollerball scrolls but will not select when push
Try removing the silver cover around the scroll ball, and remove the ball. There should be a little white square underneath it. If there is no white square, but a red square, then it could be water damage. I had the same issue with mine.
Dec 15, 2008 | RIM BlackBerry Pearl 8100
Blackberry rollerball
Hi guys I have the solution. I think all your trackballs are stuck. If you cant move it, take the silver ring off with a knife, take off the trackball and put rubbing alcohol on it wth a Q - tip until it works. Can some1 help me? My problem is titled My blackberry pearl wont load up.
May 16, 2008 | RIM BlackBerry Pearl 8100
RIM will admit, its a known issue with the blackberry was the first blackberry with a front trackball and so there is a design flaw that dust will get in here and prevent the magnets from moving around inside.
the little silver rim is acutally designed to be taken off so you can clean inside. take an embrodery needle, and put it under the silver rim by the TY button on the keypad....once this pops off, there is the ball and there are 2 more silver rims inside along with 4 magnets. remember how you take this apart, cause if you dont, then this will void any warrenty your phone might have.
in order to clean this, soak the ball in rubbing alchohol and take a cotten ended Q-tip with rubbing alchohol and damp it a little bit and clean it real well.....its also nice preventative doing this regularly...,. (not taking the ball out, but just cleaning the rim and ball about once every other day or so....)
Dec 30, 2007 | RIM BlackBerry Pearl 8100
RIM BlackBerry 8800 Logo
94 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
